Re: USA: Engine failure on United Airlines Boeing 777 Quote:
Originally Posted by GRAND23 There is no cowl on engine. Scary scenes indeed. Good that they have diverted the flight back to base (and that's what manual says too). |
There is no requirement to fly back to base, the pilots assess the situation and based on protocol and their own judgement decide where they want to land in essence. Obviously, if you have just taken off, the nearest airport is likely to be the one you have just departed from. But that is certainly not a given. Depending on how the pilots assess the situation they might want to give preference to another airport nearby. Quote:
Originally Posted by GRAND23 I work for aviation industry (specifically on engines). It looks like a fan blade failure for me. But wait! Blade failure can be contained and engine is designed for this. But if there are multiple blades failure then it cannot be contained and will lead to catastrophic failure. |
The whole definition of a catastrophic failure is currently discussed on the various pilot forum. In layman terms, when the blades are breaking of and leaving the engine perpendicular and thus potentially can pierce the cabin it tends to be called catastrophic. Engine have special protective measure and some re-informcements in place to minimise damage by blades coming of the engine.
It looks that in this case most of the bits came out of the back of the engine. Still very serious, but a very different kind of failure it appears. We will have to see and hear more. Quote:
Originally Posted by GRAND23 Almost all engines are designed to fly back with single engine and this is mandatory requirement from EASA approval. |
Not just EASA. I can’t think of a any aviation authority that doesn’t mandate the ability to loose one engine (on a twin) and even multiple engine failure on 3-4 engine planes.
In general, on twins, it is mandatory to be able to loose an engine during take off and still take to the air, and obviously stay cruising on one engine. It does come with substantial performance reduction, obviously. Quote:
Originally Posted by GRAND23 From this video, it looks like bad engine was still running or may be it was shut down later? Generally during blade failures, engine will be shut down immediately. Reason = uncontrolled fire will lead to further damages on aircraft.
It looks like the engine is simply windmilling. The pilots will have shut it down, which means no fuel is going to the engine. But part of the turbine is still in place and it is just the wind/air flow through the engine that makes it spin. You can observe the same effect on airplanes on the ground. Look at their engine, if there is some wind, you are likely to see them spinning around slowly.
Not quite sure what it is we see glowing/burning. Most likely some components that got very hot, or hydraulic oils spilling out.
Jeroen |
