Originally Posted by T1000 Keen to know, how break downs are handled at mid sea? |
Hi T1000,
As explained by fellow BHPian, there is tank or technically called air reservoir which holds 30 bar compressed air for immediate use.
Now let me explain a bit how the engine is started using compressed air.
First some Acronyms, TDC. Top Dead Center, ECU Engine Control Units
The Electronic engine is fitted with an angle encoder which detects exact location of the unit and the encoder is calibrated for the first unit, so other units positions are relative to number 1 unit. For a 6 cylinder 2 stroke engine the firing order is 135426.
Now once angle is known, the ECU knows which unit is at TDC. Now based on the firing order the compressed air is let to the unit which is at TDC. This compressed air pushes the piston down and engine starts to turn. The rotation of the engine makes the other pistons to come to TDC and compressed air is let on these pistons, which makes the engine to pick the RPM. Once engine reaches the RPM where it can develop enough momentum to burn the fuel, the fuel is pumped by the booster pumps. The fuel is injected at around 350bars.
Once the engine up running on fuel, the RPM is raised and speed of the vessel / ship picked up.
For breakdowns:
Normally we make sure the strict maintenance schedule is followed and generally the breakdown at sea are less.
But at an unfortunate event of breakdown, no choice but to solve the problem and make the engine run again.
The challenge is not doing the breakdown maintenance, the challenge is to carry out maintenance when the ship is rolling. As the ship loses the engine it won't be stable and does all sorts of dance
as possible. Now to carry out the maintenance as per the rolling is very challenging.
Originally Posted by Sutripta What would be the impeller diameter of these turbos? |
The diameter of the impeller is around 1 metre to 1.5metres
Originally Posted by V.Narayan What sort of clutch connects the engine to the propeller. I assume when this giant engine is being started with compressed air it is de-clutched from the propeller shaft and then as it starts to run on its own it is clutched in and the ship starts to move. How large & heavy is your propeller. |
As explained by fellow BHPian it is direct coupled engine and no clutches are provided. The diameter of the propeller is 9meters and one turn of the propeller pushes the ship by 6meters.
Originally Posted by rav11stars Thanks a lot for the post. Writing is a subtle art and there are few in this forum who've mastered it. You'd just love to read them. Your post is one of them. It has just the right amount of info and nicely spaced paragraphs to encourage one to read rather than scroll through. |
Thank you for the encouraging comments.
To become a seagoing merchant vessel Captain it takes any where from 10 years to 15-years of experience. In these years one gains enough experience and understands behavior of the vessel, understands the effect of sea currents and winds and understands effects of tides. As in case with the vehicles (sedan, SUV, MPV. etx) different vessel behaves differently to the wind, current and speed.
Vessels like containers carriers zoom at 20 to 22 knots but Crude oil tankers and Bulk carriers (iron ore, grain, cement etc) hardly moves at 15knots. Main reason being the amount of cargo they carry and how much immersed they are in water.
A crude oil tanker (Very Large) has an immersion of 25meters under water (imagine a 6 storied building) and carry 300, 000Tons (3 Lakh Tons) of Crude oil at a given time.
Regarding the technical aids, there are whole lots of them which assist in safe navigation in any waters.
We have Electronic Charts ( Some thing like G-Maps), GPS (for position), Compass (for direction), Radars (for surrounding info), Auto Pilot mode etc etc.
