Re: Ashok Leyland delivers Light Bullet Proof Vehicles to the Indian Air Force Quote:
Originally Posted by norhog Thank you for that reply.
Any information what would be inputs by Lokheed in this vehicle.
Is it the blast dissipation under the body if driven over a mine or explosive or the fact that it can fit in an cargo airplane.
Thanks in advance. |
The entire vehicle is based on the the Lockheed Martin CVNG - Common Vehicle Next Generation.
About the CVNG -
The Lockheed Martin (LM) CVNG is based on the thought process of the Supacat HMT ( High Mobility Transporter).
The Concept is to have a 'base chassis' which can be easily customized to deliver multiple vehicles that the military may need, including 'field changes' where required.
Somewhat like how car companies use 'platforms'. Ideally an Octavia is the same as a Jetta/ A4/ Seat Leon with a choice of engines.
The HMT was designed with 2/3 engines, 2/3 transmission choices and 'mounting spaces' which allow for modules to be added/ removed from the base vehicle to be used in multiple roles.
The AL - LBPV is based on the same concept, which was purchased from Lockheed Martin.
The base version is not 'armoured' and can be considered as an equivalent to a Open top Jeep, Its meant to be used for troop transport.
Based on the IAF needs - this has been armoured to Stanag2 levels
Incidentally, Stanag2 vehicles dont necessarily have the 'V' shaped hull that mine resistant vehicles have but use 'curve deflectors' similar to the sloped armour on tanks where the slope increases the 'effective cross section' of the armour plate. This dissipates the 'blast pressure' created by the explosion away from the vehicle while also ensuring that the plate does not deform too much. The seats for the soldiers in such vehicles are generally suspended from the top rather than being bolted to the floor. Most Grenades have between 120-200 grams of explosive as they depend upon 'shrapnel' for the secondary kill effect. Such a vehicle will easily take a few grenade hits directly.
I believe AL bought the basic chassis/ engine design from LM. AL has in the past developed armoured vehicles based on the same chassis. |
