Team-BHP > Team-BHP Directory > Delhi NCR
Old 27th June 2018, 18:26   #1
Thanked: 1,160 Times
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)
I had earlier posted about a Tata Authorised Service Centre - Narain Singh and Sons in the forum. Mandeep, the owner's son and the de-facto manager of the concern was a BHPian himself. A keen auto enthusiast, his love for cars and knowledge showed in the professionalism with which the outfit was run. I had a pleasant experience in my every visit, and owing to their professional attitude, and an honest approach, my Manza was always in top shape.
The workshop has now been closed for reasons unknown and the space has been sub let to Chevrolet to run their A$$. This came as a jolt to me when I read about it, for it was because of this particular workshop and their positive , problem solving attitude that I was assured of good health of Manza.
The car had had its 90K Service nearly a year back and it was due for a 100K Service. Now this was a major exercise, because as per the user manual, a whole lot of things were to be inspected, repaired and replaced as part of preventive maintenance. Having gotten used to Narain Singh & Sons' diligence, I just did not want to entrust anyone else with these tasks. In addition, at about 98K km, while on the way to Moradabad, the car had turned sluggish and stopped accelerating. I had taken it to the TASS there
(Shree Balaji Autowheels) and while the chief mechanic, after a test drive had accurately diagnosed the cause to be clogged Air Mass Sensor, and went on to clean it with Throttle Cleaning Spray, he still insisted that the OBD be hooked up and checked for any errors. My experience in Narain Singh & Sons with OBD hookup had always been pleasant, as they routinely used to do it for most cars as a precautionary measure. I was taken aback when I was informed that it'll cost Rs 1000/- . Additionally, he went on to say that if this doesn't solve the problem, then maybe the turbocharger will have to be replaced. I was surprised, because I for one am very cautious about idling the turbocharger for a minimum of 30 seconds before and after a drive. Not convinced , I called up Mr Hardeep, the owner of Narain Singh and Sons and he said that turbo failure is not common, and even rarer on the Quadrajet 90 engines. Eventually, it turned out to be just a clogged Air Mass Sensor which was cleaned with a bit of Throttle Cleaning spray and I was give a Rs 1800/- bill for the whole exercise. While I am thankful for Shree Balajee Autowheels working on the car and correcting the issue, I still didn't like their fleecing attitude - what with OBD charges, and the ominous talk of replacing the turbo (which would've set me back by a cool Rs 45K + labour + taxes) .
This scare only firmed my resolve that the 100K service, which would involve a fair bit of checks, inspections, fluids replacements and elbow grease would be done by someone competent and trustworthy. With that in mind I sought out Vijay's phone #. It was a relief to know that he was still in Delhi and working independently not far from the erstwhile location of Narain Singh and Sons. The good news was that he, along with three other reliable mechanics from Narain Singh and Sons had started working together not far from where the workshop was located. The other three were 'Pandit' (Virender Kashyap), Dinesh and Ayub, who is a trained electrician. Of the four, Vijay is the most experienced and qualified, having been trained in Tata Motors, Pune. He was the chief technical expert at Narain Singh and Sons and every year they sent him to Tata Motors, Pune for refresher training and to learn about new releases and their maintenance / repair.
The four work as a team, and usually have their hands full . While 'Pandit' is a skilled mechanic, Dinesh is their facilitator. He sources all spares and expendables (oils, greases, fluids etc) from a nearby TA$$. Ayub is a skilled electrician and works on all things electric.
Products/ Services Offered:
  • Routine Service
  • Specific Mechanical problems
  • Accidental repair - mechanical. For denting painting, one might have to look elsewhere, though not too far. The workshop next to them specialises in it.
  • Even TMI Insurance Renewal, through an agent (As claimed by 'Pandit')
What I like:
  • Attentiveness & eye for detail- they have the patience to hear you out and the work you need done.
  • Honest advice - if the car doesn't need a particular repair/ service/ part replacement, will not try to palm it off on you just to make a fast buck.
  • Well trained with updated knowledge on the latest product lineup - have worked on Tiago, Tigor, Nexon, Hexa in addition to the Indica, Indigo, Vista, Manza, Bolt, Nano, Safari, Storme, Aria and Zest.
  • Courteous though businesslike. Will explain cause of the problem and what will be done on the car to remedy it.
  • They source OEM parts and expendables from TA$$ at reasonable costs.
  • Can work on Fiats, and anything with a Fiat 1.3 Multijet or SAFIRE.
  • Have a captive heavy duty lift and Air Impact Nut Torque Wrench from the workshop whose premises they use for work.
  • Pressure wash facility is available.
What I Don't Like:
  • The approach road is congested and not easy to locate.Finding the workshop may be difficult for some as it is a little off the main road.
  • The work is done in the open, so if you are keen to see the work being done, you may have to brave the elements.
  • The fact that they have to share the lift means they sometime may not get it when they need it, and may have to wait for their turn. Incidentally, the workshop owner bought this heavy duty lift second hand from Narain Singh and Sons, apparently for a pittance.
  • If you want any specific thing to be changed, Dinesh has to source it from a nearby Tata A$$. This takes time. Better to show him the car, decide what needs replacement and buy things in one go from the Tata A$$.
Small Yet Significant Points
  • Amenities of a modern workshop.
  • You can go and see the service/ repair being carried out on your vehicle - a big plus for me.
  • Costs - this is a huge plus. They are lower than par. For the expertise and experience they have, and the accuracy with which they diagnose and rectify a fault, I feel they can afford to charge more, and satisfied customers will happily pay.
  • Work on Sundays too. Wednesdays off.
  • All spares, fluids, oils are sourced from TA$$, so one is assured of genuine articles being used. The downside is that these are taken from bulk storage drums, so one has to take his own clean containers for getting them back to the site of repair (Jahangirpuri Industrial Area). Anything leftover is handed back to owner for top ups later.
All things that were done :
  • Engine Oil and Filter changed
  • Fuel Filter Changed
  • Coolant drained, cooling system cleaned with pressurised water, dried out using compressed air and refilled with genuine Tata Coolant.
  • Brakes bled and refilled with correct grade Brake Fluid.
  • Power Steering Fluid drained and refilled with prescribed power steering fluid.
  • Gear (Transaxle) Oil drained and filled with correct grade oil.
  • Suspension checked and a bush replaced.
  • Engine Guard Plate, dismounted to replace Gear Oil, inspected, straightened and remounted.
  • Exterior Wash.
All this took about four hours. The heavy duty lift and Pneumatic Nut Torque Wrench helped. The overall charges were way lower than what I would've paid in a A$$ Workshop. All in all it was a pleasant experience. Those who want their car looked after well and are finicky about genuine spares and can spare the time, Vijay is one of the more knowledgeable, experienced and professionally trained mechanics specializing in Tata Cars in Delhi.
Address/ Directions
Google Maps Link : https://goo.gl/maps/NGSEsbf6ba42
Address - Sanjay Motors (the workshop whose lift they use) Unnamed Road
Block E, SMA Industrial Area, Jahangir Puri, GT Karnal Road, Delhi 110033
Coming from Delhi and moving north towards Karnal, cross Jahangirpuri Metro Station, enter the industrial area from an arterial road opposite Metro Pillar No 136 and 200 metres ahead you have the erstwhile Narain Singh and Sons/ now Chevrolet Workshop on your left. Turn left and move to the end of the road to a T Junction. Sanjay Motors is on the right, opposite an iron foundry.
Contact Information
Name of Person - Vijay
Contact Nos :
+918010790951 (Whatsapp/ voice call)
+917531053323
Name of Person - Dinesh (facilitator - main person to arrange for all genuine spares, oils and fluids)
Contact No :
+919811794697
One can Whatsapp Vijay on the work required to be done and things to be changed in advance so that the spares, oils and fluids can be sourced before hand.
Cheers !
Vijay Working on Bleeding the Brake Fluid
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)-brake-bleed-vijay.jpg
The Steering Fluid Being Drained
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)-drain-sterering-fluid.jpg
'Pandit' Working on the gearbox of another Manza
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)-pandit-gearbox.jpg
The Heavy Duty Lift
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)-sanjay-motors-lift.jpg
Vijay Working to Bleed the Brakes
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)-vijay-brake-bleed.jpg
Vijay Re-mounting the engine plate after having straightened it out
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)-vijay-engine-plate.jpg
Vijay Working on a Noisy Gearbox of another Manza
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)-vijay-gearbox.jpg
Vijay checking the Suspension of the Manza
Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)-vijay-suspension.jpg
Ironhide is offline   (7) Thanks
Old 9th July 2018, 09:44   #2
panky12345's Avatar
Thanked: 172 Times
Re: Friendly Neighbourhood Garage & Tata Specialist - Vijay & Pandit (Delhi)
Do they service just TATA or other vehicles as well?
panky12345 is offline   (1) Thanks
Old 9th July 2018, 16:46   #3
They can work on all petrol and diesel vehicles and specialise in anything with a Fiat MJD/ SAFIRE. Here is a broad list of vehicles that they can repair / have serviced in the past :-
Tata
  • Hexa
  • Storme
  • Aria
  • Safari
  • Zest
  • Bolt
  • Manza
  • Nexon
  • Tigor
  • Tiago
  • Indigo
  • Indica
  • Nano
  • Sumo
  • Sumo Grande / Movus
Fiat
  • Palio
  • Linea
  • Punto
Maruti
  • Swift
  • Dzire
  • SX-4
  • Ciaz
  • Ertiga
  • Alto
  • Celerio
  • Ignis
  • Baleno
Toyota
  • Innova
  • Etios
  • Liva
They insist on procuring and installing genuine spares and expendables from the A$$ nearby, and that takes time, so you might like to keep that in mind. Or else, call them before hand, speak about what definitely needs to be replaced and they can arrange for that well in time.
In addition, Ayub, in addition to being a competent electrician is also a trained AC Mechanic. So those who want to have their Tata ACs diagnosed may approach them.
Cheers !
Ironhide is offline   (1) Thanks
Old 25th June 2021, 16:01   #4
coldice4u's Avatar
Thanked: 1,143 Times
Does anyone know if these folks are still working ? I tried calling the numbers but none of them are working. I needed a good reliable place for my Tata Bolt. Tata service atleast for the ASS leaves a bit desired.
Any recommendations for old gen Tata cars in NCR. My Revotorq is getting quite clattery at even very low highway speeds !
coldice4u is offline   (1) Thanks
Old 25th June 2021, 16:31   #5
He has started working with a cousin of Mandeep. They've a multi brand workshop in Badli. Others are there too.
These are Vijay's last known numbers :-
+91 80107 90951
+91 75310 53323
If that doesn't work then the proprietor of the workshop , Hunny, may be reached at +91 98712 02580 .
Vijay is one competent mechanic and he shall be more than happy to look at the niggles of the Bolt. Hope this helps.
Cheers !
Ironhide is offline   (2) Thanks
Old 28th September 2021, 17:58   #6
coldice4u's Avatar
I finally managed to move my lazy bum and visit the place. My Bolt petrol has crossed 62k and is more than 6 years old now and a change of the timing belt was on my mind as we have been planning for a 1500 km trip in the upcoming months.
I got the timing belt from Boodmo and visited the place. Vijay was available and he promptly took it up. Also discovered a leaking water pump which had led to a loss of coolant. Dinesh & Vijay managed to source an aftermarket water pump and got the same replaced with the timing belt. Also asked to check on the tappet clearances. Entire job took about 5 hours including a lunch break of 30 mins.
Slightly miffed that they charged me OEM price for an aftermarket pump. But Vijay is a chap with thorough experience on last gen Tata cars including Nexon. I think the labour charged was a bit above expectation, or may be i was expecting too much !
coldice4u is offline   (2) Thanks
Old 3rd October 2021, 19:20   #7
Vijay is a highly trained Tata mechanic. While he was the Head Mechanic with Tata/ Narain Singh and Sons, he used to regularly attend the upgrade courses with them in Pune / Lucknow every year - sometimes twice a year, and then train the remaining workshop staff. I've seen his approach to problems and realised that he's somewhat of a perfectionist - getting behind the problem till it is resolved satisfactorily. I'd surmise that for all Tata products (and all Fiat Multijet iterations - anything from 1.1 to 2.0 L) he would be the best trained and technically competent FNG Mech in NCR area.
Labour may be a tad on the higher side, but with him, at least there's a satisfaction that he's got years of experience and he'll do what the OEM recommends.
Cheers !
Old 21st May 2022, 16:45   #8
coldice4u's Avatar
Completed my annual service at the place again. It was a pleasure meeting the guys and getting the car worked on. The window winder for both the rear doors failed on my Bolt and got them replaced at a fraction of the cost. Fortunately was able to procure aftermarket parts for the same and seems to be working just fine.
Next up would be a suspension bush,tie rod, ball bearing & link rod change in the next service.
Old 16th October 2022, 23:19   #9
Here's a heads up about the latest contact details for the workshop they together work at. It's called Singh Motors and the address is
Khasra No. 26/6/1
Near Primary School,
Badli, Delhi-110042
Their latest contact numbers are
9811994697
9582587497
8010790951
Cheers !
Ironhide is offline
