I had recently swapped the radio whip antenna on my Polo to an OEM sharkfin antenna.
The process was fairly simple and took barely 10 minutes. I thought I’d quickly pen down a DIY-guide on how to replace the stock antenna without splicing or trimming any wires which may invalidate the warranty of the car. Unfortunately guys, I failed to click snaps during the process in the hurry and excitement that ensued. Really sorry about that but fret not, I have detailed it as much as I can using some reference images from Google and other sources.
Disclaimer: Please note that if you choose to attempt this DIY, you are doing so at your own risk and I shall not be held responsible for any loss (of warranty or otherwise) or damage incurred as a result of this procedure!
If you recall, the first gen. Polo (and the Vento) had a long radio aerial like this one:
(Image courtesy: Polo - Team BHP Review)
The more recent versions came with a stubby whip antenna like this one:
The Jetta comes with a glossy sharkfin antenna like this one:
(Image courtesy: Jetta - Team BHP Review)
Without any iota of doubt, a sharkfin aerial looks much better than a long piece of plastic protruding out of the car. Most car manufacturers however provide one only on the top-end cars on their list and not the entry level variants probably owing to the exclusivity and the
marginally higher cost of the sharkfin aerial (although the difference is negligible compared to the total cost of the car).
Parts Required:
If you do a search for the sharkfin aerial by the VAG part numbers, there are several variants of the sharkfin aerial available for the VW/Skoda cars. The part number belongs to the
1K0 035 507 _ series where the dash denotes an alphabet. Enter an alphabet there and you have a different type of aerial! Heck, there's even a dummy aerial without any cable (part number: 1K0 035 507 D,
reference image). So which one should we choose for the Indian spec'd Polo/Vento for replacing the stock radio aerial?
This one:
The part number of this aerial is:
1K0 035 507 J as indicated in the sticker. But hold on, you are going to need another part. The replacement FAKRA connector that bears the part number
6Q0 035 575 K. Why this connector you may ask? Without this FAKRA connector, you are going to need to splice/cut the wires because the FAKRA connector (purple) that comes with the sharkfin antenna will not properly mate with the FAKRA jack that came with your car. So these are the only two parts you would need to replace the whip antenna on your car. The total cost was roughly about Rs. 6000 but please note that shipping charges aren’t included in this price.
As luck would have it, one of my friends was posted in the US as a part of his on-site work and he was willing to bring down some stuff so long as it wouldn’t attract customs duties and the items are small so he could squeeze it inside his luggage. I logged into
ECS Tuning (a website that deals with Audi/VW aftermarket and tuning parts) and started my search. Quickly created an account there and when the website prompted me to enter my car but I couldn’t find a Polo there! Why? Because of this:
The Polo doesn't retail there! (But it looks like US may be getting one in the future -
link) And so I entered the Volkswagen Jetta V TDI (remember the gamble part I had mentioned before?!) and when I searched for the antenna, it came up with the results and there was one which matched my requirements and the note mentioned
‘Kit includes connector to replace your whip antenna.’
So that seemed more like it. I bit the deal and bought one. Since it was the Christmas weekend, they had sent me an intimation that shipping would take a couple of days more. When the store re-opened, they shipped it by road using FedEx and it reached my friend at Colorado on the 4th day. He sent me a few images. I couldn't wait to receive them in my hands!
Here's the link from ECS Tuning -
ES#12179 Tools required:
1. A prying tool:
Ideally a plastic prying tool (like the one shown above) is required so as to not leave any marks or scuffs while removing the panels and trims. Otherwise a fine knife and some masking tape over it would do the job.
2. A 24-27 mm double-ended spanner/wrench OR an adjustable spanner.
An adjustable spanner will help in the future too in case you are buying one specifically for this job. Please note that
a box spanner or a ring spanner may not work if the cable from the aerial is routed through the nut. Taparia is a well-known brand for hand tools in India. The quality is top notch and the pricing is reasonable. Just a headsup in case you are in the market to buy one!
Steps:
Before beginning the work, it would be advisable to fold the rear seat (push the front seats ahead and then fold the rear seat-back) so it is easier to work and access the panels/trims. One can easily sit on the folded rear seat without dirtying the upholstery. It is not necessary to remove the parcel tray however. Let’s get to work!
1. Removing the headliner trim:
Gently insert the tool into the gap and remove the headliner trim. This part:
Removing the headliner trim exposes the headliner end and you can actually poke your hand through the gap between the roof of the car and the headliner but this gap isn’t sufficient to unscrew the antenna base. Thus, one of the C-pillar trims need to be dismantled.
2. Dismantling (NOT removing!) one of the C-pillar trims:
The headliner need not be removed completely! Pry open the C-pillar trim by inserting the tool into the gap:
The clips will come off with a ‘click’ sound - do not worry; they will not break easily.
Now pull the headliner down:
NOTE: Pulling the headliner down will cause some crease to appear along the headliner at the corner of the C-pillar area. DO NOT WORRY, this crease is not permanent and will smoothen itself out within minutes of releasing the headliner.
3. Disconnect the FAKRA connector from the jack.
The connector would be secured in place using a plastic U-clamp. Pull the connector off this clamp and disconnect the connector from the jack.
4. Remove the stock antenna base from the roof:
Now that the headliner can be lowered, the nut holding the antenna base is accessible:
Unscrew this nut using the spanner. Just a bit of force for the initial part and the nut can be loosened by hand. Once the nut is off, pull the antenna from the top of the roof:
5. Replace the FAKRA connector on the sharkfin aerial:
The FAKRA connector (purple) provided on the sharkfin aerial will not mate properly with the FAKRA jack (purple-white) that came with the car. But that’s alright since the spare FAKRA connector (green) should resolve this issue.
Insert a blade into the tab of the FAKRA connector (purple) and pull it off. The cable should now come off freely:
Now insert the cable into the spare FAKRA connector (green) and replace the tab. It would lock with a ‘click’ sound.
6. Clean the aerial hole from dirt, dust and other debris.
You would notice that the region surrounding the hole has accumulated dust and other particles. Use a soft microfiber cloth and clean it. Use a damp cloth to wipe the region for any marks. Let it dry.
For those among the detailing-freaks, you may wax this area before inserting the sharkfin aerial.
7. Installing the sharkfin aerial:
Insert the sharkfin aerial into the square slot:
Tighten the nut from inside using the spanner. The aerial should firmly sit on the roof without any movement.
8. Plug the connector with the jack:
Having replaced the FAKRA connector, it should now mate with the jack properly. Connect it and let it lock with a ‘click’ sound. Secure the connector back in the U-tab.
9. Replace and lock the trims into place:
Lock the C-pillar trim and the headliner trims by snapping them back into place.
We are done! Test the reception by enabling the radio.
Please note that many e-commerce sites such as Ali Express and eBay retails similar antennae which are cheaper but without a proper FAKRA connector. Such as this one:
The connector indicated on this one will not mate with the FAKRA jack in the car. Moreover, the O-ring gasket at the bottom of the antenna may not be of good quality and may wear out soon compared to the OEM antenna. This will cause water to seep through the hole and spoil the headliner.
References for images:
1.
Golf Mk V Forums
2.
VW Vortex Forums
3.
Generation Dub Forums
4.
VW US Update on 22 September 2015: Some of the members had reported poor radio reception after swapping the stock aerial with the sharkfin aerial sold from ECS Tuning. Please be aware of this before attempting the swap. Thanks!
