Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | 68,496 views |
29th June 2023, 15:30 | #91 | |
BHPian Join Date: Nov 2018 Location: Hyderabad
Thanked: 2,801 Times
| Re: OceanGate submersible Titan goes missing while visiting the Titanic. EDIT: Wreckage located Quote:
In the bicycle industry no manufacturer offers a warranty for a carbon fibre frame, however warranties are offered for metal frames. This is because a carbon fibre based bicycle is known to suffer from sudden and unforeseen cracking and shattering during usage. So counting each dive as a test would make no sense unless the company decided to ultrasound test the entire submarine post each dive. That would be too slow and too costly. But that is probably the only way they could prevent such a failure. Instead they went for a jugaad scheme. They had some sort of sensors rigged across the vessel to measure buckling/cracking. But these sensors make sense on a metal vessel with a predictable fatigue rate, whats the point on a vessal which could crack and shatter like glass? | |
(14) Thanks |
The following 14 BHPians Thank AirbusCapt for this useful post: | digitalnirvana, Dry Ice, Joe367, Nitish B Shetty, rajvardhanraje, Ravindra M, redohabitat, Roy.S, sainyamk95, Sen, Shubhendra, srvm, Thad E Ginathom, V.Narayan |
29th June 2023, 16:48 | #92 | |
BHPian Join Date: Dec 2005 Location: bang
Thanked: 3,204 Times
The stress cycles, which @AirbusCapt is referring to is well known for marine steel while for Carbon fiber it is not fully understood. The problem, i am told, is due to the inherent nature of the bond between two dissimilar materials. The yield point of carbon fiber is sudden unlike marine steel which undergoes an elastic failure. This is probably the cause for an implosion and not buckling. | |
(5) Thanks |
The following 5 BHPians Thank srini1785 for this useful post: | AirbusCapt, digitalnirvana, redohabitat, srvm, V.Narayan |
29th June 2023, 17:40 | #93 | |||
Distinguished - BHPian Join Date: Jun 2007 Location: Chennai
Thanked: 28,305 Times
| Quote:
In an early post, I asked a couple of technical questions, but no-one has yet answered:- 1. Risk of delamination in carbon-fibre composite, and whether the cylindrical structure would affect this. I'm pretty dumb with numbers, but plainly the interior diameter is smaller than the exterior diameter, the circumferences throughout the thickness are thus, different, and could that cause separation? 2. Focus is on the carbon fibre, what what about the titanium? ISTR reading that it work hardens quickly. Isn't work-hardening/metal-fatigue just different instances of same or similar phenomenon? All those deep-ocean stresses <a bit later> Quote:
Last edited by GTO : 29th June 2023 at 18:48. Reason: Merging back to back posts | |||
() Thanks |
29th June 2023, 21:15 | #94 | |
Distinguished - BHPian | Re: OceanGate submersible Titan goes missing while visiting the Titanic. EDIT: Wreckage located Quote:
Apart from that under EU consumer law, any product would have a 2 years warranty. You can not sell anything in Europe without warranty. But again, apart from that just about all carbon frame bicycles, be it a road bicycle, or MTB come with identical warranties as metal/aluminium frames. Not just in Europe, same is true in the USA and many other countries. I think this thread is a testimony to how little most of us really understand when it comes to carbon fibre products. How do they design, manufacturer and test carbon fibre parts in the aviation industry if they could shatter just like that? Jeroen Jeroen | |
(13) Thanks |
The following 13 BHPians Thank Jeroen for this useful post: | anandhsub, ashis89, Karthik.guru, kiku007, MinivanDriver, Redline6800, Roy.S, sainyamk95, Sen, SnS_12, srvm, Thad E Ginathom, vb-saan |
30th June 2023, 09:12 | #95 | ||
The only thing that seems to be going for carbon fiber is it's weight although its beyond my understanding why lightness should be considered a favorable factor in a submersible. Regarding the cylindrical structure, i can only say that any fluid would exert the same pressure on all sides. So a cylinder or sphere (having same radius of curvature) would experience the same force per square m at a given depth due to water. Quote:
(2) Thanks |
The following 2 BHPians Thank srini1785 for this useful post: | redohabitat, Thad E Ginathom |
30th June 2023, 10:36 | #96 | |
BHPian Join Date: Mar 2016 Location: Bengaluru
Thanked: 3,168 Times
| I have been following this thread for the past few days but was unable to find time to post here so far. Many posts in this thread have been about Carbon fiber composites and its failure modes, its suitability/unsuitability for the submersible applications etc. Some posts in this regard have been inaccurate, some are partially correct, some use wrong technical terms and some are completely wrong**. I won't get into which post is which type. Kindly allow me to add a few points even though it is not specific to Titan's failure. ** I earn my bread by working in the area of Composite airframe structures. I'm fairly exposed (>14 years) to their design, stress analysis, material characterization, mechanical testing, Non-destructive testing (NDT) and do a fair bit of R&D in high performance composites. 1. First off, there are many types of composites in use (from performance and cost point of view): from use in ground applications such as pressure vessels, to automotive (F1 etc), to sports goods (cycling, tennis racquets), to Aviation and space applications. Naturally, the ones used in Aviation and space are of very high grade/quality and performance, and therefore costs more to produce. Also, these materials undergo rigorous characterization and testing before being certified for use in aviation applications. Also, the design of airframes (whether using alloys or composite materials) are also rigorously checked and reviewed. 2. The usage of the phrase 'Carbon-fiber' alone to refer to Titan's hull is incorrect as some have already pointed out. Composites are made of 2 or more constituent materials. In this case, Carbon-fiber is called the reinforcement and it is supported in a polymer matrix (typically epoxy for such applications). The raw material is layered or wound on a tool and is cured (polymerization in high-school parlance) in an autoclave under appropriate temperature and pressure conditions to obtain the part. 3. I would presume that for an application like hull of Titan submersible, the designers would have chosen a high-performance composite material similar to the ones used in aviation industry. And I presume/hope their designs were verified and validated thoroughly via tests on ground. 4. IF DESIGNED PROPERLY, Carbon fiber composites are capable of being used in this hull application. A few sub-points in this regard: a. The cylindrical shape of hull is best suited for fabrication through filament winding method. If designed and executed properly, the structure should achieve its design strength and stiffness. b. The challenging part of the design is going to be the joints. Particularly, the ones between Carbon fiber composites and Titanium/other alloys (dissimilar materials in many ways). Again, this is POSSIBLE to do, if due care is taken. Likewise for bonding / joining between composite and viewing window. c. Delamination in composites is an area that worries designers (delamination = separation of various composite layers within a laminate). So, we take them into account during design to a certain extent. Also, an appropriate inspection plan (visual + NDT) is put in place during service to avoid unforseen failures. Typical NDT techniques used are ultrasonic inspection, infrared thermography, X-ray and so on. I'm not sure what kind of inspection plan and infra was in place for the ill-fated Titan. 5. High-performance composites (such as used in aviation and space) are actually better in fatigue compared to traditional Aluminium and Titanium alloys. (I saw some posts in this thread mentioning the complete opposite). Without getting too technical this is the simplest explanation: Crack propagation is easier if the material is homogeneous and isotropic (like alloys). It is difficult (needs more energy) in non-homogeneous, anisotropic materials like composites. Also, designers take fatigue effects into consideration during design, whether it is alloys or composites. Also, loading-unloading cycles of few tens or hundreds times is different from cycling for thousands of times. For instance, critical sections of airframe which are subjected to fatigue loads will be typically designed to withstand a million or more load cycles (basically it is designed to be safe for its entire operational life). So, I presume designers of Titan's hull would have considered few 100's to 1000's of load cycles while designing it. Someone mentioned that composites are poor in fatigue and that is why they aren't used in turbine blades. Turbine blades are typically made using Nickel or Cobalt based superalloys because of the extreme thermal and fatigue environment. The temperatures in turbine can easily reach about 1500 deg C. Most composite materials cannot be used at such high operating temperatures. And thats why they are not used. Not because of poor fatigue manners. Composites are widely used in fan blades of gas turbine engines (E.g. GE90, GE9X etc.) which are subjected to fatigue loads but at lower operating temperatures. {Turbine is different from Fan. Fan comes before the combustion chamber. Turbine comes after the combustion chamber, hence subject to higher gas temperatures.} 6. Most metals and their alloys are DUCTILE. This means that, up to a load, they come back to original shape and size when they are unloaded (known as Elastic limit or Yield point). Above this load, they elongate/deform permanently even if the load is removed (known as Plastic deformation). If one continues to load it further, then the material ruptures. In a way, this DUCTILITY is considered beneficial because the material provides some sort of 'warning' in the form of plasticity before it ruptures completely. Now, Carbon fiber composites are not ductile, they are BRITTLE materials. They do not undergo plastic deformation. Instead, they are elastic upto some load and then BOOM (ruptures suddenly). Engineers who were trained in traditional methods, consider(ed) this behavior as non-ideal/inconvenient. But that was 30-40 years ago. Composites are now better understood and more predictable, which is why most modern aircraft structures (both civilian and military) are nearly 50% composite by weight. 7. Since this post is already too long and technical, let me end with one final point. Foreign body impact = Kryptonite for composites. They can cause (sometimes severe) delaminations / disbonds on the inside of composites while looking perfectly fine on the outside. This can fool inspectors during routine visual inspections. For e.g. if Titan's composite hull got hit/banged by some part of Titanic's wreckage during its final or previous trips, then it could potentially cause delaminations with fatal consequences. Once again, a detailed inspection plan and execution should be in place to catch such damages. My sincere apologies for the long & pedantic post. I could not resist posting in a detailed manner since some earlier posts were adding to some common misconceptions about high performance composites (which is my daily-bread ) srini, much of your previous and this post is correct but there are some mistakes. Quote:
That's because, such vehicles have to be made, assembled, trialed on ground (outside-of-water) - where heavier the weight, more laborious, painstaking it is to move it around etc. Last edited by Sheel : 30th June 2023 at 13:23. Reason: Please use the EDIT or QUOTE+ (multi-quote) button instead of typing one post after another on the SAME THREAD! Thanks. | |
(76) Thanks |
The following 76 BHPians Thank srvm for this useful post: | abhi9044, adi.mariner, Akshay1234, alpha1, anandmv, ankan.m.blr, arijitkanrar, Arun_S, asbshyam, ashis89, audioholic, Beta_Blocker, BoJack, carthick1000, catchjyoti, clementj, d.w.w., darkfantasy, denzdm, digitalnirvana, dijkstra, DIV17, Dry Ice, dsnaveen21, Elegant, Everlearner, Freespirit27, furyrider, GJ01, GKR9900, IanNazareth, Jeroen, Karthik.guru, kavensri, kiku007, KiloAlpha, Kurrant, lalgudi, lapis_lazuli, libranof1987, mallumowgli, mayankk, MegaWhat, MinivanDriver, Mu009, myavu, nagr22, NICHE, Night Raven, Omkar, PreludeSH, professortarzan, r0nit7, rajvardhanraje, redohabitat, robincsamuel, Rocketscience, Roy.S, sagarpadaki, sainyamk95, sandeepmdas, sanjayrozario, sauravpat, Sen, Shubhendra, Simhi, skanchan95, SnS_12, Thad E Ginathom, thanixravindran, TheReebee, tracerspiff, V.Narayan, venkat_partha, viggienomad, wolg |
30th June 2023, 10:44 | #97 | ||
So it is all about buoyancy and how to deal with it at such extreme depths. Using composite materials solves this problem and allows for a much simpler design. It is much cheaper. Jeroen Last edited by Jeroen : 30th June 2023 at 10:55. | ||
(7) Thanks |
The following 7 BHPians Thank Jeroen for this useful post: | mallumowgli, Redline6800, Sen, SnS_12, srvm, Thad E Ginathom, V.Narayan |
30th June 2023, 12:25 | #98 |
BHPian Join Date: Jan 2023 Location: Mumbai
Thanked: 477 Times
| Re: OceanGate submersible Titan goes missing while visiting the Titanic. EDIT: Wreckage located Recent news from the company who made the Submarine for visiting Titanic, someone at the board level has to be really nuts to not understand that this is not working for the company. |
(3) Thanks |
The following 3 BHPians Thank udzgodfather for this useful post: | rajvardhanraje, sainyamk95, Thad E Ginathom |
30th June 2023, 17:37 | #99 | ||||
But seriously, this suggests that they are under no regulatory control whatsoever. If this was an aircraft, wouldn't it be grounded until completion of full investigation and release? Hmmm... Am I suggesting they should just scrap the whole venture, company, and all? Not really, but full investigation and transparent testing should come before future plans and advertising. | ||||
(3) Thanks |
The following 3 BHPians Thank Thad E Ginathom for this useful post: | Jeroen, SnS_12, srvm |
30th June 2023, 18:36 | #100 | |
BHPian Join Date: Sep 2015 Location: Bangalore
Thanked: 261 Times
There's one point that has been nagging me. I would be very thankful if you could throw some light on this aspect. In an aircraft hull use case, the composite hull is under tension ( or rather I intuitively think of it that way) as the outside air pressure at altitude is less that the inside of the pressurized cabin. However in the deep sea submersible use case, the compsite hull is under compression since the outside pressure is many fold higher than the inside. Now intuitively I feel that the composite material being made out of strands of fibre that is woven, then reinforced and layered would withstand tension better than compression. Would really like to hear your expert opinion on this. Thanks. | |
(1) Thanks |
The following BHPian Thanks MinivanDriver for this useful post: | srvm |
30th June 2023, 19:20 | #101 | |
Distinguished - BHPian Join Date: Jan 2015 Location: Chennai
Thanked: 8,847 Times
So yeah, they've had operations in international waters with no one to police them. This has to be some weird legal loophole - because, why not just regulate them based on where such companies are incorporated? I don't understand this bit. Last edited by graaja : 1st July 2023 at 11:56. Reason: Removing off-topic parts unrelated to this discussion. Please stick to the topic. | |
() Thanks |
30th June 2023, 20:01 | #102 | |
You are quite right that internally pressurized vessels are predominantly under tension loads. And vessels/submersibles subjected to external pressure are under compressive loads. And indeed, composites with their layered construction have better tensile strength (about 20-25% higher) compared to compressive strength. But this is known and hence factored-in during design where compression loads are to be carried by the structure. *Slightly advanced topic* = Also, most thin structures (not just composite ones) such as ones used in aircraft when subjected to compression loads tend to BUCKLE first before getting crushed under compression. Once again, there are ways to predict onset of buckling and prevent buckling by design. Composites are regularly designed to carry compression loads. for example, top skin of aircraft wing is dominated by compression loads. So, if designed properly with care, it can be a safe structure. | |
(5) Thanks |
The following 5 BHPians Thank srvm for this useful post: | Jeroen, MinivanDriver, skanchan95, Thad E Ginathom, V.Narayan |
1st July 2023, 05:38 | #103 | |
BHPian Join Date: Sep 2022 Location: IN
Thanked: 181 Times
If a touring company offers you to take you to the Titanic, run. If a touring company that prides itself on cost-cutting offers you, run further. If a touring company that prides itself on cost cutting offers you a seat on an already used untethered cyclindrical carbon fibre-titanium sub, just laugh. It's about your life, not about whether something's possible. You could make it that deep in a phone booth, if "it's made well enough". If you're a billionaire who really wanna see the Titanic, commission a sub yourself. Last edited by Formula1 : 1st July 2023 at 05:53. | |
(1) Thanks |
The following BHPian Thanks Formula1 for this useful post: | Thad E Ginathom |
1st July 2023, 10:55 | #104 | |
BHPian Join Date: Jun 2017 Location: City of Lakes
Thanked: 804 Times
Regarding the incidents/accidents/crimes that happen at sea in international waters, the maritime authority of the country where the ship/boat/yacht is registered and the country where it enters after the crime happened, are required to take required necessary actions. Local police too is involved and supposed to take required actions. OceanGate is a registered company and their ocean going crafts must have been registered somewhere. They must be having license to operate international VHF radios registered with service provider so, legal action proceedings will be there. They must have made the clients to sign an indemnity to cover themselves. Incidents and accidents happen across the industries, that doesn't stop the business. In case an accident happens on a ship or a marine craft, initial evidence is collected, investigation is done at different stages depending on the nature of the incident, if the nature of incident is not serious, the ship goes about its business immediately after the initial investigation is completed. Loss of 2-3 lives is not considered a serious incident to stop the business. We submit an indemnity for our kids, when the school is taking them out for picnics, tours etc, so OceanGate is well covered by such indemnity, stating that the customer is well aware of risk in case of an untoward incident. The above statements are purely based on how the business works, and as far as I understand, emotional values have no role in business, except to attract customers (business). Hundreds of lives of seafarers are lost at sea every year, response from the employers is standard as per the procedures, no emotions, no feelings of remorse. Harsh but thats the truth. | |
(3) Thanks |
The following 3 BHPians Thank Brumby for this useful post: | adi.mariner, thanixravindran, V.Narayan |
1st July 2023, 11:08 | #105 |
Senior - BHPian Join Date: Dec 2007 Location: Mysore
Thanked: 5,277 Times
I had to laugh at the fact that there's not even a discount on the $250,000 price tag! |
() Thanks |
