Old 25th January 2017, 17:36   #1
maddyguage's Avatar
Thanked: 279 Times
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta
After deep research, finally installed PLA 2.0 Park Assist on my friends 2012 VW Jetta 2.0 TDI Highline DSG.
First of all I must tell you that it's not an easy task. In order to install new module you need to strip down whole dashboard, which is not an easy task.
You need Highline variant of the car with 8K OPS and compatible ESP as well as MFD.
Parts you need :
1. PLA 2.0 module - 3AA 919 475 M.
2. Ultra-sound PLA sensors - 1T0 919 297 A - 2 for front and 2 for rear.
3. Brackets for PLA sensors - 3C0 919 493-4 - 4 nos. (notice that front sensor brackets are angled)
4. Rear ABS sensors - 2 nos - WHT 003 857-8 A.
5. Wiring harness.
6. Park Assist switch.
You can buy whole kit from aliexpress. Just ask seller about compatibility regarding your car MY. You can use this kit if you already have 8K OPS in your car.
PLA 2.0 kit - OEM PLA 2.0 for Jetta
IMPORTANT NOTE -
When you order this kit, choose "with 8 sensors" under color name.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-htb17cmkhvxxxxabxxxxq6xxfxxxb.jpg
image source - aliexpress
Kit was received as described. Package was received within a week. Seller is very helpful and he even shared wiring diagram.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-20170125photo00003666.jpg
But before all the hassle, let's see why we should install this cool retrofit.
1. 360 OPS (boon when you're surrounded by traffic)
2. This system can park in very tight space, which we can't do.
3. Looks really cool if you've installed.
4. It can Park/Unpark so even a newbie can use it.
5. Even best valet can't beat this accurate system.
So overall you can go for this retrofit without any second thought.
Before you plan to install this retrofit, make sure you have good technician with you and all the necessary tools handy.
Tools required
* T20 torx bit
* T25 torx bit
* M12 XZN triple square spline bit socket (steering wheel remover)
* ratchet or screwdriver
* Utility knife
* Tapered drill bit (11/16 size)
* Trim removal tools
* Heat Shrink
* Fabric/friction tape
* Electrical tape
* Masking tape
* Double sided sticky tape
* Terminal pin removal tool
* adhesive (bond tite)
* Steel fish tape
INSTALLATION :
First of all remove Positive terminal from battery and insulate it with electrical tape.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_1383-1.jpg
pic courtesy - Team-BHP
We will divide installation process in following steps.
1. Remove front bumper
* First of all pop up the hood. Now with the help of T25 Torx bit , detach front grille by removing 4 screws.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-7036271339_b954ff1029_z.jpg
image source - vwvortex
* Remove 4 screws from fender near wheel arch using T25 Torx bit. Make sure to check size of the screws and put them in right spot again.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-7036271845_6b0d65e698_z.jpg
* Remove one screw from bumper near wheel arch which holds assembly in place.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-7036272153_fbc7b0e8ce_z.jpg
* Remove 8 screws from the bottom of the bumper using T25 Torx bit.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-6890179066_c52e30e90e_z.jpg
* Now with the help of other friend, remove front bumper slightly and remove OPS as well as fog lamp socket. Put it somewhere safe where it doesn't get damaged.
2. Remove rear bumper
I have found video for this on youtube. You can checkout, else I have taken screenshots from video for step by step guidelines.
* Remove 3 screws from fender side of rear bumper using T25 Torx bit.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-9.52.53-pm.png
image source - youtube
* Remove 3 screws from underneath of bumper on the right side using T25 Torx bit. Remove black plastic.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-9.56.31-pm.png
* Remove 4 screws from the bottom of bumper using T25 Torx bit.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-9.56.58-pm.png
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-9.57.05-pm.png
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-9.57.17-pm.png
* Now most importantly, there is a hidden screw inside fender panel. Remove that panel and remove one screw using T25 Torx bit with extender on both the sides.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-9.58.12-pm.png
* Now remove Tail-light assembly. Open trunk and remove cap inside boot. You will see white plastic screw with spring around it. Just unscrew it and easily remove tail-light assembly. Unplug tail-light connector.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-10.00.49-pm.png
* Remove screw under tail-light assembly using T20 Torx bit. And unclip bumper from 2 clips on each side.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-10.07.36-pm.png
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-10.08.06-pm.png
* Now slide bumper backwards starting from fender side. Gently get it out.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-10.08.19-pm.png
* When you try to remove bumper, you will feel that there is something holding it. Just remove that one screw on each side using T25 Torx bit with extender.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-screen-shot-20170127-10.09.28-pm.png
* Now remove whole bumper and put it safe somewhere so it doesn't get damaged.
3. Locate 8K OPS Module
Now this is the step where everybody will think why I chose to install this kit in the first place. As Tanveer_2558 suggested in his thread, it's a real headache to locate 8K OPS module.
According to other forum threads, it's located under following locations.
1. In the trunk.
2. Below wiper assembly.
3. Below glove-box.
4. Behind instrument-cluster (most difficult one).
Removed wiper assembly but no signs of module.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3744.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3745.jpg
We tried everywhere and finally found it behind instrument-cluster. In order to remove that, you have to strip down whole dashboard.
DISCLAIMER : Before you start removing dashboard assembly, make sure you have all the required tools handy and you have a good technician with you.
INDEX :
1. REMOVE DASHBOARD.
2. REPLACE ABS SENSOR.
3. INSTALL PLA SENSOR.
4. WIRING.
5. CODING.
maddyguage is offline   (9) Thanks
Old 9th February 2017, 01:15   #2
maddyguage's Avatar
Thanked: 279 Times
re: DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta
REMOVE DASHBOARD :
Now step by step remove whole dashboard assembly. If you're not sure about this process then take some professional help.
Start off by removing headlight switch panel. Just pull off 'FAUX' wood panel.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3746.jpg
Remove headlight switch. Put it at "0" position and press it. Just regulator slight right and switch will come out easily. Remove side panel.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3751.jpg
Now remove HU. Disconnect all connectors and put it somewhere safe. Remove HU panel by disconnecting 'AIRBAG WARNING LIGHT' connector.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3756.jpg
Now using Gannu's DIY for removing instrument cluster (VW Polo DIY: Removing / upgrading the instrument cluster) method, unscrew 2 screws from instrument cluster.
Disconnect 24 pin connector and gently remove cluster. Put it safe.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3757.jpg
Now disconnect glove box and gently remove it.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3759.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3760.jpg
After you remove whole glove box, it will look like this.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3766.jpg
Remove panel near gear level, which has Park Pilot switch. Disconnect connectors.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3764.jpg
Now remove HVAC (AC console) panel. Disconnect connectors.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3762.jpg
Remove gear lever leather cover.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3765.jpg
Now in order to remove upper dashboard, we need to remove centre trim (gear lever) so that dashboard can be pulled back and we can remove it easily.
So start with rear AC console. Unscrew it.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3767.jpg
You will see there are 2 screws inside centre armrest, unscrew them.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3770.jpg
Remove rear AC vents. Now you will see there will be some play with whole assembly. We will use that as our benefit and will lift upper dashboard.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3771.jpg
Now we will have to remove steering wheel.
DISCLAIMER : If you don't have any idea how to do this, then don't attempt this step alone. Use some professional help if needed.
Tools :
1. M12 XZN triple square spline bit socket.
2. Ratchet with extension.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3780.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3781.jpg
For detailed guidelines please follow Gannu's steering removal (VW Polo DIY: Mk7 Flat-bottom Steering wheel upgrade) thread.
First of all we have to remove airbag from the steering wheel. Before that remove upper trim of steering column.
Now rotate steering wheel about 90 degrees right. And if you look at back you will see a clip like this.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-clip.jpg
Now using flat-head screw driver push this clip downwards to detach it.
Rotate steering to its normal position. Now again rotate it about 90 degrees left. repeat above steps and detach another clip.
Now that clips are detached. Remove airbag assembly carefully. Disconnect yellow connector and black connector.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3775.jpg
Put airbag safe.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3776.jpg
Now rotate steering wheel to centre position and using described tool remove centre screw.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3777.jpg
Now make sure that steering is locked in centre position. 2 slots should be aligned in position.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3778.jpg
Now pull steering out and put it safe.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3798.jpg
Now remove both stalks by unscrewing 2 screws on each side.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3779.jpg
Now with the help of a friend lift dashboard a bit and you will see the culprit a.k.a 8K OPS. It is located on the right side of dashboard.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3785.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3788.jpg
Now disconnect 16-12-12 pin connector from OPS module and get it out.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3791.jpg
We have the new PLA module which has similar connector pins. Both look identical.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3792.jpg
Side by side pic of old and new modules. (left - 8K OPS , right - PLA)
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3794.jpg
Pin layout of both modules are exactly the same. Though we will have to rework on connectors in coming steps.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3795.jpg
Old 15th February 2017, 23:23   #3
maddyguage's Avatar
Thanked: 279 Times
REPLACE ABS SENSOR :
Now we have to replace ABS sensors from rear wheels.
Basically these are similar sensors but, new sensors are more accurate.
First of all by using hydraulic jacks, lift the car.
Now remove rear left tyre.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3799.jpg
As you can see in the picture, there is cable coming out. That's our ABS sensor.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3804.jpg
To remove that you need to unscrew that single screw and disconnect cable. This one is tricky job. You need to go underneath of the car to remove this screw and take extension ratchet to remove it.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3805.jpg
Once you unscrew it, remove upper cable using flat-head screw driver.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3810.jpg
Here is the pic of new sensor we need to install.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3811.jpg
Here is the pic of both sensors. (left is old, right is new) They both look identical. The only difference is A in the end of part number.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3812.jpg
Now install this new sensor and tighten screw.
Repeat this step for the right wheel also. And that's done.
maddyguage is offline   (8) Thanks
Old 18th February 2017, 22:43   #4
maddyguage's Avatar
Thanked: 279 Times
INSTALL PLA sensor :
First of all we will start off with front bumpers. As we know we have to install 2 additional PLA sensors in front bumper.
Luckily VW Jetta front bumpers come with factory markings (may be for foreign markets) so we just have to drill at given markings.
But the problem is, we couldn't find any drill bits for front PLA sensors. They are bigger and different in shape.
PLA - FRONT BUMPER :
So first we had to measure front PLA sensor.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-20170125photo00003655.jpg
Then we used this retro tool for drilling front bumper.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-20170125photo00003656.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-20170125photo00003657.jpg
Marked centre point of circumference and rotated this tool with pressure. And in no time we got perfect hole for sensor.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-20170125photo00003658.jpg
Using file tool, smoothened edges of the hole.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3971.jpg
Perfect hole after filing a bit.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3970.jpg
Now using good adhesive (we used bondtite) stick PLA sensor in hole using brackets.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3880.jpg
Left side PLA sensor :
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3972.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3974.jpg
Right side PLA sensor (Apple logo of my iPhone visible) :
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3973.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3975.jpg
Just stick them and let it dry for some time around 2-4 hours. Just make sure its in right place and sensors stay parallel to car.
PLA - REAR BUMPER :
As we did in front sensor install, measure sensor size. Rear sensors are smaller so you can use drill bits to make hole.
We used drill bit which came with aftermarket rear bumper camera (haha). It matched size of rear sensor.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3879.jpg
After drilling, use file tool to smoothen rough edges.
Using adhesive (bondtite) stick rear PLA sensor along with bracket.
Right side PLA sensor :
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3881.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3872.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3919.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3968.jpg
So now we have installed front and rear PLA sensors. Now we will move on to wiring installation.
Old 19th February 2017, 20:47   #5
maddyguage's Avatar
Thanked: 279 Times
WIRING :
Now if you spare some time on this and understand diagram, then it's pretty simple. Otherwise it may confuse you. Because the diagram we used here doesn't match actual wiring diagram of PLA kit. But luckily everything works even after following incorrect diagram. phew
Seller was very helpful and he even sent wiring connections as follows.
Front bumper parking sensor cable Black T8 Plug--- Yellow T12 Plug of Parking module
T8/1---------T12/1(ground wire)
T8/2---------T12/2(firing line)
T8/3---------T12/5 Front left Green and white
T8/4---------T12/6 Middle left Green and yellow
T8/5---------T12/7 Middle Right Green and Red
T8/6---------T12/8 Front Right Green and Blue
T8/7---------T12/9 (PLA Module Left)Black and Green
T8/8---------T12/10(PLA Module Right)Grey and Green
Switch Cable
Front Parking Sensor Switch ----------Parking Module Yellow T16 Plug T6/2-------T16/13(Green and Blue)
T6/5-------T16/4(Green and While)
PLA Switch--------Parking Module Yellow T16 Plug
T6/2-------T16/9(Blue and white)
T6/5-------T16/16(Purple and white)
PLA2.0 Cable
PLA2.0 Rear Bumper Cable
White and Purple cable ---Black Plug of Parking Module T12/6(Right PLA Sensor)
Yellow and Purple cable-- Black Plug of Parking Module 12/10(Left PLA Sensor)
Red and Yellow—Positive wire of Rear Bumper sensor cable (doubling same color wire and get power supply.
brownish yellow---Negative cable of rear bumper sensor(Ground)( doubling same color wire)
We followed this diagram below. But as you can see, it is incomplete. There's no instructions for rear PLA sensor connection.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3821.jpg
PARK ASSIST SWITCH wiring (left side connector) for PLA module :
Starting with Park Assist switch wiring. First of all get this wire beneath dashboard throughout upper right corner of dashboard, so that we can connect it to PLA module.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3817.jpg
Now as you can see in the diagram, we need to tap brown(ground) and grey (illumination) wire into Park Pilot switch.
This switch comes with additional brown and grey wire connector. This can be used if you want to install TPMS (Tire Pressure Monitoring System) switch.
Now as you can see there are 2 wires coming out of switch - green and pink. Pull that cable throughout dashboard to upper right corner where PLA module is placed.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3818.jpg
Now you need to insert 2 wires to T16 (16 pin connector i.e left connector) :
PINK wire to PIN 9
GREEN wire to PIN 16
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3843.jpg
If you look closely, you can clearly see that there are marking of numbers on connector itself. Using that marking we are going to insert new wires.
So that switch wiring is completed. We will connect switch later on when we put back dashboard.
FRONT PLA SENSOR wiring (middle connector) for PLA module :
As you can see in the diagram, you just need to insert 2 wires to T12(a) (12 pin connector i.e middle connector)
GREEN with black stripes wire to PIN 9
GREEN with white stripes wire to PIN 10
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3835.jpg
Front PLA sensor wiring is done. Now we will move on to Rear.
REAR PLA SENSOR wiring (right connector) for PLA module :
As I described earlier, if you look at the diagram there is no details given for how to connect rear PLA sensor.
So we had to check by ourselves only and finally got correct PIN numbers after several discussions.
You need to insert 2 wires to T12(b) (12 pin connector i.e right connector)
BLUE wire to PIN 6
BLACK wire to PIN 10
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3836.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3839.jpg
Now connect all the connectors back to PLA module and put it back in position.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3844.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3846.jpg
Now that we are done with PLA module wiring, we will be moving on to PLA sensor connection.
FRONT PLA sensor wiring :
Now if you look at wiring diagram, it is pretty straight forward.
Each sensor consist of 3 wires.
LEFT PLA
One is for GROUND. (brown)
One is for SIGNAL. (green with black)
One is for POWER. (red)
RIGHT PLA
One is for SIGNAL. (green with white)
We need to tap GROUND & POWER to existing parking sensors as shown in diagram.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3921.jpg
Now get 2 green wires from PLA module to front bumper from inside engine bay. You can use cloth tape for additional safety. Don't place it near any metal or engine component which gets too hot.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3807.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3806.jpg
Now as you can see, wires are short. But you will find additional waterproof connectors which will give you enough length to cover both PLA sensors.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3956.jpg
Connect GREEN with white stripes to FRONT RIGHT PLA sensor.
Connect GREEN with black stripes to FRONT LEFT PLA sensor.
Now moving on to rear PLA sensor.
REAR PLA sensor wiring :
LEFT PLA
One is for SIGNAL. (black)
RIGHT PLA
One is for SIGNAL. (blue)
We need to tap GROUND & POWER to existing parking sensors. There is no diagram which shows this step but, it's similar to front sensor wiring so no issue.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3931.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3932.jpg
Connect BLUE to REAR RIGHT PLA sensor.
Connect BLACK to REAR LEFT PLA sensor.
Now connect blue and black wire connector with each other and this will go from trunk to PLA module, all the way through interior panels.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3940.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3966.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3965.jpg
Now after all this wiring instructions, you will be wondering why I chose green wire for front and black/blue for rear.
If you look closely at PLA kit, you will see that it comes with all proper connectors and proper wires. You just need to figure out which one goes where.
Green wire is short compared to blue/black so it is but obvious that blue/black will go to rear sensors.
So finally done with wiring, we will head on to coding section.
maddyguage is offline   (10) Thanks
Old 10th March 2017, 01:36   #6
maddyguage's Avatar
Thanked: 279 Times
CODING :
Now moving to very important step. Don't get scared after connecting VCDS to your car. You will see many fault codes.
There will be almost every warning light lit up on your instrument cluster. It's ok.
You will see so many RED (fault codes) in VCDS scan. Don't worry it's normal. It will go after proper CODING.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3904.jpg
STEERING ASSIST :
Go to 44. STEERING ASSIST under select control module.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3908.jpg
Now go to ADAPTATION.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3907.jpg
Under ADAPTATION menu, go to INSTALLATION PARK STEER ASSIST drop down menu.
And go to channel 4. and click on READ.
It will show you 2 as stored value.
Now put 1 as new value. Click save.
Now go back. Exit controller.
ABS CONTROLLER :
Go to 03. ABS CONTROLLER under select control module.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3910.jpg
Now click on CODING.
You will see huge code. Copy it and keep it safe somewhere in case if you need it in near future.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3911.jpg
Now click on LONG CODING HELPER.
Now go to Byte 17.
Check Bit 2 if you want to install TPMS.
Check Bit 3 if you want to install XDS.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3912.jpg
Now click on Lcode 2.
Go to Byte 17.
Check Bit 0.
Check Bit 3.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3984.jpg
Now go to Byte 18.
Check Bit 4.
Check Bit 6.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3915.jpg
Click Exit.
Now you will see new code.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3916.jpg
Now click Do It.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3917.jpg
You will see coding accepted.
VOILA.
You will see that most of the fault codes have gone already. Some will be there. Don't worry we can clear them by steps below.
Now turn on car.
Rotate steering fully to the right.
Rotate steering fully to the left.
Now you will see that steering angle sensor error has gone. (ESP light will go off from instrument cluster)
Tell someone to walk around your car for Park assist calibration and 360 OPS.
Now roll up and down all the windows 2 to 3 times.
After driving for about 100 metres you will notice that all warning lights from instrument cluster has gone.
After scanning with VCDS, you will see no errors. phewwww.
360 OPS :
It will automatically turn on after coding.
Remember it will turn on only if any object is nearby.
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-img_3979.jpg
DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta-20170125photo00003662.jpg
maddyguage is offline   (22) Thanks
Old 10th March 2017, 02:51   #7
maddyguage's Avatar
Thanked: 279 Times
THANKSGIVING :
If you have done everything right then congratulations. You have successfully pulled off this difficult task. It's tiring and time taking installation, but outcome is surely delicious.
I would like to thank our local technician Rajubhai for assembling and dismantling all the interior parts carefully.
I would also like to thank our local electrician Shoyeb for doing all electrical job and letting us work in his shop.
I would also like to thank our tech support Vishesh - AVS TUNING for answering all the queries regarding coding and wiring stuff.
I would also like to thank Tanveer - Team-BHP handle for all the inputs and inspiring us to pull off this tricky mod.
I would also like to thank GTO and all moderators for always motivating me and for providing such a huge platform for car enthusiasts.
And finally I would like to thank my best friend Mehboob Siddique for agreeing on doing this mod and obviously letting his car for this mod.
maddyguage is offline   (18) Thanks
Old 3rd June 2018, 23:46   #8
Thanked: 321,362 Times
Re: DIY Install: Park Assist PLA 2.0 (self park/auto park) on a VW Jetta
Thread moved from the Assembly Line to the DIY Section. Thanks for sharing!
Here's Tanveer's Jetta with Park Assist:
GTO is offline   (16) Thanks
Old 4th June 2018, 10:55   #9
Thanked: 230 Times
Good lord! That is some amazing work. Well done sir.
clix22 is offline
Old 4th June 2018, 11:04   #10
Thanked: 34 Times
Wow! That's some serious DIY,
vittalnrv is offline   (1) Thanks
Old 4th June 2018, 12:07   #11
Thanked: 565 Times
Oh god this is serious stuff. Pretty awesome. Its not a DIY its a DIYIE (Do it yourself if an expert)
Does the park pilot require throttle input or is it completely automated.
deepjaju is offline   (1) Thanks
Old 4th June 2018, 12:29   #12
Thanked: 156 Times
Wow... This is awesome. What patience and knowledge. Respect. The other day it took me 2 hours to assemble my son's hot wheels set. And that too with some serious inputs from my 5 year old.
kiranton is offline   (2) Thanks
Old 4th June 2018, 15:21   #13
Amit_Kapoor4750's Avatar
Thanked: 77 Times
Thanks for sharing this amazing DIY maddyguage. It was a very difficult job, equally beautifully done. Your planning and execution is top of the mark. The detailed step by step guide with very informative and clear pictures will assist many of us in our planned DIYs.
Amit_Kapoor4750 is offline   (1) Thanks
Old 4th June 2018, 18:59   #14
murajith's Avatar
Thanked: 172 Times
Wow, Thats passion at work .
Attention to detail and also effort to pen down detailed instruction (which many OEM instruction manual may not have) is much appreciated.
murajith is offline   (1) Thanks
Old 4th June 2018, 21:30   #15
ameet_pv's Avatar
Thanked: 22 Times
Awesome step by step instructions. End result video too good.
ameet_pv is offline   (1) Thanks
