Re: DIY: Tachometer Installation for WagonR & A-Star LXi Quote:
Originally Posted by a4anurag 2) Maruti A-Star LXi – 2009 model
With the experience of installation that we gathered on the WagonR, going about the same on the A-Star wasn’t difficult expect that we stopped at the point where we were searching for the brown wire behind the instrument console but later got a doubt that the EPS unit should definitely be getting this wire for the EPS to work accordingly. It was the right thing as the coupler had the wire in it. From here on things were easy except for parts sourcing.
First of all thanks for sharing a brilliant DIY. I too got inspired by your thread & wanted to have an OEM tachometer in my 2001 Maruti Zen Vxi deluxe. As zen never did came with a tachometer from the factory, I only looked for the brown wire in EPS module like the Astar & I did find one brown wire.
Next part was to source the Ritz tachometer, the MGP store manager said that he could arrange for one petrol Ritz tachometer from the warehouse. But as luck would have it, when I went to pick up the tachometer I was informed that the tachometer is broken but a tachometer for the diesel Ritz is available. Patience is not one of my strongest qualities so I picked up the Ritz diesel tachometer hoping that it would work & the only difference would be a lower redline.
I got the installation done in early 2017 from a accessories store, the brown wire from the EPS module was the correct wire for RPM signal. But the RPMs displaced by the tachometer were absurd, it used to show idling RPM around 2000 RPM & a slight tap on the accelerator pedal would mean the tachometer needle would be near the redline.
So, now that I am a member here & I can interact with you guys, I would like to try to do a proper installation. Should I order a petrol Ritz tachometer? Will it work properly or the RPM signal that my old EPS module sends can't be read by the new Ritz tachometer? My knowledge of electrical/ electronics is negligible.
The EPS module
The famous brown wire
The Ritz diesel tachometer ![DIY: Tachometer Installation for WagonR & A-Star LXi-diesel-tacho.jpg](https://www.team-bhp.com/forum/attachments/diy-do-yourself/1713093d1689873803t-diy-tachometer-installation-wagonr-star-lxi-diesel-tacho.jpg)
