Old 18th January 2017, 10:44   #16
graaja's Avatar
Thanked: 25,618 Times
re: Installed: VW Flip Camera in my Polo GT TSi. EDIT: Custom Adapter Plate & Water Drain on Page #3
Originally Posted by akash_m View Post
Wow! Thats an amazing DIY. I will definitely do it on my Polo. Wanted to ask if the boot lid operation remains the same as original, i.e by pressing the logo. Also, wont the camera be spoiled with the fingers each time you do so?
Thank you for the kind words, Akash! Boot lid open function remains same as original. You can flip the logo and open the boot, or long press on the key fob and open the boot. When you open the boot, the camera is not exposed. The camera is below the plastic spring loaded flap (check the picture on the first post). It only comes out when reverse gear is engaged. All the best with the install
Originally Posted by vw19d View Post
Man this is an awesome. I wasn't even aware that there was something called as "flip camera". This is so cool and must surely be a head turner when you reverse during driving. Fantastic job
Thank you for the kind words vw19d! Yes. This is a very cool feature indeed. Not sure if people notice the logo flipping open though
graaja is offline
Old 18th January 2017, 14:12   #17
Thanked: 634 Times
Like your other diys, neatness of the installation is very good. You never would've got this finish if you had assigned the installation job to an 'expert' of our land. The field of vision of the camera is very good, that alone makes it worth the effort, more than the fancy associated with the flip action.
crdi is offline   (1) Thanks
Old 18th January 2017, 14:18   #18
prateekvidya's Avatar
Thanked: 289 Times
Great work !! It looks so cool and you did make the effort to work out the details
Just a question : can you use this during monsoons ? Did you do any sort of checks for water-proofing and general contamination built up ?
prateekvidya is offline   (1) Thanks
Old 18th January 2017, 14:36   #19
graaja's Avatar
Thank you very much for the kind words, crdi!
Thank you very much for the kind words.
Very good question about water proofing. I have not yet done checks for water proofing. I have added a rubber washer to prevent water from seeping inside and believe it should work well in monsoons. There is a water drain pipe in the camera. But Polo does not have a water drain channel in the boot. I am looking into this to figure out if anything can be done about this. Will update the thread when I have a solution.
graaja is offline
Old 18th January 2017, 18:43   #20
ramgkulkarni's Avatar
Thanked: 363 Times
Amazing job this is!
I went through the whole post inch by inch and it is such an amazing artifact. This will be a tough DIY install to top. Great detail and execution. Its time to buy a polo now
ramgkulkarni is offline   (1) Thanks
Old 18th January 2017, 21:27   #21
adneeraj's Avatar
Thanked: 386 Times
This is super level of perfection and does not look like a DIY at all. Amazing levels of sophistication!!
It does add a lot of value to the GT overall and the before/after pics clearly show that the effort was worth it.
After reading through GT threads (this was one of my shortlisted cars until I bought the Grand i10 Auto), I believe this is the greatest of all mod-friendly car around in India right now!
So many things one can achieve and make it almost at par with the European counterparts...
Huge thumbs up
adneeraj is offline   (1) Thanks
Old 19th January 2017, 01:38   #22
ecosport rules's Avatar
Thanked: 2,063 Times
Superb DIY Graaja
Neatly done as seen on a factory finished Passat
How did you manage to get the dynamic moving lines which respond to steering inputs while reversing?
ecosport rules is offline   (1) Thanks
Old 19th January 2017, 05:48   #23
graaja's Avatar
Thank you for your kind words ramgkulkarni!
Huge thumbs up
Thank you for your kind words Neeraj! Yes. Polo is one of the best mod friendly cars. Every mod I do, I tell myself this is the last one. But something else keeps coming up
Originally Posted by ecosport rules View Post
Superb DIY Graaja
Thank you for your kind word ecosport_rules! The dynamic guidelines are in-built in the DS611 HU that I have installed. It reads the steering angle from the CAN bus and controls the guidelines.
graaja is offline
Old 19th January 2017, 10:44   #24
CSharma's Avatar
Thanked: 15 Times
Oh Man! What a DIY. Exemplary work.
The way the plan is drafted and executed shows great skills and not to forget the laser cuts and the rubber seals.
CSharma is offline   (1) Thanks
Old 19th January 2017, 11:18   #25
Thanked: 1,079 Times
Ganeshji,
Awesome. Look forward to seeing this live very soon
Cheers!
Krish
krishsreedharan is offline   (1) Thanks
Old 19th January 2017, 16:56   #26
graaja's Avatar
Thank you for the kind words CSharma!
Originally Posted by krishsreedharan View Post
Ganeshji,
Cheers!
Krish
Sure Krishji. Let us catch up during the weekend mini meet
graaja is offline
Old 19th January 2017, 17:03   #27
Thanked: 142 Times
Re: Installed: VW Flip Camera on Polo GT TSi
Part 6 - Final Result:
Overall, a very satisfying DIY job as this involved some mechanical problems to be solved, and I was able to do a clean install without resorting to some crude jugaad. Also, I think this is one of the coolest mods that can be done on the GT.
That’s all I have folks on the VW flip camera installation on the Polo GT Tsi.
Fantastic work Graaja and a very well detailed in terms of the steps. I can see that you are a perfectionist, which is also important from the maintenance perspective.
Can this be adapted to a dedicated display, if the appropriate HU is not installed?
AutoSphere is offline   (1) Thanks
Old 19th January 2017, 17:09   #28
graaja's Avatar
Thank you for the kind words AutoSphere!
Yes. It should definitely be possible to adapt this to a dedicated display. The camera has an RCA pin for the video signal. I am sure the dedicated display also would have a video input. There is also a small red wire along with the RCA pin that can be used as a trigger to turn on the dedicated display when reverse gear is engaged.
graaja is offline   (1) Thanks
Old 19th January 2017, 22:22   #29
HalfOctave's Avatar
Thanked: 70 Times
Wonderful, this is something innovative. This must be first of its kind of implementation of reverse camera.
HalfOctave is offline   (1) Thanks
Old 20th January 2017, 17:57   #30
Thanked: 56 Times
That is super cool!
Congrats for the successful DIY, and thanks for sharing!
ishankpatel is offline   (1) Thanks
