Old 25th December 2016, 20:16   #1
Mr.Boss's Avatar
Thanked: 7,585 Times
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-00.jpg
What?
Foot Well lamp
Why?
1) Looks Good
2) Serves purpose (little toddler drops things in hands often)
When?
Completed installation today
Where?
At home
Who?
Your's truly
How?
D.I.Y
How much?
Couple of Hundred bucks
Mr.Boss is offline   (7) Thanks
Old 25th December 2016, 20:34   #2
Mr.Boss's Avatar
re: DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny
Parts required:
1) LED Light
Either a LED strip or the blocks should do, color choice is personal. I'm using block type (3 LEDs) white LEDs, 2 Nos for either side and couple of T10 LEDs for cabin lamp
2) Wire
I had wires left from my previous project (forgot about the spec / gauge) Approx 4m will be required
3) 2 way switch
This is optional. I'm using the 2 way switch to operate the foot well lamp in dual mode.
Mode 1: Operates with the cabin lamp (Door Switch / Cabin lamp switch)
Mode 2: Dedicated power (irrespective of doors open / cabin lamp switched on or off)
4) Snap fit connector
To have detachable / removable connection from the cabin lamp to the rest of the circuit. This again is optional. I used the one from one of my left out wiring harness.
5) Fuse & Holder
I ordered through Aliexpress and awaiting delivery. Will be installed after the snap fit connector once it is delivered.
6) Heat Shrink sleeves
Optional, you may use insulation tapes as well. But heat shrink tubes are safe bet with professional touch.
Tools Required:
- Wire Stripper
- Screw Driver (to remove the cabin lamp)
- Scissor (To cut the heat shrink tubes)
- Soldering Gun
- Heat Gun / Lighter (to heat the heat shrink tubes)
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-01.jpg
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-02.jpg
Old 25th December 2016, 20:42   #3
Mr.Boss's Avatar
Removing the Cabin Lamp:
Cabin lamp with OE bulb
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-03.jpg
Switched-off condition
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-04.jpg
Notch to insert screw driver
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-05.jpg
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-06.jpg
Cover removed
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-07.jpg
Space for 2 bulbs, but only 1 installed (other one doesn't have the connection / circuit either. This is going to be the next project)
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-08.jpg
Use a little effort to remove the base unit
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-09.jpg
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-10.jpg
Backside circuit
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-11.jpg
And the socket
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-12.jpg
Socket removed
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-13.jpg
Pin configuration
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-14.jpg
1 : -ve signal from door switch
2 : direct -ve
3 : direct +ve
Old 25th December 2016, 20:47   #4
Mr.Boss's Avatar
Output wiring preparation:
Soldered the snap fit socket to the cabin lamp circuit (No prize for figuring out the poor soldering, mechanical engineer is good at welding and poor at soldering)
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-15.jpg
PS:
I should have used a Fuse Tap instead of taking the +ve from the cabin lamp itself. Ordered the same and delivery delayed.
Regular bulb and T10 LED
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-17.jpg
LED fixed
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-16.jpg
Old 25th December 2016, 20:51   #5
Mr.Boss's Avatar
Wiring & Fixing:
Removed the door rubber beadings and few trims to route the wire
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-18.jpg
Wire routing done
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-19.jpg
Circled bolt is used to grab the body earth / -ve for Mode 2 circuit
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-20.jpg
LED & Switch wiring prepared with heat shrinks
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-21.jpg
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-22.jpg
LED block pasted below the glove box
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-23.jpg
Mode selection switch placed here
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-24.jpg
Fixed with double side tape
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-25.jpg
Old 25th December 2016, 20:53   #6
Mr.Boss's Avatar
Final Outcome:
With OE cabin lamp bulb
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-26.jpg
With LED as cabin lamp
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny-27.jpg
Mr.Boss is offline   (15) Thanks
Old 25th December 2016, 20:58   #7
Mr.Boss's Avatar
Cost Involved:
LED blocks - 60 INR (30 each)
T10 LED - 50 INR (25 each)
Wire - 50 INR (approx)
Switch - 10 INR
Fuse & Holder - 20 INR (approx, yet to be delivered and installed)
Total - 190 INR
Mr.Boss is offline   (8) Thanks
Old 25th December 2016, 22:12   #8
Rudra Sen's Avatar
Thanked: 6,867 Times
Mod note: Thread moved to Do It Yourself section. Thanks for sharing.
Rudra Sen is offline   (3) Thanks
Old 26th December 2016, 14:10   #9
Myth_sx's Avatar
Thanked: 88 Times
Re: DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny
Thanks for the DIY thread. Quite helpful especially the list of required items and alternatives.
Originally Posted by Mr.Boss View Post
Parts required:
1) LED Light
Did you purchase these online or some physical shop ? Power rating for the Footwell LEDs ?
3) 2 way switch
5) Fuse & Holder
Can you provide an online link for the switch, fuse and holder, if possible ?
Myth_sx is offline   (1) Thanks
Old 28th December 2016, 19:53   #10
Mr.Boss's Avatar
Thanks for the compliments.
Did you purchase these online or some physical shop ? Power rating for the Footwell LEDs?
What ever is ordered online is yet to be delivered. All these items were purchased from stores. LED strip wattage was not mentioned, but going by the size, I assume it should be less than 0.5W / LED
Switch was purchased from local store. Similar ones are available on Aliexpress as well
SPDT Switch
In-line fuse
Mr.Boss is offline   (1) Thanks
Old 29th December 2016, 22:43   #11
Thanked: 118 Times
The setup looks extremely cool and at the cost its a steal.
Really good job and thanks for simplifying the steps for the rest of us who want to follow suit.
I have also ordered the items online - aliexpress and am motivated to try something like this.
xsrahul is offline   (2) Thanks
Old 31st December 2016, 23:26   #12
Mr.Boss's Avatar
LED cabin lamp illumination is not that good as the regular (OE) bulb. I should upgrade the T10 LEDs to higher wattage or make an alternative with brighter LEDs.
Mr.Boss is offline
Old 1st January 2017, 00:33   #13
Thanked: 118 Times
Hi, i have upgraded the cabin lamp using such a bulb.
2pcs/lot 48 SMD 5050 Panel Bright 48 led panel 12v T10 W5W festoon Dome LED Bulb Lamp interior lighting auto parking car light
http://s.aliexpress.com/uiIfYVZr
(from AliExpress Android)
Another link - Vheelocityin 70743 24 SMD White LED Lamp Car Dome Ceiling Roof Interior Reading Light https://www.amazon.in/dp/B00QFCA1LA/ref=cm_sw_r_cp_apa_kgaAyb35GFF9Y
While this is a aliexpress link, similar ones are available on indian shopping sites too.
xsrahul is offline   (1) Thanks
Old 1st January 2017, 00:41   #14
Mr.Boss's Avatar
Thanks for the links, let me order a similar one
Mr.Boss is offline
Old 1st January 2017, 21:04   #15
Thanked: 118 Times
Do let me know if that works well. Cheers and look forward to more upgrades
