The story of the Su-27 began in the late 1960s when Russian intel reported new generation of fighters being developed by the US, with vastly improved capability. The Russians set about beginning development of their own fighters to counter the new upcoming threat. The American fighter turned out as the F-14, F-15, and F-16. Of these, the primary focus was on matching or improving upon the expected performance of the F-15, which was to be the mainstay of the USAF.
Aerodynamic studies were performed by TsAGI, the Russian equivalent of NASA, with the outcome being a generic draft of low slung twin engine frame with extensive wing-body blending in the form of leading edge root extenstions, or LERX for short. The wings didn't just abruptly join the cylindrical fuselage as earlier designs did, the wings themselves grew thicker and changed form, getting rounded to blend in seamlessly into the fuselage. This gave a tremendous increase in lifting surface as well as increased internal volume for fuel/equipment.
The first mockups were wind-tunnel tested in the early 1970s, the new layout seemed promising. By 1972, the F-15 had made its first flight, and in 1976, a stripped down F-15 called the Streak Eagle, made several world records for climb/altitude performance. The Russians now had a clearer idea of the target performance the Su-27, or the T-10 as the prototype was then named, had to improve on. The project was headed by Mikhail Simonov, with Alexander Pulenko as test pilot.
The T-10 had ogive curved wing tips, no slats, and the twin tails sat atop the twin engine nacelles.
The initial development was carried out as Ramenskoye facility, and US spy satellites captured grainy images of the new fighter. The US intelligence named this fighter Ram-K , the MiG-29 being developed beside the Sukhoi was designated Ram-L, after the parent Ramenskoye base.
NATO satellite spy image
The T-10 protoype first flew in 1977. Performance was found deficient compared to the F-15, and a redesign was ordered. The revised design was named T-10S, which significantly changed the original design.
The ogive wing-tips gave way to square tips, the engine was reconfigured with the accessories moved to dorsal side of the engine to reduce the engine's ventral wetted area, and the tail fins were moved outboard on the booms which housed the wing root, undercarriage and stabilator controls. Thus was born the Su-27 as we now know. This T-10S prototype flew in 1981 and proved much better in all performance aspects.
The Su-27 series are manufactured at 3 difference organizatios/facilities in Russia -
(Irkutsk) IAPO,
(Komsomolsk) KNAAPO and
NAPO (Novosibirisk).
The Su-27 entered service with the Russian air force in 1985, and soon enough NATO planes had their "friendly" encounters in the Cold War.
Evident from this photo is the visibility the pilot has outside. The low sill offers a good line of sight below and side, front visibility too is excellent. Rear visibility is not as good as the US F-15/F-18 at 6'o clock position directly behind, but the pilot can most of his rear hemisphere in the same plane and upper hemisphere - certainly a huge improvement over earlier generation jets like the MiG-23 and MiG-25/31, which have little glass area and about nil rear vision.
Remember the Streak Eagle mentioned earlier? The Russians did their own version with the Su-27, naming it the P-42. Like the F-15 Streak Eagle, the Su-27 was stripped of all military equipment - radar, ECM, fire control systems, gun, ammo drum, even paint to reduce weight to bare minimum. Paint alone weighs around 200kg. The tail fin was clipped as well. With the weight now down by about 50%, the thrust to weight ratio of the P-42 exceeded 2:1, and the jet could accelerate in a vertical climb! The P-42 captured several time-to-altitude records from the Streak Eagle in 1986, and those records still stand.
Here's a short video about the P-42.
2 seat Su-27UB/Su-30 with raised cockpit and spine:
Su-33 plan view:
Specifications:
Length: 21.9 m (72 ft)
Wingspan: 14.7 m (48 ft 3 in)
Height: 5.92 m (19 ft 6 in)
Wing area: 62 m² (667 ft²)
Empty weight: 16,380 kg (36,100 lb)
Loaded weight: 23,430 kg. (51,650 lb.) with 56% internal fuel
Max. takeoff weight: 30,450 kg (67,100 lb)
Powerplant: 2 × Saturn/Lyulka AL-31F turbofans
Dry thrust: 7,670 kgf (75.22 kN, 16,910 lbf) each
Thrust with afterburner: 12,500 kgf (122.6 kN, 27,560 lbf) each
Fuel capacity:
9,400 kg (13200 litres) Su-27 internally
10,000kg (14000 litres) Su-35
Performance
Maximum speed:
At altitude: Mach 2.35 (2,500 km/h, 1,550 mph)
At sea level: 1,400 km/h, 870 mph
Range:
4000 km ( 2480 mi ) at altitude , 1500km (935 mi) at sea level) - Su-27/Su-35
3,530 km (2,193 mi, 1,906 nmi) at altitude; (1,340 km / 800 mi at sea level) - Su-30
Service ceiling: 19,000 m (62,523 ft)
Rate of climb: 300 m/s[101] (59,000 ft/min)
Wing loading: 377.9 kg/m² (444.61 kg/m² with full fuel) (77.3 lb/ft² with 56% fuel)
Thrust/weight: 1.07 with 56% internal fuel; 0.907 with full fuel
Maximum g-load: +9 g
Armament :
Su-27 : 10 hard points - 2 on fuselage centreline, 1 under each intake nacelle, 2 under each wing, plus 2 wingtip rails.
internal single barrel GSh-301 cannon on right wing root, 150 round capacity
The max load is 2x R-73 on wing tips + 2 R-73s on outboard wing pylons, 2 R-27R/ER on fuselage centre-line, and 2 R-27R/ER beneath engine nacelles, 2 R-27T/ET on wing inboard pylons.
Total mix : 4 R-73 + 6 R-27. Also used were longer ranged R-27EA (active radar homing) , R-27EP (passive radar homing) variants of the R-27. Ground attack capability in early Su-27s was limited to unguided bombs and rockets.
Su-30/33/35 : 12 hard points - 2 on fuselage centreline, 1 under each intake nacelle, 3 under each wing, plus 2 wingtip rails.
upto 8000kg of ordnance including R-77 and R-27R/T/ER/ET/EA/EP medium range air to air missiles, R-73 short range AAMs, KAB250/500/1000kg bombs, laser guided bombs,
80mm/130mm/240mm rockets, Kh-29 , Kh-31, Kh-25, Kh-59 air to ground/ship missiles
Countermeasures ( flares, chaff) cartridges in dorsal surface of the stinger, between the engines.
Sources:
1.
https://en.wikipedia.org/wiki/Sukhoi_Su-27
2.
http://www.milavia.net/aircraft/su-2...7_variants.htm
3.
http://www.milavia.net/aircraft/su-27/su-27_history.htm
4.
http://www.globalsecurity.org/milita...ssia/su-27.htm
5.
www.bharatrakshak.org
6.
http://knowaircrafts.blogspot.in/201...7-flanker.html
7.
https://en.wikipedia.org/wiki/Sukhoi_Su-30MKI
8.
http://www.independent.co.uk/news/ob...y-2240870.html
Image sources:
1. wikipedia.org
2. dailytech.com
3. airliners.net
4. russianplanes.net
5. su-27flanker.com
6.
www.flankers-site.co.uk
7.
http://www.aer.ita.br
