Firstly, I want to thank everybody who took the time to reply with their kind and appreciative words! Never did I imagine my first post here would win so many hearts.
Originally Posted by Turbojc Your model looks pretty accurate. Could you walk us through how you measured your car and translated the dimensions to that of your model?
Great job, and keep up the good work!
Cheers! |
I am so glad to see that I have been able to spark an interest in this field within so many fellow BHPians! I would absolutely love to share the process I followed in this endeavor.
First, I began with this wonderful tutorial:
This does a very good job of explaining the process.
Simply put, one begins by tracing over 2D images of the required model (car blueprints) from different angles. Beyond that, it is entirely using estimation to make sure it looks proportional from all angles. Here, the CarWale 360° image helped a lot (
https://www.carwale.com/honda-cars/amaze/360-view/).
Below you can see a comparison between an intermediate stage and the final 3D model that I built:
The vast difference in the complexity between the two models is the result of regular incremental updates to the basic design over a span of ~2 weeks until it was exactly to my liking.
Initially, I even thought of getting the basic design printed (I was
that desperate). However, I figured that I had traveled so far on this unprecedented path, I might as well perfect it. Should be easy once you go through the above video.
As for the size and measurements, the proportions should be fine as long as you follow the same blueprint for all sides. The final printed model's measurement can be adjusted by locking the x/y/z ratios and changing any one value, to maintain proportion, on Blender itself, or something more simple such as Windows 3D Builder (my choice) which is present by default on Windows PCs.
Lastly,
Originally Posted by superguy282 Also any other tips or suggestions before the printing? |
As a novice myself, the only advice I would like to give: Don't forget, 3D printing is a
very physical process. Simply creating a model following the linked video won't yield fruitful results (notice how
my wheels and ORVMs are separately placed). You must take into consideration that the 3D printer prints against gravity and thus your model must be well balanced, and most importantly, have a solid base on the print-bed, lest you want to end up with some 3D filament
spaghetti :P
Once again, thanks a lot to everybody for your words of encouragement, I hope this little walkthrough will be useful to all of you wonderful collectors out there, may you get all the little models you ever desire!
~Rudy.
