A bit of a dreary rainy windy Sunday morning. Perfect weather for a bit of fiddling.
In all honesty, I am running out of jobs to do. My little white board is empty. I did note the date/mileage of filling it up with oil. I need to get a more precise measurement on how much oil it is really using.
Next week I have a nice Spider tour, organised by the Dutch Alfa Spider Register. Just to get to the starting point is almost 200km. So I dare say I will do about 500km in a single day. 4/5 motorway running at 3500 RPM. Lets see what that does to the oil level.
As I noted some weeks ago, the Spider rear right indicator has been given me some problem. Twice it failed during a tour. Twice I got it fixed, but without really knowing what I did. Other than taking it apart, bit of cleaning etc.
So time to investigate properly
Spider has by far, the most stuff in the boot all the time. Everything needs to come out:
Of course, make sure you know what you are doing. Which means when working on electrics, make sure you have a diagram handy. I recently had these Spider electrical diagrams printed on A3 and laminated:
Comes in handy:
Take away some of the upholstery:
Some more and some proper lighting to see what I am doing
Took out the socket for the indicator and for the brake light. They are connected on a common ground. The ground is in fact common to all lights and I don’t have any other problems.
But on the diagram I also noted a common connector for all the rear lights. So dug it up from behind the upholstery and it looked not that great.
Had a good look at the bulbs and came up with something interesting. The glass bulb on the right is completely detached from the fitting.
Here it shows a bit more pronounced:
Remarkably, it was still working and it came out/into the fitting by twisting a bit with no problem either. Never the less, that is a bulb failure waiting to happen, so I replaced it. Had to rummage through various spare parts boxes and boots of all my cars to find a replacement.
Need to get myself some spare light bulbs. Cleaned everything thoroughly, tightened the various contacts on the fittings a bit, put everything back again. Lets see if it works.
Also, fixed my little flashlight I keep in the Spider. Last time when the indicator broke, I noticed it wasn’t working anymore. Batteries are fine, so was the bulb. Needed a bit of cleaning, put some new batteries in as well.
I keep a simple multimeter in all my cars. Just in case. When I used the one in the Spider last time, to check a few things on the broken indicator, I noticed the display getting very weak. So I replaced its battery. Not sure, but I think I must have had this little multimeter for over twenty years. First time I am replacing the battery.
With the Spider all sorted I decided to run some tests on my Lathe. My Dutch lathe-forum friends have suggested that something might be amiss with my lathe as I was having problems with using the various reamers on my little wobble engine. The finish just was not as good as it should be.
So I decided to try it out. Got all my drills and reamers out. I have quite the collection now!
Cleaned my lathe meticulously. Put a 30mm bit of steel round bar in the chuck.
Carefully adjusted for the correct height and squared it off
Drilled with the centre drill, 2,5 mm
With a 2.5 mm drill and a 5.9 mm drill
Next the 6mm reamer. Real slow RPMs, lots of cutting oil and on retracting blew a lot of air through it
This time the finish looks pretty good. In fact by eye it looks better than on this photograph somehow. You will have to take my word for it.
So I don’t think there is anything amiss with my lathe, it is just me not being very good on some aspects of using the lathe.
By the time I had cleaned away everything it was still raining so I decided to give my bicycle a quick clean too. Just like previous time, Hosed it down with the special cleaning solution on the bicycle stand. I did take the little guidance wheels apart as they tend to get very mucky
I am quite pleased with this combination of chain and sprockets. I checked for wear again and it still shows virtually no wear. I have been adhering slightly more rigorous cleaning and oiling regime, so far so good!!
Jeroen
