Old 13th September 2016, 12:27   #1
aayushnair's Avatar
Thanked: 454 Times
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled
Part 1: Cruise Control
This post is dedicated to Gannu (TeamBHP) & Ciclo (UKPolos.net - http://www.uk-polos.net/viewtopic.ph...65431&start=15) as without the help of these 2 individuals my cruise control retrofit would’ve only been a dream!
I’m not going to write much about this except that it is was an absolute delight to do this myself – did take a few hours but got it working all right!
The desire to actually have a CC system installed didn’t burn until the stalks I had ordered to give me the control of viewing more options on my Cluster arrived. It enabled the MFD but the left stalks had CC controls and they weren’t working, this I didn’t like – it was like having an ice-cream knowing you can’t eat the cone! This is when the whole research began and I came across the above posts.
Now since Gannu has already described in a lot of detail (and loads of efforts) the various parts required I’ll keep this to a minimum and let the pictures do the talking…
1. The wiring harness (mine didn’t come with the diode – added that easily and labeled all the wires to stop the confusion:
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_wireharness.jpg
2. The Airbag has to come off first before you can start installing the harness in the T41 Connector, here’s a pic of the airbag clip; you’ve got to lift the clip up and it then pops out – 2 such clips on the back of the wheel.
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_airbag-clip.jpg
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_airbag-hex.jpg
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_steering-wheel-adjust.jpg
3. Remove the stalks – since I had already installed the new ones previously I just removed them, stuck the slip ring with tape to ensure it doesn’t move from its position and here’s a pic of the T41 connector
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_t41.jpg
4. Once the harness is in place – reverse process to put back the steering wheel and airbag
5. Now the BCM comes off, here’s a pic of the 2 clips which hold the car wiring harness in place when attached to the BCM. Just ensure you copy the original coding of the car from VCDS for all channels (I took screenshots of all pages just to be good – this is required to ensure the new one is coded correctly)
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-ccbcm-clip.jpg
6. The original OEM BCM Low line (PQ 25)
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_bcm-oem.jpg
7. The new (ordered from Hungary) BCM PQ 25 – High line – the tricky part here was to insert the ends of the harness to the correct slots and then push the BCM back in to place – this was easier said than done! Took a while before it was snug into its place with the clip back on.
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_bcm_hl.jpg
8. Next lead a cable to the ECU – luckily I already had my amplifier power cable running from the engine bay into the car, used the same opening (OEM) and ran the single wire (insulated with heat shrink tube to add more protection right to the ECU)
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_ecm-open.jpg
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_ecu_slot.png
Once the ECU was back into its place – and everything was locked and loaded connected the battery and enabled the new BCM (it was in factory mode) and copied all the original codes and enabled Cruise Control. I was devastated when it didn’t work, as I had invested 3 straight hours into this and I couldn’t figure out what I had done wrong.
I took a scan of the car and it had given me an error saying Terminal 45 switch missing (now T45 is the switch to the CC on the stalk) – I just opened the dust cover of the steering wheel again and pushed the T41 connector together again and heard a click! Shoot I hadn’t put it together well the first time, and voila on my test drive CC was working perfectly!
... just another pic of the CC stalk:
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-cc_stalk.jpg
It has been fun ever since and I’m superbly grateful to Gannu and Ciclo – their guides have been of tremendous help!
Part 2: Enabling Remote Control
Now the new BCM unit (87M) along with supporting CC also supports remote control operations which are not available on my original unit the low line version (84A) – the alarm bells rang and I totally wanted this as it should honestly be a default feature on any car you buy (mine is the Mid-version; the Ambiente) and is definitely something which should’ve already been in an INR 7.2lac car.
Anyway – from my research what I found is that in the newer version of the Fabias (5J+ or 2009+) the BCM controlled the entire car electronics and there wasn’t a separate unit which is required (which is in the older 6Y versions -) So this assured me that the BCM + a remote is the only other thing I’d need to have this option available.
I had checked with Skoda the cost of replacement keys and they had quoted me a figure in the range of 12-15k for a set – now that’s as usual so it didn’t surprise me; but I was sure there is another way to do this.
So with more and more information now available on this I found that the version of the key required for my car is 3T0 837 202H (Hella 434 Mhz) – the versions change as per your car model so you’ve got to check this with the year of manufacture and chassis no.
All I did is buy this from aliexpress (it comes with the blade, the remote, transponder, battery and case fob) – you’ve also got to ensure the transponder version is ID48 for this car.
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-remote_key-1.jpg
The transponder - ID 48
Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled-remote_id48.jpeg
Once this had arrived it was fairly simple to configure the remote to the car (since I already had a transponder chip which I had coded previously from Ashar Keys in Dadar, Mumbai) It was a straight install.
To configure the remote – you’ll need VCDS and process is simple-
The remote was read in the first attempt and my car now also has a fully functional remote locking system (the boot function works too!)
I was super happy with this entire setup, I know now my car’s a manual transmission and I wont benefit too much from CC – but well when I’m on the highway it’s a blessing; just slot into 5th and cruise at the speed you want to – super relaxing!
Hope this helps!
Coming up next – New Suspensions and Monte Carlo headlights installed!
Cheers,
Aayush
Last edited by GTO : 13th September 2016 at 13:36. Reason: Spacing :). Thanks for sharing!
aayushnair is offline   (22) Thanks
Old 14th September 2016, 20:02   #2
Thanked: 634 Times
Re: Skoda Fabia: Cruise Control retrofit, with BCM upgrade & remote control enabled
Man! You must be as happy as having a new car. Neat job and it is made to sound so simple. People really are playing around with the electronics of vw group's cars as if they were one of their childhood toys. Don't you need to get the key blade duplicated?
crdi is offline   (1) Thanks
Old 14th September 2016, 22:18   #3
aayushnair's Avatar
Thanked: 454 Times
Hey totally, it's really a boon being able to mod your car yourself like this. Yeah needed it duplicated, that too was done at Ashar keys. A 10minute Job. The keys came with a blank blade HAA type to match the size of my original keys. Worked like a charm!
Old 15th September 2016, 22:20   #4
Thanked: 74 Times
I did a double take when I saw this article as I wasn't aware it was possible to install such a complicated feature. Congratulations Sir and hope you have many miles of safe cruising. Now i'm inspired to do a steering mod on my car which I have been contemplating for a while.
medicineman1987 is offline   (1) Thanks
Old 16th September 2016, 11:58   #5
Thanked: 154 Times
Need some courage to take on the VW group and do DIYs like this, who anyways refuse a warranty claim at the drop of a hat
rohin4110 is offline   (1) Thanks
Old 16th September 2016, 18:45   #6
Thanked: 504 Times
Awesome. Off late, I am having a hard time in believing the nature of threads in T-BHP. Someone is installing cruise-control on their car, as if its an app, and someone is writing about driving to Leh from Bangalore, while other adventurers are traveling to Uganda and Congo! Way to go guys. Brilliant.
bsdbsd is online now   (1) Thanks
Old 16th September 2016, 18:50   #7
Sahil's Avatar
Thanked: 7,999 Times
I applaud your DIY skills but IMO thats a lot of effort, time and cost spent on probably one of the more useless features - Cruise Control
Sahil is offline
Old 16th September 2016, 20:28   #8
aayushnair's Avatar
Thanked: 454 Times
Thanks a lot guys!
So my warranty expired in 2015, and most of these mods started post that! Now I even service the car myself (read my self!)
Yeah it's a lot of effort for sure, but it's like boys and their toys if you know what I mean! Can't get enough of it!
With reference to costs- it really wasn't much, overall less than 12k.
But I enjoy every penny of it knowing I did this!
Old 17th September 2016, 14:58   #9
Thanked: 634 Times
True that, but the information about the remote key install will be pretty useful as most of the lower variants of vw cars up to the vento have keys without a remote. People of tier-ll/lll cities and rural areas can benefit very much from such information as they usually don't have easy access to the services of a specialist. Even if one doesn't straightaway jump into a DIY or a professional installation, he or she will be happy to know that such possibilities exist.
crdi is offline   (2) Thanks
Old 17th September 2016, 15:19   #10
Thanked: 3,201 Times
Great job
Sahil cruise control is a useful feature when you have to drive long distances at a stretch, you can have give the right leg a break and cruise when you find a relatively traffic less stretch.
Moreover its always good to have a feature and not need it than to need it and not have one
Karthik Chandra is offline   (1) Thanks
Old 30th March 2020, 09:58   #11
Cheers,
Aayush
Hi Aayush,
Just a quick question, how did you identify FCC ID for your new BCM. Your new BCM was from Hungry so won't it be FCC ID from some Hungarian cars. I have skoda fabia 2012 mid ver model with same old BCM 84A without remote. Got another used BCM from Germany 86H but can't sync any aftermarket remote. VCDS shows "NA".
Looks like I'm missing correct FCC ID keys. If you can assist me to identify FCC ID for my car.
vranjan21 is offline
Old 30th March 2020, 10:58   #12
Hi Aayush,
Last edited by Gannu_1 : 30th March 2020 at 11:40. Reason: Trimming quoted post. Please avoid quoting a large post as it inconveniences small screen users. Thanks.
Old 30th March 2020, 19:29   #13
aayushnair's Avatar
Thanked: 454 Times
Originally Posted by vranjan21 View Post
Hi Aayush,
Hi Vranjan21,
I really didn't look at the FCC ID, instead focused on the part no.
I had to source keys with the following part no. 3T0837202H at 434MHz using an ID48 transponder. Any other part no. has a different remote control ID and will not work.
Here's a link to the latest key format I've upgraded to: a Skoda Octavia's (2018) - https://www.aliexpress.com/item/3283...27424c4dmKgQjZ
Another thing to check is the entire part no. of the BCM unit you've procured to understand which key is the right one - I really dont recall the link where I got this information from (will update in case I find the one, but what I do recall is I had to check compatibility of the key using the '87M' right at the end of the BCM no.
Aayush
aayushnair is offline   (1) Thanks
Old 31st March 2020, 04:29   #14
Thank you Aayush, your little hint is also good enough to continue my search. Please don't forget to post back in case you able to recall the link. Smile.
vranjan21 is offline   (1) Thanks
Old 31st March 2020, 11:06   #15
aayushnair's Avatar
Thanked: 454 Times
Just found a little more on this on this very own forum by Gannu. - https://www.team-bhp.com/forum/diy-d...ol-module.html (VW Polo DIY: Upgrading the BCM (Body Control Module))
I've referred to his research as well and he's mentioned on his thread about compatibility of remotes. Your remote with the 86H at the end should work with 434Mhz Freq.
Please share:
1. Remotes part no.
2. Have you transferred all coding from your original BCM to the new one by removing all previous coding or did it come blanked out?
Thanks,
Aayush
aayushnair is offline   (2) Thanks
