Part 3: Assembling the Printer
Assembly took almost 12 hours. Most of this time was spent in reading and understanding all the steps described in the instructions manual, and locating all the parts - plastic components, screws, pins etc. from various packets. I also made some mistakes during the assembly and had to redo the process sometimes. If I were to do this again, I may be able to do this in 6 hours.
Following are the various main functional blocks that have to be assembled.
- Heated print bed
- Graphic LCD
- Processor board
- X-axis motor, smooth rods, and bearings
- X-Axis carriage
- Extruder assembly
- Z-axis assembly - motor, smooth rods, and bearings
- Y-axis assembly - motor, smooth rods, bearings, and heated print bed
As the assembly was very involving, I missed taking pictures of many functional blocks. Below are some pictures I managed to click during the assembly of some of them.
The heated print bed: This is a magnetic bed on which a metal sheet is placed and the parts are printed on this metal sheet. Depending on the material printed, the bed is maintained at a temperature to keep the part sticking to the bed while the print is in progress. This bed can be heated to 100+ degrees Celsius. A thermistor is used to sense the temperature and control the heater. The printer maintains the bed to within 1 degree of set temperature.
The extruder: This is the part that pushes the filament through the heated nozzle. For Mk4, they have developed a new design with planetary gears to push the filament through. The extruder assembly also has a built-in load cell that is used to do the first layer calibration. This is a fascinating design and was a little complex to assemble.
The parts needed for the extruder.
Extruder assembly in progress. The planetary gear is assembled.
The fully assembled extruder assembly.
The processor board: This is the brain of the printer and has a 32-bit microcontroller that controls all the operations of the printer. The board is placed inside a metal enclosure and has connectors for connecting various components like motors, sensors, power cables etc.
The processor board is installed inside the enclosure.
All cables are plugged into the respective connectors.
The WiFi adapter board plugs into the processor board.
A few work-in-progress pictures. The living room looked like a battlefield for 2 days.
X-Axis Assembly: This assembly carries the print head and moves in the X Axis. The assembly has a base that holds a breakout board with connectors to connect various components of the print head like heater, thermistor, extruder motor, filament sensor, load cell etc. A wiring harness runs from the back of this assembly and connects to the processor board. The extruder assembly is mounted on this carriage.
The X-axis carriage assembly with the breakout board.
The wiring harness connects the X-axis carriage to the processor board enclosure. Note how neatly the wires are bunched inside a sleeve. A nylon wire runs along the wires providing necessary mechanical support to the wires.
The extruder is mounted on the X-axis carriage.
