Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | ![]() 20,115 views |
![]() | #1 |
Distinguished - BHPian ![]() | Pre-flight planning & checks for flying single-engine planes ![]() Source Flight preparation and flight planning is done in a very structured way. It doesn’t matter if you are flying a single engine Cessna or Jumbo jet. The main difference is I will do everything myself and on a Jumbo there are two pilots who will distribute the tasks and to some extend check one another. Also, airline pilots rarely do their own flight planning. They have an operational department that does all of that for them. They still need to verify and make sure they can conduct the flight safely of course. So here is what I do: I will do a very thorough flight planning exercise. Usually the night before at home behind my PC. It all starts with where you start from and where you are heading to. Next I need to decide whether I would like to conduct the flight under Visual Flight Rules or under Instrument Flight Rules. Obviously, the weather might decide for me that is has to be IFR. The preparation for either VFR and IFR is somewhat different, VFR gives my much more flexibility as long as I don’t venture near any main airports (so called B-airspace). Fuel planning has also different requirements. I rarely filed a flight plan for an VFR flight. For an IFR flight plan you have to file a flight plan. In the USA whilst flying under VFR rules you can ask Air Traffic Control for “flight following”. That means they will keep an eye on you and advise you along your flights on anybody getting near, or when you are entering restricted airspace. The ultimate responsibility is still with the pilot but in essence you get an extra set of very capable eyes. Flight following can be denied if ATC is too busy. However, that rarely happened to me. Also, no mistakes, almost all major Airports allow VFR operations. So I could land my little Cessna/Cirrus just about anywhere. There are specific requirements on the aircraft equipment for entering this so called B-space. In essence you need a proper transponder and two way radio communication. I would figure out the routes, look at the expected weather, check and work out possible alternate route and diversion airports. I would check the so called NOTAMs (Notice to Airmen). These deal with all sort of possible operational restrictions at airports and along the routes. On an IFR route I would very carefully check the complete route on sectional charts so I really understand what minimum altitudes I would have to be able to fly, whether me and my plane are capable etc. I would look up the airport diagram of my departure and arrival airport and the possible alternates. Study the arrival routes, airport information, runway information etc. Depending on what plane I was going to fly I would make more or less notes. For instance on the Cirrus with a very advance full glass cockpit changing radio frequencies is very easy. Essentially you have all the information on the navigation display. On simpler aircraft that might not be the case. You would have to look it up on a chart or a document. So when I flew our little Cessna I would usually right down all the frequencies per airport and along the route, so I had them handy on a piece of paper. Less need for that in more advanced aircrafts. Fuel planning is important. I would always try and leave with full tanks no matter what. As a rule most GA pilots will always fill up their tanks to capacity after the last flight of the day. That way chances of condensation are smallest. Still, you need to do the fuel planning and especially on longer flights I would calculate fuel burns and check that at any point during my intended flight I would still have enough fuel to reach a potential alternate. Again, flying VFR or IFR has different requirements on alternates. Once you have figured out the fuel, the next thing would be the CG (Centre of Gravity) calculation. Based on your airplane loading, (passengers, fuel, luggage) you need to determine that the CG is within certain limits. In the old days we used charts for this, these days all done on an easy app on your iPad. You would do take off and landing calculation to ensure that given the loading of the aircraft, the expected wind, temperature, altitude and runway, you could safely take off and land. For you destination airport and alternates studying the missed approaches is really relevant as well. Once I was happy that I could safely execute my flight I would print my flight plan in case of an VFR flight. In case of an IFR flight I would upload/submit it for approval/registration. I used both an iPad as well as paper documentation. So I would make sure that the flight and all its relevant data (route, airports, departure / arrival etc) was easily available so I don’t need to search for it. Part of the planning process is also taking your own personal minimums into consideration. When you pass your VFR or IFR check ride you are fully qualified. So legally as long as you adhere to the respective rules and requirements you are ok. The question a pilot needs to answer, what are my personal limitations. They might be less than the legal ones. I would be very reluctant to fly near mountains. Not because it is illegal, but I just don’t have much experience. I took a week mountain flying instruction once, but still I would plan a route across mountains very carefully, if at all. Crosswind is another. How much crosswind do you feel you can handle comfortably? If there is a likelihood of the crosswind at your destination airport being more than you feel comfortable, should you go at all, or at least make sure you can reach alternates with less cross winds! Take off minimums are an interesting one. Believe it or not, for GA pilots such as me there are no minimum take off requirements. So legally I can take off with zero visibility. It would be pretty stupid, but perfectly You also need to check whether you are fully current for the intended flight. If you have an USA FAA VFR/IFR rating you are automatically qualified for night flying. But under for instance VFR rules you can’t take passengers unless you have done a certain number of night landing the previous period. Some with IFR you need to have a certain number of type of landings under your belt or you are not considered current. That might put restriction on how you can conduct your flight. As I mentioned VFR and IFR flight have legal fuel minimums. So once you arrive at your destination airport you need to have sufficient fuel to fly for say 30-45 minutes (depends a bit). My personal fuel minimums were at least double. I just never felt comfortable cutting it that fine. In practice it was rarely a problem. A Cirrus can easily fly up to five hours with sufficient reserves to meet legal minimums. There was sort of a joke/saying amongst GA pilots: Old GA pilots rarely run out of fuel, their bladder will be full long before their tanks are empty! I actually used Microsoft Flight Simulator now and then to familiarise myself if flying into a particular airport I had not been before!. Google Earth is also an excellent tool to help yourself orientate in unknown territory. So in all for my the flight planning could take several hours easily. Length of the flight doesn’t even make that big a difference. You still need to make all the checks, familiarise, do the calculations etc. The next day, first thing when I wake up. Ask yourself “am I in a fit state of mind and body to conduct the flight”. You need to be brutally honest with yourself. If you had a few glasses of wine the night before you might not even be legally allowed to fly. But a bad cold can be a major issue, especially if your intended flight is at high altitudes. So once you self declare fit next is verifying any chances to your flight plan. Typically whilst driving to the airport, I would phone and get the latest weather updates for my departure / arrival en enroute weather. If it deviates too much from what I had counted on, I might have to redo some or all of the planning. Once at the airport I might have to sort some paperwork before taking the plane. In our club we did most of ours online, but you had to sign of for the plane. If the airplane was hangered the first thing was usually to get it out of the hanger. Then conduct the walk around. Which is done by checklist. It is a visual inspection of all sorts of parts of the plane. Wheels, tyres, wings, rudders, ailerons, flaps, engine, check oil, water, fuel (fill up if need be). Very important: You need to check the fuel for water!!! So you have to draw fuel from each tank with a special little device and check the colour. (Fuel for these single engines has a blue dye added) Load and secure any luggage. Instruct passenger on what to expect, emergency procedures, help them strap in, get their headset on, show them how the oxygen equipment works. (these planes don’t have pressurised cabins, so over a certain altitude everybody needs to start using oxygen. From there on you start you pre-flight checklist, contact ground (in most cases) and declare intentions. (e.g. you are ready to taxi or you want to activate the flight plan etc). There might be some paperwork you need to verify (depending on it being an VFR/IFR flight certain instruments need to be calibrated within a certain period etc. Also, there are a few documents that each airplane needs to carry on all flights and you need to verify they are on board. And ultimately off you go. During the flight you would constantly monitor if your flight was going according to plan. So you would watch your fuel burn, altitudes, winds aloft, keep monitoring the weather en route, destination and alternates. If anything deviated by too much you might have to re-think, re-calculate or even re plan your flight You can’t just hop into a plane and take off. Well, you can. But it would be pretty stupid and almost certainly illegal as well. I loved flying every aspect of it. I always really enjoyed the lengthy flight planning, the more complex the better. Jeroen Last edited by GTO : 19th November 2018 at 07:22. Reason: Adding a representative image :) |
The following 71 BHPians Thank Jeroen for this useful post: | 1.2TSI7DSG, aah78, abhijitvp, Acharya, AKTRACK, alpha1, ankan.m.blr, arjithin, arunphilip, ascension, bikertillidie, BlackPearl, blackwasp, BoneCollector, CarCynic, carmayogi, dailydriver, dhandapanik, Enobarbus, gauravanekar, govindremesh, greenwolf08, GTO, hmansari, honeybee, ike, InControl, Ithaca, jaunthead, kutts, Latheesh, lemedico, libranof1987, Lobogris, MaheshY1, mallumowgli, N33raj, NirmalK, PapaBravo, PapaKiloSierra9, Rahul Bhalgat, Raj_RD, Roy.S, Sail, saket77, Samba, Samurai, sandx, shekaran, Shubhendra, skyocean, SmartCat, snaseer, somspaple, spd_tkt, sri2012, sun_king, tharian, timuseravan, V.Narayan, Varun_HexaGuy, VeluM, vharihar, VijayAnand1, Vishal.R, Vitalstatistiks, vnabhi, voldemort, whitewing, Yusha, zavegur |
![]() | #2 | |
Team-BHP Support ![]() ![]() | re: Pre-flight planning & checks for flying single-engine planes Quote:
But all that coverage never gave me the sense that he had planned his trip this kind of detail. I remember he was not qualified to fly IFR, yet he was flying over sea at night. Last edited by Aditya : 18th November 2018 at 19:59. | |
The following BHPian Thanks Samurai for this useful post: | carmayogi |
![]() | #3 | |
Distinguished - BHPian ![]() | re: Pre-flight planning & checks for flying single-engine planes Quote:
Again, these are personal choices pilots must make. All private pilots should prepare and plan along similar. Most do, some don’t. GA certainly in the past had a very poor safety record. Many planes crashed, lots of fatalities and the number one reason was what is called loss of control. The FAA did extensive research. Their conclusion were a bit of a revelation. One thing they found is that statistically there is no difference between a low hour pilot and a high hour pilot. Statistically speaking you are as safe with me as you are flying with a say KLM captain with 20.000 hours under his belt. So flight experience did not really contribute to less fatal accidents. What they did find is that people who are fairy conscious about the overall approach to flying are less likely to have a fatal accident. So it is all about attitude. And that is relative easy to teach. So they introduced the FAA wing program. Every USA pilot can participate for free. It teaches you how to deal with all the things I described. Planning and proper aeronautical decision making are key to flight safety. Being a hot shot stick and rudder pilot is not. Most of these loss of control accidents happen because pilots get themselves into a situation they could have easily avoided. If they had planned it properly, if they adhere to procedure, if they are honest with themselves etc. Let me give you a small example. At our airport a few times a year we would have open days. Pilots would take people up for a quick flight. Usually 10-15 minute flight. Great fun, lots of kids and also some parents for whom it is a hugely interesting first exposure to General Aviation. I have participated as pilot a few times. Good fun. There were two types of pilots during these days. There were those that did the initial prep, walk around and then loaded up their passengers, landed unload passengers and put the next lot of passengers on and took of again. They did not think a 15 minute flight warranted another walk around. Then there were the likes such as me. I would do a walk around every time prior to each subsequent take off. Flying is about building routines, doing things the same way in order to quickly notice something out of the ordinary. Takes all kind. But statistics don’t lie. Jeroen Last edited by Aditya : 18th November 2018 at 19:59. | |
The following 24 BHPians Thank Jeroen for this useful post: | ankan.m.blr, arunphilip, Crazy_cars_guy, hmansari, ike, InControl, Ithaca, libranof1987, mallumowgli, mango_pal, NirmalK, r0nit7, saket77, Samba, Samurai, sandx, shekaran, silversteed, skyocean, somspaple, sri2012, V.Narayan, VeluM, voldemort |
![]() | #4 | |
The following BHPian Thanks SmartCat for this useful post: | gauravanekar |
![]() | #5 | ||
I was a bit surprised by this number 3 slot if I’m honest. These engines are pretty simple and robust. But for various reasons we havent seen all that much development on them over the last couple of decades. It is probably a money thing. It is expensive to develop and certify new engines. Also, the GA and pilot community is, when all is said and done, pretty conservative, So they might prefer an old design with some known problems over a new unknown design. Jeroen PS: for those that like to understand the full details, here is where I took the numbers from: https://www.faa.gov/news/fact_sheets...m?newsId=21274 Last edited by Aditya : 18th November 2018 at 19:58. | ||
The following 12 BHPians Thank Jeroen for this useful post: | CarCynic, InControl, Ithaca, libranof1987, Lobogris, NirmalK, saket77, Samurai, V.Narayan, Vitalstatistiks, vnabhi, voldemort |
![]() | #6 |
Team-BHP Support ![]() | Pre-flight planning & checks for flying single-engined aircraft - Posts moved to a new thread. Last edited by Aditya : 18th November 2018 at 19:43. |
![]() | #7 | |||
Distinguished - BHPian ![]() Join Date: Aug 2014 Location: Delhi-NCR
Thanked: 72,252 Times
| re: Pre-flight planning & checks for flying single-engined aircraft Quote:
The following 8 BHPians Thank V.Narayan for this useful post: | CarCynic, gauravanekar, hmansari, Ithaca, libranof1987, Lobogris, SmartCat, vnabhi |
![]() | #8 |
BHPian Join Date: Jan 2008 Location: Bangalore
Thanked: 1,557 Times
| re: Pre-flight planning & checks for flying single-engine planes Great write-up Jeroen. What is GA? Also, you said: Why is VFR even allowed as an option? Isn't IFR much safer? |
![]() | #9 | |
GA is General Aviation, basically non-scheduled flights in small aircraft like this: ![]() Quote:
https://en.wikipedia.org/wiki/Air_Ne...and_Flight_901 ![]() | |
The following 4 BHPians Thank SmartCat for this useful post: | Crazy_cars_guy, hmansari, V.Narayan, vharihar |
![]() | #10 |
BHPian ![]() Join Date: Dec 2015 Location: Kolkata
Thanked: 49 Times
| re: Pre-flight planning & checks for flying single-engine planes |
The following BHPian Thanks Raj_RD for this useful post: | vharihar |
![]() | #11 | |||||
But on average 75% of VFR rated pilots that find themselves in IMC conditions (i.e. conditions requiring an instrument rating) meet with a fatal accident. Within three minutes of having entered the clouds! here is the the (in)famous 178 seconds to live. https://www.flightsafetyaustralia.co...-vfr-into-imc/ If you are a VFR pilot and you accidentally fly into cloud you have to act very very fast. Statistically the changes of your plane crashing and killing everybody including yourself are huge. In most cases the most prudent thing to do is to turn 180 degree and try and fly out of the cloud again! VFR flight is at least in theory about as safe a flying IFR. There are lots of rules and regulation you need to adhere too ensuring the risk of collision are minimal. And very very very few aircraft collide in mid air. The biggest problem with VFR is flying into IMC where you really need an IFR condition. As long as you plan your flight properly, and keep tracking your progress, tracking the weather it really is not an issue. Here is good overview of VFR flights: https://en.wikipedia.org/wiki/Visual_flight_rules Under VFR each pilot is responsible for ensure sufficient separation with other aircraft in the vicinity. As I indicated earlier ini the USA you can request flight following from Air Traffic Control. But there are also certain rules you must follow to ensure the chances of a collision are minimal. The below ensure 1000 feet separation between airplanes based on the (magnetic) course they are heading. Quote:
Or to put it even more simply: civil aviation other than large-scale passenger or freight operations That doesn’t say anything on the size of the plane! Huge planes, depending on how they are operated can be considered GA. Quoting for the USA Quote:
What is relevant is that from a legal point of view under most aviation jurisdiction, GA and Commercial aviation come under different rules. The latter even more strict. Jeroen Last edited by Jeroen : 18th November 2018 at 22:36. | |||||
The following 5 BHPians Thank Jeroen for this useful post: | Ithaca, SmartCat, V.Narayan, VeluM, vharihar |
![]() | #12 |
BHPian ![]() | Re: Pre-flight planning & checks for flying single-engine planes Well written and excellent preparations combined with impressive knowledge about aviation procedures and regulations, Jeroen. Loved the meticulous planning, pretty much covered everything a pilot should do and more so on the part where you avoid doing things that constitute unnecessary risks. GA is the last remaining zone of pilot's flying, the fun is taken out of everything else by the instrumentation available these days. PS: Is there a hint of Richard Bach? If not, I'd suggest "A Gift of Wings" ![]() |
The following 2 BHPians Thank sun_king for this useful post: | CarCynic, Jeroen |
![]() | #13 |
| Re: Pre-flight planning & checks for flying single-engine planes |
![]() | #14 | |
BANNED | Re: Pre-flight planning & checks for flying single-engine planes Quote:
Hi Jeroen, a lovely and informative thread. Few stupid questions if you wont mind to answer. 1. For a GA pilot, do he/she has to own a plane to fly? Or are there organizations like Zoom for car, that rent out planes for you to fly? 2. Like commercial aviation, do GA pilots also get certified for the particular brand and model of aircraft? Do small aircraft have defined categories for license, e.g. when we say I am certified to drive a LMV, I can literally drive any private car. 3. Do flying domestic and international need separate set of preparations? Are there other private and smaller airfields that are open to GA only? Who manages these airfields? 4. How is the fuel efficiency for a small aircraft like the one you fly? ![]() Last, but not the least, if you own an aircraft, will it be too much of botheration to you to enlighten us lesser souls with some photographs of your beauty? ![]() | |
The following 2 BHPians Thank PetrolRider for this useful post: | hmansari, Lobogris |
![]() | #15 | ||||||
Distinguished - BHPian ![]() | Re: Pre-flight planning & checks for flying single-engine planes Quote:
I do have two excellent books from Jeppesen on respectively VFR and IFR flying. And then I have lots of actual manuals, mostly on the Boeing 747-400 True, although I am not quite sure how much fun military flying is these days. It is very restricted. Also, military pilots tend to make very few hours. I used to fly more hours per year than most NATO pilots believe it or not. Quote:
Just about every airfield will have at least one, sometimes multiple outfits that rent out airplanes. Some people go for fractional ownership. And you will see advertisement in the “planes for sale” sections in magazines/website. E.g. you will see the 1/4 fraction of a Diamond aircraft advertised. So this is where mostly 4 guys get together and jointly own the aircraft, each owns and is responsible for 1/4 of the cost. It brings down the cost of owning and operating the cost of an airplane considerable. Of course you need to work out simple rules on who gets to fly, when. A very good and easy way to learn to fly and to continue flying is to join a flying club. They will own the planes, often have certified instructors that can help you obtain the various ratings. I started as a member of a flying club. During our last year in the USA a couple of us, together with one of the instructors step out of the club and we made our own club. Three guys had bought their own planes an d the flight instructor owned three planes. So we pooled all those planes together and formed our own club. The club looks after the planes, hanger, insurance any and all maintenance cost. The total annual cost is paid by the members. Then we calculate hourly rental rates for each plane. All of us could fly any of the planes we had in the club at very attractive rates. We had a very simple system for rostering. Essentially a web based Excel sheet where you filled out the hours/days you wanted to fly a certain plane Airplanes cost money to buy. But once you own them the cost continues. You need insurance, a hangar or at least a parking place on a ramp, you need maintenance (you are only allowed to do minimum aircraft maintenance yourself. So you end up taking it to specialised outfits with certified mechanics. Certain equipment needs regular inspection and or calibration etc Quote:
Flying a water plane requires a special license. So in essence you can fly any single engine plane weighing less than 12.500 pounds. However, no flight school, club or rental place will let you have a plane unless you can prove you are familiar with it. So your log book needs to show you have sufficient hours on type. Quote:
A little two eater Cessna 150 burns 6.1 gallons per hour. A huge, luxurious, Cirrus SR22 burn 17 gallons per hours Quote:
My eldest son Luc came along for the ride and took the video shots which I edited: We take off from Rotterdam airport. Fly across Belgium into the north of France. We land and do a few touch and goes on various airport along the way The Cirrus is my personal favourite. It is one the heaviest, largest and fastest aircraft anybody with a PPL can fly. It is very luxurious. It is also fully IFR equipped and certified. It is even certified for flying into known icing regions. I did not mention it specifically in my earlier post. But part of the flight planning when it comes to weather is to be on the look out for areas where you might encounter icing conditions. Icing for most small aircraft is lethal. Legally you have to plan around it, If there is a reasonable chance of icing conditions you have to plan around it. Unless you fly a plane like the Cirrus. Very few of these small planes have this capability. https://www.avweb.com/news/airman/181877-1.html This thread originated as part of a very different one. Just so happens Smartcat asked me a question regarding safety on these sort of planes. I am very happy to see such interest. I will add a little bit more around obtaining a PPL and my own journey/experience in doing so. I can already give away the plot: It was one the best/coolest things I have ever done!! Extremely rewarding when you do your first solo take off! Jeroen Last edited by Jeroen : 19th November 2018 at 13:14. | ||||||
The following 14 BHPians Thank Jeroen for this useful post: | Acharya, BlackPearl, blackwasp, catchjyoti, gauravanekar, hmansari, InControl, Ithaca, kutts, PetrolRider, Samurai, shyml, SmartCat, spd_tkt |
