Originally Posted by rosh_aveo1.4 Hey. That looks brilliant. I tried the same thing but used a battery operated unit instead which goes to sleep once disconnected and another one unit in my Civic that uses a small wire. And yes, never liked the wire hanging in the dashboard as you said.
I basically use it for music streaming and not for calls since I'm not comfortable driving and speaking on a phone. But I still haven't solved the NFC tag issue i.e how to go about automatically calling a radio application like Ganna or Saavn (rarely use the music stored in my SD card). I know I can launch an application using NFC but I still haven't figured out how to select a particlar folder or favourite or radio station. The phone music player app works fine with controls and all but not a third party radio app as far as I know.
And how we're you able to toggle the location settings in your phone though Tasker? Was it rooted? I think that was what the Xposed framework modules does? |
Thank you. Let me try to answer your questions as best as I can. Regarding type of Bluetooth unit, I avoided a battery powered unit because then the unit does not switch on and off with the car. This was essential for my setup as the connect and disconnect are triggers that I wanted to use for automating my in car audio. Battery powered units may have auto sleep function, but this would mean even when I switched off the car, my phone would continue to be connected to BT till I walked away out of it's range. Since I use a special Car Mode with a totally different layout, it disables my lockscreen, replaces apps and icons, announces all notifications via speaker.... I didn't want that to happen. Also, everytime I sat back in the car, I'd have to manually turn it on. Plus, there's the hassle of periodically charging it, because you can't leave it connected to charger forever and battery is bound to die sometime. I wanted something that was a one time setup and then I could just forget it forever. Sort of like the "Fill it. Shut it. Forget it." Hero Honda philosophy. That is what I have managed to achieve.
I had also explored two other options and wasted money on them. One was an all in one USB Bluetooth device which streamed music from the phone over Bluetooth directly to the USB and the music system thought it was reading a pen drive. The second one was the type that plugs into the USB and a short cable connects it to the AUX input. Both these sound good in theory but the music streaming quality was not up to my standards, the devices didn't auto pair, randomly disconnected, the mic was tinny, call quality through BT was bad. And the worst thing was that I still had to use my phone to change songs and operate calls etc. So I kept looking and finally ended up with the current setup.
Regarding the phone side of the automation process: Yes, I'm rooted. Xposed framework is not necessary for the core functionality I have described, but it's essential in changing NFC listening state form only when phone is unlocked to even when screen is locked. This saves me the step of unlocking the phone when putting it into the car cradle. I can just pop it in there casually and all the magic happens on it's own. The main apps are Trigger, Tasker and a Tasker plug-in app called Secure Settings. The last one is a powerhouse and allows access to countless hidden options and features, including the elusive Car Mode, that Samsung has hidden away, only to be triggered when you use the super expensive Samsung proprietary car dock. I can access all these using secure settings, but only with root.
Originally Posted by blahman Awesome DIY buddy.. Why don't you try this app called AutoMate instead of using the car mode function? AutoMate is still a Beta buy it looks exactly like the AndriodAuto interface.. There are a few bugs but I haven't faced any major annoyances.. Here's the link to download it from: https://plus.google.com/communities/...88212710276577 |
Thank you. I have actually tried automate and am a beta tester for the app. It has great potential, the design is beautiful, and I'm sure it'll be great one day after it exits beta. But currently, the core functionality is still not mature enough to meet my needs or standards. After trying out practically every single Car Home app on the play store, it is my opinion that the current best is "Car Dashdroid". It does everything I want, and the best thing is that the developer is very responsive. I e-mailed him two feature requests and within a week, he added them to the app!
Originally Posted by su1978 Great mate. This is really awsome. Initially i was contemplating the idea of changing the HU on both my cars to have this feature. But now i think i will buy this unit. Few queries that are ringing in my mind are
1. You mentioned that the music fades away and the name of caller gets displayed. Does the display happen on the HU of music system or on the phone
2. Is there a possibility to connect the 3.5mm audio jack from behind the music system.
3. Is there any way we could have the steering mounted controls for answering/rejecting calls. |
Thank you.
1. What I meant is that it's displayed on the phone screen. There is no way to display info like that on car system screen via just an AUX cable.
2. I'm glad you asked. Because I want to know this too. That would be even cooler. All wires would disappear! But I'm not very good with car head units and need guidance from some DIY guru to accomplish this task.
3. There are steering mounted units available. Blaupunkt makes one. But the ones I know are battery operated and need a special head unit to work (you can't run an AUX cable from the steering wheel to the music system, right?!). Another variety has built in speaker, but it is too tinny for my liking, and the unit is for calls only, won't connect to the head unit. To the best of my knowledge, unless you DIY a contraption, there's no commercially available unit that is compatible with this setup.
Hope this helps.
