My daily drive is a
2007 Honda Odyssey (model code : RB1) which I bought pre-owned, in March 2015. It was a single owner car which had done around 98,000 km and after 15 months with me, the odo now stands at
1,18,000 km. My daily commute is around 80 km.
Although it does not get uncomfortably hot where I live, it is generally humid, rains quite often and winters are really cold. All these, combined with the fact that I am a bit uptight when it comes to the interiors getting dirty, means that I drive with the air-con / heater ON 95% of the time.
Compared to what it is back home in Kochi, the dust and
visible pollution levels are negligible here. I still prefer using the A/C in recirculation mode. I had decided to replace the cabin filter and wiper blades in both our cars just after Spring every year (wifey drives a pre-owned
2013 Swift CVT).
All OEMs in Japan sell parts over the counter. May be, they are legally obliged to. All you need is your vehicle registration certificate (and ¥) so that they can enter the VIN in their system and get you the correct part from storage. I went to the neighbourhood Honda dealer and bought a cabin filter, along with a few other bits like oil filter, engine air cleaner element etc (since I service the cars on my own in the evenings, using one of the lifts in the office garage). At the equivalent of INR 2000, it was a bit costlier than I expected.
Step 1: Open the glovebox lid
Step 2: Pull down the lid completely pressing the tabs (circled in red)
Step 3: Press the tabs on the filter housing to open the cover
Step 4: Pull out the filter housing till it comes off completely
The (not-so) dirty filter
Step 5: Remove the filter from the housing by pushing it upwards.
Note the direction of airflow printed on the element and the housing.
Step 6: Open new filter and performs Steps 1 to 5 in reverse to fix it.
Look back at your smiling car and walk away.
Notes:
① I know that a good cleaning of the old filter might have sufficed. But my kids are still small (4 year old and 3 month old) and I am paranoid when it comes to the chance of them picking up allergies etc.
② It took me around 5 minutes during lunch break for this DIY. But if you suffer from OCD as I do, you will spend another 20 minutes cleaning the surrounding areas.
③ This part
80292-SLJ-003 Element, Filter is common across several Honda models (Accord, Civic, CRX, CR-Z, Legend, Step Wgn etc) and I believe the replacement method should be similar if not the same.
Thanks for reading!
