Old 28th January 2024, 13:43   #1
Thanked: 397 Times
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia
Hello Dear Forum Members,
While trying to troubleshoot why there was a no communication fault on the rain and light sensor, I needed to access the BCM. The BCM resides behind the glove box on the left side of the cabin air filter element. I removed the glove box but in the process broke the hook of the "Brake Element" which opens the glove box softly.
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240128_1206421.jpg
The part itself is made entirely of plastic. I tried to join the hook portion back to the neck using Fevicol ALLFix all purpose adhesive and left the part for drying for 24 hours. However after 24 hours, the strength that needs to be there in the hook was not present.
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240128_1207031.jpg
I searched online for the part which was difficult but eventually I found the part number which 5E2 880 324. Skoda-parts.com had the part in stock, which was retailing at 16 Euros. 1450 Rs for a plastic part is pretty steep, but what stopped me from buying it and going DIY was the shipping price. It was 75 Euros! I wasn't ready to pay close to 9000 Rs for a piece of plastic!
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-capture5.jpg
Time to wear my thinking hat. Ideas ranged from heating the two pieces and plastic welding them together to cutting a nut in half and then attaching it to the neck of the brake element. Both the ideas were dropped because since they posed their own problems. How was I supposed to melt two small portions of the plastic or how was I supposed to attached a half cut nut to the plastic neck.
I then turned to my box of knick knacks and found some self tapping hooks which are meant to be used with wood. Could this hook be threaded in to the brake element?
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240128_1207431.jpg
I decided to give it a go. The first order of buisness was to make a pilot hole so the self tapping hook has something to latch on to. I took a very thin wood nail from the same box of knick knacks and proceeded to heat the nail on the stove till it was red hot. I then carefully melted a hole on to the centre of the neck of the brake element.
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240128_1216411.jpg
I then started threading in the hook. First thread hooked on without any problems.
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240128_1219251.jpg
As I was finding it difficult to grip the hook and turning it simulaneously, I helf the hook with a pair of pliers and rotated the brake element carefully to thread the hook fully. My main fear was that I might split the plastic in half but thankfully, that did not happen. At last, the hook was threaded in fully.
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240128_1221131.jpg
It was time to fit the glove box brake element and test if it worked. Here is a short video of before and after.
Unfortunately I do not have any video or photos of how I fixed the glove box and the brake element because it is a two hand job.
DIY is far from perfect. The overall length of the brake element has increased by about 7 mm. I feel there is a initial moment when the glove box is free falling after which the brake element catches it and slows it down. But hey, I did not have to spend 9000 Rs so I am happy.
DIY cost - may be 5 Rs.
Time consumed - 15 minutes
vaibhavyagnik is offline   (21) Thanks
Old 29th January 2024, 09:59   #2
Thanked: 587 Times
Re: DIY: Repairing the Glovebox Brake Element of my Skoda Octavia
Brilliant. Love it. The best part is that your "fix" is stronger than the original part. Plastic parts are a pain as very few "glues" will stick to them. Super glue (cyanoacrylate) used with a filler powder (plastic, glass or metal) is very usefull for adding "body" to a repair and give it extra strength. G Bond, Glue Angel is a good example of a "ready to go" kit.
I use a German version of this kit, even repaired the aluminium float pin hinge on a carburettor and corrosion holes in a 50 year old float bowl !!!
At a push you can just use superglue and fine dry sand as a filler. I repaired a plastic refrigerator ice box hinge using a screw glued into place with superglue and salt, still works 2 years later.
Redex is offline   (3) Thanks
Old 29th January 2024, 16:29   #3
Zippy_wheels's Avatar
Thanked: 460 Times
Ever since I read on the internet somewhere, I use baking soda+super glue to fix the kids toys. It dries faster and the baking soda provides filling to the mix creating a very strong bond. All the details are available on the internet. It is my go-to solution for most fixing, especially for plastic parts.
Zippy_wheels is offline   (1) Thanks
Old 30th January 2024, 11:09   #4
Thanked: 587 Times
Baking soda (sodium bicarbonate) is better than salt (sodium chloride) but in true "bodge/jugaad" style it was the only material I had to hand. I tried sugar but the superglue reacted and produced a lot of heat and smoke because it was an organic material.
It was during my annual 4 month stay in India, (all of my usual toys were at home in the UK).
Regards Neil
Redex is offline   (1) Thanks
Old 3rd February 2024, 08:07   #5
Ingenious concept Vaibhav. You not only managed to save 9000 rupees, but also made a more durable part yourself.
akash.yadav001 is offline   (1) Thanks
Old 3rd February 2024, 11:00   #6
Thanked: 409 Times
This is truly the realization of the "Panch rupay Nikal" ad from Feviquik.
Pidilite may soon approach you for an interview.
Anyway... it truly shows that if we value our money, we actually become more intelligent...
shamanths3 is offline   (1) Thanks
Old 7th July 2024, 20:40   #7
Hello everyone,
A week before while I was getting a GPS tracker fixed in my Octavia, the technician needed to get an access to BCM to power the tracker device. Upon completion of the job, while he was fixing the glovebox back the unfortunate incident happened with the 'brake element'.
I tried looking for the part online, but No joy. So I got inspired by this post and tried fixing the part on my own.
I took 2 small commonly available nails which was there in my toolbox, and with the help of Fevi kwik and some baking soda powder I was able to strongly fix the nails to the plastic part of brake element.
This worked quite well and I was able to fix the element in the glove box and obtain the slow/soft movement of the glovebox once again as it was before the incident.
Attaching a few pictures of the job carried out.
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240707_142055.jpg
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240707_171818.jpg
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240707_171848.jpg
DIY: Repairing the Glovebox Brake Element of my Skoda Octavia-img_20240707_172623.jpg
the1984@doctor is offline
