Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | ![]() 15,715 views |
![]() | #1 |
Distinguished - BHPian ![]() ![]() | DIY Install | Adding a Rear Cabin Roof Light in 3 Cars | Ignis, Polo, Nexon Adding Roof Light To Rear Cabin Area Of Ignis, Polo & NexonA few months pass & then there's a DIY itch with the car. Suddenly something starts to feel missing, regardless of whether its really missing or not! Here we go again. So the title is clear enough I think to set the context. All 3 cars I own are really just small hatchbacks of various lengths. Yet - the makers of all 3 have been very smart in installing the sole cabin-illumination in the front, near the IRVM. Everything in the back should remain a dark secret they said. So far - the Nexon has a detachable LED with USB charging installed on the C pillar within reach of my son from his child-seat (its documented in the Nexon ownership thread). But then - something permanent, without LiIon battery & directly linked to the front lamp / doors - is definitely better. And since anyway its needed in 2 other cars - I decided to install it in the Nexon as well. Cleaner the better. Let there be light! Warning - if you don't have the cold heart needed to use a cutter and literally chop-away parts of your beloved car - this is where you close the tab & don't read further. Some very cruel blade-work will be needed for this project & you need to have that cold-blood. As usual, Japanese efficiency and cheap modularity to the rescue. Sourced a WagonR front roof / SCross rear cabin lamp from Boodmo (3Nos) for this purpose. There are good alternatives available - like the cabin light of Tata Punch / Altroz. They are better finished & come with an LED light. But then - they cost 4 times as much ![]() This is the part that I sourced - Boodmo.com - Suzuki Cabin Roof light Part Number is - 36210 M 55K00-6GS As usually is the case - the lamp does have a cheap halogen bulb included - but does not include the connector we need, to attach the wiring. And its a typical non-standard connector thats hard to source online. If you want to source it from Boodmo - the options are roof harnesses of other cars like Swift / Baleno (In my case it was rather costly to procure 3 especially since Boodmo stupidly multiplies shipping charges for every added quantity of the same item in the order). The easiest option is to buy the Swift roof harness. It costs around 205 INR + shipping. Boodmo.com - Swift roof wiring harness. The use of this harness is just to get the suitable connector and 2 wires of suitable length pre-crimped. Most parts of the harness other than the roof lamp wiring, we'll anyway have to cut away. I luckily stumbled onto KARDIY once on YouTube and saw that they are stocking the connectors with small 3 wire pig-tail, available for sale via their Whatsapp catalogue. Checked with them & they had it in stock. INR 100+ shipping per unit. Thats really well priced. The gentleman is kind & I liked doing business. Added to contacts for future! We'll use a set of Polycab wires covered in shield to extend the pigtails to the desired power sources. We'll go one car at a time in the next posts. The steps are pretty much the same -
For harness preparation, temperature & fireproofing, sound deadening you may also want to have -
So since the project involves cutting away roof liner parts, something that is irreversible (especially painful if you get it wrong), it had to be the Suzuki in the garage that was the guinea pig! Can't imagine messing up something on the Polo/Nexon, would have to be taken to the ER with spasms. We'll be doing a pathfinder installation with the Ignis, learning as we go, & fine tuning the process as we move to the next 2 cars. Jump To Car - About the Suzuki Light - ![]() ![]()
The following 19 BHPians Thank Reinhard for this useful post: | aman9393, blackwasp, bobbyblr, brownkaiser, dailydriver, DevilzzzzOwn, digitalnirvana, GTO, InControl, jomson13, keroo1099, MotorDev, PaddleShifter, PearlJam, Sangwan, sukiwa, The Rationalist, TROOPER, vaasu |
![]() | #2 |
Distinguished - BHPian ![]() ![]() | re: DIY Install | Adding a Rear Cabin Roof Light in 3 Cars | Ignis, Polo, Nexon Suzuki IgnisSo, without further ado, lets get on with the experiment cum learning exercise with the Ignis, hopefully in a step by step manner of documentation.
The following 28 BHPians Thank Reinhard for this useful post: | adityan27, amalji, aman9393, arjunsatheesh, blackwasp, bobbyblr, brownkaiser, Captain Slow, condor, denny_ace, DevilzzzzOwn, digitalnirvana, Dreamlifter.07, GeeTee TSI, gischethans, GTO, InControl, Joelinf, jomson13, MotorDev, Nick_Wanderlust, PearlJam, Pennant1970, Sangwan, sukiwa, The Rationalist, TROOPER, vaasu |
![]() | #3 |
Distinguished - BHPian ![]() ![]() | Re: DIY - Install Rear Cabin Roof Light in 3 Cars - Ignis, Polo, Nexon Volkswagen PoloThe process will be pretty much identical in the Polo GT TSI 1.2, at least the one I have from 2014. It's roof lamp connector also has the 3 wires of the same function as the Ignis. Nothing too complicated here. And its an 8 year old car afterall. So lazy as I am - I simply cut the stock connector's wires, added a proper electrical wire connector in between, and reconnected the new wires and old connector back into place. Of course - its always advisable to do a cleaner job, by depinning & re-pinning the stock coupler. I spent 15 minutes trying to take out the existing pins. After that under intense October Sun, it started feeling that I was damaging the wires more by so much abuse. It was better to just cut them clean. You can follow the process mentioned in the post above. Since we are going to pull the power from the front dome light - the process and concept is pretty much identical to the one we followed with the Ignis. So more pictures than English in this particular post.
On a side note - I was planning to upgrade the front dome light to the 3 lamp Jetta spec assembly since some time. It costs around 4K INR to purchase right now. Was sitting on the fence for a while. But now with the excellent overall lighting spread in the cabin & the minimal need of specific map lights for the 2 people in the front in my usage pattern - I suspect I won't be going down this upgrade route for now. Less than 300 INR did the job and some for me! Last edited by Reinhard : 14th October 2023 at 17:47. |
The following 19 BHPians Thank Reinhard for this useful post: | adityan27, aman9393, blackwasp, brownkaiser, denny_ace, DevilzzzzOwn, digitalnirvana, Dreamlifter.07, GeeTee TSI, gischethans, GTO, InControl, MotorDev, PearlJam, Pennant1970, Sangwan, sukiwa, The Rationalist, TROOPER |
![]() | #4 |
Distinguished - BHPian ![]() ![]() | Re: DIY - Install Rear Cabin Roof Light in 3 Cars - Ignis, Polo, Nexon Tata NexonThe show-stopper. The coup de grace. My precious ![]() The Nexon's roof liner - is the best of all the 3. Thick, well knitted, well insulated & well installed. In fact - there is a thick layer of glass-wool (or similar material) across a lot of the roof's area inside the roof-liner as well. The liner is well stuck on the roof as well. The little things that make overall experience better. Its my most favourite of the 3, so cutting the liner of this one, was always going to be quite painful. Nauseating even. But its like a Band-aid as often. Do it quickly and its bearable. So here we go. Most of the steps you are well aware of by now. So it will be a repeat to some extent.
Well - that's all folks! That's 3 cars with a much better cabin illumination at a really negligible cost. As always - happy to learn from you & do share any insights or suggestions improvements that you might have identified. Happy to help in case anyone wants to try this. Its one of the easiest electrical updates to do in mass market cars. Cheers! Last edited by Reinhard : 19th October 2023 at 18:47. |
The following 29 BHPians Thank Reinhard for this useful post: | adityan27, aman9393, arnav17, ashutoshb, batterylow, blackwasp, Blue Vitriol, BoneCollector, brownkaiser, Captain Slow, chaksjr, DevilzzzzOwn, digitalnirvana, GeeTee TSI, gischethans, GTO, InControl, jomson13, maheshm619, marszeus, MotorDev, Nick_Wanderlust, Pennant1970, pratuls, Ravi Parwan, Sangwan, Sudarshan_N, sukiwa, TROOPER |
![]() | #5 |
Team-BHP Support ![]() | re: DIY Install | Adding a Rear Cabin Roof Light in 3 Cars | Ignis, Polo, Nexon Thread moved out from the Assembly Line. Thanks for sharing! |
The following 3 BHPians Thank Aditya for this useful post: | digitalnirvana, GTO, Reinhard |
![]() | #6 | |
BHPian ![]() | Re: DIY - Install Rear Cabin Roof Light in 3 Cars - Ignis, Polo, Nexon Quote:
![]() I had used a generic LED roof light which costed about 80 - 90 rs. It can be directly screwed on to the roof liner.Its light-weight and doesn't put any pressure on the liner material.BTW, yours' look better integrated.I made a hole with dia of a pencil and used a cloth hanger to route wires. Still going strong. ![]() | |
The following 6 BHPians Thank maheshm619 for this useful post: | blackwasp, chandrus03, DevilzzzzOwn, InControl, Reinhard, SaiSW |
![]() | #7 |
BHPian Join Date: Mar 2016 Location: Pune
Thanked: 672 Times
| re: DIY Install | Adding a Rear Cabin Roof Light in 3 Cars | Ignis, Polo, Nexon That looks like some serious amount of time spent doing this DIY, Kudos to you!! I'm quite averse to fiddling around with the electronics on my bikes and cars but with such a well documented post I am inclined towards giving it a try. How long did this take? I'm guessing the time would have been similar on the Polo and Ignis and a bit on the higher side for the nexon. Thank you for sharing. |
The following BHPian Thanks jomson13 for this useful post: | Reinhard |
![]() | #8 |
Senior - BHPian | Re: DIY Install | Adding a Rear Cabin Roof Light in 3 Cars | Ignis, Polo, Nexon Phenomenal effort (quite so even for one car!), beautifully articulated and fabulous results. Better interior lighting just lifts the ambience of the car and your cars have gone up a segment or two in this department. Cruel to be kind indeed with the headliners! |
The following BHPian Thanks GeeTee TSI for this useful post: | Reinhard |
![]() | #9 | |||
Distinguished - BHPian ![]() ![]() | Re: DIY Install | Adding a Rear Cabin Roof Light in 3 Cars | Ignis, Polo, Nexon Quote:
It doesn't take too long. About 3 hours max, including the harness preparation & installation, even at a leisurely pace. I did it in the Nexon in less than 2 hours, including everything. Slowest was the Ignis sadly - as I accidentally ended up blowing a fuse ![]() Quote:
The following BHPian Thanks Reinhard for this useful post: | jomson13 |
![]() | #10 |
Newbie Join Date: Apr 2023 Location: Coimbatore, TN
Thanked: 45 Times
| Re: DIY - Install Rear Cabin Roof Light in 3 Cars - Ignis, Polo, Nexon This is very useful. I'm going to try installing it in my alto 800 |
The following BHPian Thanks chandrus03 for this useful post: | Reinhard |
![]() | #11 | |
Newbie Join Date: Nov 2023 Location: Noida
Thanked: 21 Times
I am very distraught right now, I do not know if I have many options. I have tried putting foam sponge as spacers before and after the beam. That kind of works but has created a bulge outwards on the roof liner and doesn't look very appealing. What other options do I have? ![]() | |
![]() | #12 | |
BHPian Join Date: Jul 2021 Location: Gurgaon
Thanked: 338 Times
Always ready to help DIY community ![]() | |
The following BHPian Thanks KarDIY for this useful post: | Reinhard |
![]() | #13 |
Hey hesoyam_007. These are what come to my mind -
