At long last I managed to spend some hours on Debbie again! Some mixed results, but progress is being made as they say.
Also, the remaining materials for Debbie arrived. This is all I need to build the carburator later on . So i should have everything to see me through our second lock down for the next five weeks. I also have 2,5 weeks holiday, so I am looking forward to make some good progress with Debbie!
Before ordering material I go through the Debbie drawing and right down what I need, check it against what I have in Stock and what is left to order. It all goes into my Master Spreadsheet. I hope that will be useful to someone building Debbie after me.
Materials arrive well packed, long brass tube taped on a piece of wood, so it doesn’t get damaged!
First order of business; make the second support. Which means transferring the dimensions from the drawing on a piece of aluminium. This permanent marker works really well. I do need to use some emery paper and de-greaser first for best results
Some additional lines, so I know where to put my hack saw to work!
I tried a different set of protectors on my Vice. These are cladded in rubber, instead of all aluminium. Not much difference though.
Ten minutes with my hack saw:
Ready to go back into the mini mill, to cut the rounded top using my well proven method with a boss, on which the support rotates
Pretty good result! Identical to the earlier one!
Back onto the lath. I am using the center to line up the support. Works really well, I got it well within 0,1mm centric. I checked afterwards with my gauge dial, but this is good enough as it is!
I am doing everything the exact same way as on the first support. But it is all going twice as fast. Practice makes perfects, as they say!
Drilling with my largest 13mm drill bit, so I can then put my boring bar to work.
Boring bar and dial gauge set up to ensure I go only 8mm deep!
The end result, test fit with the bearing. Perfect!
Next I was going to try to figure out how to mill the bottom end of the support and how I could modify the first support along the way. Problem though. I made another error on the second support as well. The first support was way too high. The second support is not as high, but it is still the wrong measures!!
So I came up with a very different approach to rescue both parts. Not much choice, because due to the lockdown it is going to be difficult to get hold of new material.
So I made a bushing out of Delrin. Exact same diameter of the bearing, twice the width. So it holds the two supports together and alligne the centre of the shaft to be exactly.
Next, after some more carefully measuring and a lot of checking, double checking and triple checking I cut off the base of both supports!!!
Now I can produce two half supports with identical measures easily on my mini mill:
Only took me about 30 minutes, but the results look good!
Next I need to mill two basement parts for the support. I think that should be possible with the cut offs I have. I will then drill, tap, bolt these to the earlier made supports and Bob’s your proverbial uncle once again.
The final milling will be done with everything bolted together. I need the bearing centre (now the Delrin bushing) to be exact 60mm above the bottom of the base. That should be doable.
I still have a few days of work, not even full days of work. By Thursday I will be done completely work wise and I will take two full weeks holiday. So plenty of time to get going with Debbie!
Jeroen
