Wiring
Easy part.
A major chunk of my frustration before I began this was due to the connector. I didn't think that sticking a wire into the hole on the plug was going to be reliable enough. But it worked out fine. I've done this mod on the fourth of August. Running happily till today.
Remove the two horns with the ratchet wrench. 10 numer IIRC. Unplug the Honda Horn plug. Take your new wire. Expose a few cms of wire, Bend it and twist it to make it thick, and insert it snugly into the Honda plug.
The other end of the wire has to be exposed according to the size of the spade connector. Snake the wire through the cut, clamp the metal arms using pliers onto the insulated part. Tug on it to ascertain it's strength.
Should look like this, then bend the wire back down to lock it in. The clamp at the bottom should prevent it from sliding out, but better safe than sorry.
Now slide these onto the horn terminals.
Pay heed to the + and - if possible. Some horns can be picky about the terminals.
I followed this wiring diagram below that Bosch sent me.
The Interface with the factory harness has to be sealed well. Wrap it with copius amounts of insulation tape.
With the + side wrapped up , move to the ground or (-).
The horn on the city, unlike many other cars has only one terminal, the negative is the grounding through the mounting hardware. But the horn has two connectors. So we connect another short wire to the horn, and stick it in the mount .
The new horns have their own mounting hardware, but see whether the old ones were sturdier. Use the better ones..
To ground this new horn, attach a short, but not too short cable. I had to make this grounding connection thrice because I cut it too short.
To make your job easier, you can first connect the ground wire to the body, and then just slide the spade on the horn later.
You screw in the screw to hold the metal mount, push the exposed wire into the hole for the screw, the screw will hold the wire in and ground it.
This is easier said than done. Keep extra slack or more appropriately, length in the wire to help you.
You can also ground it to the mounting plate, although I chose to mount it to the body of the car for a better ground.
These nuts on the mount have a knurled pattern to help grip onto the grounding wire. Use it.
Similar pattern is also seen on the horn side ,which is another spot you can stick in the negative wire. It's all ground anyway.
Mounting the horn should be done with the opening on the trumpet facing down so that the chance of water staying in are lesser. Bosch documentation had a small square depicting recommended mounting.
Here's the sound with only the high tone horn. The low tone will follow the same procedure. Once both horns are wired up, honk a few times, shake the connections, honk a little more.
only then put the bumper back on. You will follow the same steps but backwards.
REmember, with plastics, hard fast movements.
And don't drop screws inside bumpers like me. I left mine. I didn't bother taking it out lol
