Whether you consider it as fortunate sound bug or an unfortunate setback in financial terms, OEM touch screen in my Verna failed, could it be due to excessive heat in Delhi?
Since I’m using Android Auto in my other car wanted to upgrade in Verna as well. I have always used Pioneer touch screen in all my cars and was looking at Pioneer 6350BT, it was bit expensive so decided to go for Sony XAV-AX6000 this time.
Called up Chandu to fix time for a weekend, reached around 12 PM and the work started. I have used Rainbow Sound Line previously for those who know and have heard them would appreciate the SQ they bring to the table. The rear duty was carried by Rainbow co-axial either Experience Line or Dream Line. But back of my mind I wanted to hear out the Audison Voce before going ahead with Rainbow this time.
Chandu got his boys to setup Rainbow Sound Line Pro on one side and Audison Voce on the other side, after hearing for less than a minute it was clear choice for the Voce. Since these are on the pricier side went for a lower division Audison C2 series components for the back. After hearing 2 sets of components in Glanza I don’t think I can go back to rear co-axial setup as it sounds muted in front of components. Others might feel there is drilling of the door pads for installation of twitters but if you favor sound over other things it’s a non compromise to get 2 pairs of components. I already had a Flux 4 channel amplifier to run the new components.
Since it is peak summers in Delhi and temperatures are reaching 50 degrees, could not bear standing next to the car during complete installation hence took no pictures of the install in action.
Equipment list
- Sony XAV-AX6000
- Audison Voce
- Audsion C2
- Sundown Audio SFB-1000D
- Rainbow GL-S12
Old OEM head unit
Pictures of new products Sony XAV-AX6000 Day view
Night view
The aftermarket frames leave a lot to be desired in terms of quality, it is not snugly fit and has slight gaps on all sides. The team had difficulty in getting it fixed as well. Screen is a dust magnet and gets finger print smudges easily, difficult to keep it clean.
Audison Voce
These sound very clean just the way I like it, much better than all components that I have previously owned.
Audsion C2
These go well with the Voce although I have kept fader balance more to the front.
An issue I faced using Apple Car Play on the Sony XAV-AX6000 was during a call it would automatically go on hold, it would also go on hold if I touched the screen or increase/decrease volume from steering controls. I did not face any such issues while regularly using Android Auto. So I went ahead and downloaded the latest software patch from Sony’s website and updated the head unit. I have not faced the Apple Car Play issue again but still keeping it on check.
Also the Apple Car Play has slight lag when you press anything which is not there again in Android Auto.
The OEM camera would not turn on all the time when put in reverse, Chandu’s team advised me to go for new camera since older one would pixelate, I retained it to see how bad the issue is. I will go ahead with an aftermarket reverse camera, preferably in stock location next time.
This Sony unit also supports HDMI, I have an Amazon Fire Stick lying around whose remote stopped working, will try to get it installed and working next time around. After watching YouTube videos to enable HDMI I have procured a Micro HDMI to HDMI adapter, will power the Fire Stick via 12 volt car charger.
The head unit only supports type C port, hence if you use USB to listen to songs you will have to purchase a type C pen drive or a type C to A converter.
