Team-BHP > Commercial Vehicles
Old 19th December 2013, 07:12   #1
ranjithrnath's Avatar
Thanked: 144 Times
Isuzu IS12TE Bus - Built by OJES
Found a pic of ISUZU IS12TE Bus in kerala built by OJES.
Pic credit Ojes Automobiles
Specifications:
ISUZU Bus Chassis
Model : IS12TE
Wheelbase (mm) 4500
Engine Model and identification 4HK 1 XS - Euro III Compliant
Overall Length(mm) 8430
Displacement (cc) 5193
No. of cylinders FOUR INLINE
Max. Torque, Nm @ rpm 396 Nm@ 1500 - 2000 rpm
Max. Engine Output 110 kW
GB Type MZZ6U 6 SPEED OVERDRIVE
No. of gears 6 FORWARD + 1 REVERSE
GVW (Kg) 12565
Tyres Size 8.25 x 20 – 16 PR
Seating capacity 32+D
This bus KL 59 F 5344 registered in SRTO, THALIPARAMBA, Kannur District was sold in July 2012.
The chassis alone cost 11.77 lakhs for a 110kw,6 speed,12T GVW.
Finally Lynx and 1112 got a bigger competitor.
ranjithrnath is offline   (6) Thanks
Old 19th December 2013, 14:40   #2
TheARUN's Avatar
Thanked: 988 Times
I think this would be registered as an ICV
What is the seating layout? Is it 2x2 or 2x1?
The advantage with Lynx is that it is wide enough to enable 2x2 seating
Is there a BS4 option available? If not then this cannot be registered in a Metro
Thanks for the information though. It's a threat to the Ultra too, and Ojes stamp is clearly visible on the design
TheARUN is offline
Old 20th December 2013, 11:08   #3
DWind's Avatar
Thanked: 238 Times
re: Isuzu IS12TE Bus - Built by OJES
As per specs it is Euro III (may not be direct map to BS III) and I see stickers with Euro IV. How would this bus pass FC with RTO?
DWind is offline
Old 20th December 2013, 11:27   #4
deetjohn's Avatar
Thanked: 10,594 Times
Its front engine layout right? Wonder where the ventilation is. Is the idea to keep the grille open during the run?
deetjohn is offline
Old 20th December 2013, 23:33   #5
Thanked: 144 Times
Re: Isuzu IS12TE Bus - Built by OJES
Yes, it is a front engine layout. Even the older Eicher Skyline 10.75 mini buses didn't have any grille for ventilation.
Mod Note : It is now imperative for you to upload pictures directly to the Team-BHP Server. Click here to view our pictorial help article on uploading pics.
Please submit images ONLY via the Team-BHP Attachment System.
Old 21st December 2013, 05:44   #6
deetjohn's Avatar
Look at those air dams on the bumper, that gets air into the engine room. In contrast the bus doesn't have any opening other than the closed grille.
deetjohn is offline
Old 21st December 2013, 12:20   #7
binaiks's Avatar
Thanked: 1,164 Times
Siddhaganga Tours Bangalore has a couple of these as well. Their feedback is positive on them, from what I heard.
A pic of Siddhaganga's Isuzu bus, with a Sutlej body:
binaiks is offline
Old 21st December 2013, 14:58   #8
Ashley2's Avatar
Thanked: 1,526 Times
Unlike Eicher, Isuzu has a bigger engine, which definitely requires proper ventilation. Leave away ventilation how come clutch reservoir, DAT, radiator etc can be accessed? In many cases including prominent body builders like Prakash doesn't really have the sense of serviceability in mind when they build body. Also removing essential components like fuel pump itself has become troublesome and fitment requires skills which actually need not be required.
Ashley2 is offline
