Re: How do Multi-axle Trucks Turn? Quote:
Originally Posted by norhog ...
I guess these trucks and now multi axel volvo buses will be laying down some rubber on our ghats. |
If you have differential in non-steerable axle, there will be no additional wear. But in case if the truck or bus is with non-steerable rear axle, you will have more tyre wear. Quote:
Originally Posted by dhawcash ..
Also, You must have noticed Multi axle Tata trucks which have 4 axles in total. The second one- right behind the front axle is supported on air springs and can be raised or lowered depending on the vehicle load. Guess how this one steers?
It has no direct connection with the steering wheel, and is supported on follower wheels- much like a wheel-chair's front wheels - so they turn to follow the trajectory of the front wheels. Some trucks in which this axle cannot be raised, have the second axle connected to the steering system as well. |
These are the same front axles (with same axle arm, king pin, axle beam etc,) but there will be a stopper and due to which it can't be steered. Also since this is freely supported you can note that even during straight line coasting, the tyres will somewhat have a move in a zigzag manner. Quote:
While searching for an image, i came across this tata truck which has the follower wheel arrangement in the rear most axle. As you can see the axle is raised above ground and seems to be turned slightly- that is because its not connected to the steering mechanism and will follow the axle in front of it by design when it is lowered. Also notice that the steerable last axle is only a helper axle. the main heavy duty axles still dont have steering to keep costs and reliability in check. |
37T has two types of arrangement. Tata has a tag lift axle and AL has a pusher lift axle. Both are not steerable. I think Tata will have additional advantage of reduced tyre wear. Quote:
Originally Posted by norhog ...I saw some kind of hydraulic Ram connected to the second axel from front on a Ashok Leyland truck. Also the Ashok Leyland system has leaf springs and not air bellows as in case with TATA. Another point here since the second axel being a follower, during reversing it needs to be lifted up or some other thing is at play here?? | Quote:
Originally Posted by silversteed ...... AFAIK, the lift axle is lowered automatically when the GVW exceeds some limit (not sure if it was 19T or 21T). While reversing, this axle has to be lifted, or else they drag and make it difficult. Since haulage trucks don't have to reverse very often, truckers live with this handicap to enjoy the savings in terms of tyre wear when the truck is not loaded. |
The axle lifting is auto when the GVW is less than 25T.
Also during reversing its obviously necessary to lift the axle. If not the truck will only drag and will not steer.This feature is present and truckers need not compromise. Plz note haulage trucks will have to reverse more often than passenger cars every now and then when they are to be parked / unloaded.
Also there is no marked improvement in tyre performance in case of lift axle. The tyre saved during lifting is compromised with the additional wear during running. The proven advantage is improved fuel performance when the return load is empty. Quote:
Originally Posted by dhawcash Im not too sure about the hydraulic ram thing in ashok leyland- maybe they implemented hydraulics to steer the axle. But in tata trucks with the follower wheel arrangement, there is a spring and damper attached to the wheels to keep them from dangling here and there while raised. | Quote:
Originally Posted by silversteed All trucks use hydraulic power steering, hence what you are referring to might belong to the PS system. |
The hydraulic ram connects two front axle steering knuckle / track rod and facilitates steering. The two front axles will turn equally and hydraulic ram does this job. |
