Here's a quick one to change a gear knob on a fiesta.
The thing is, the fiesta has a knob with a thread running underneath through which you pull a snap tie, and this holds up the gaiter.
Same in the beat, I think.
So you basically pull the gaiter down over the knob, and then the snaptie holds it on the knob.
The knob I had was this, and for a year it had been lying around, and I had not been able to figure out a way to put it up, and keep the gaiter/surround up as well.
Then I managed to break an LED bulb today and found a perfect solution, that
fit snugly on the stick.
The highlighted bit:
So here we go.
The gaiter doesnt come off by itself.
A section of the console comes off too.
here's how:
With the whole bit pulled up over the knob, youll see the snap tie.
Undo/cut this, and the gaiter can be pulled down.
Then rotate and remove the knob.
Now the jugaad bit.
The ford knob extends quite a ways, while the Momo ended a bit early.
The exposed steel shaft was looking, well, exposed.
So I pulled down a bit a of thick ribber tubing, and cut it off to cover the exposed bit.
The LED bulb bit was attached then to the bottom with Mseal (my trusted friend...
This bit from the bulb is what will hold the gaiter's snaptie.
Voila!!!
It grew dark, so the pics aint coming out well.
Plus there is a bit of finishing still to be done.
I'll see if this looks fine after sanding and polishing.
If not, then Ill get a a new gaiter made.
Any Cobbler will make it.
Its very easy to change.
Go-fast gearknob done!!
