Re: DIY: Caliper slide pin cleaning & Brake pad replacement Quote:
Originally Posted by One:1 Thank you DeepakMenon. Just walk into any lubricant shop and ask them for silicon grease. Not many will have it, but they will guide you to someone who does. What i used was some generic silicone grease, not the best.
What i didn't realise at that time was that i could have just walked into any MGP store and asked for caliper grease which is around 20INR a packet
yes, copper grease. ill keep that in mind. Any idea where i can get that in india? |
Thank you Man, got few of them at a MGP some 20 odd bucks. Pic attached
On the copper grease, it is something you should have it comes very handy. In brakes you should apply it on caliper bolts, caliper pin threads.. this prevents them seizing on you. You can also apply it at the back of the pad where it meets the caliper piston.
Just remember a little goes a long way.
I recommend this for its ease of application and brand [~1500 bucks] will last you many years https://www.amazon.in/Loctite-37616-...copper+loctite
If on budget then this https://www.amazon.in/gp/product/B07...?ie=UTF8&psc=1 |
