Regret for delayed reply, Dr. Sen.
Originally Posted by dr. sen - Moffusil Areas (average running 210 to 270 km, to and fro). |
Yes there are operators who run Lynx for stage carriage application in Bihar / WB / JH etc. In those areas, sales is more towards Cheetah, so they look at Lynx, as a 4 cylinder Cheetah. The aggregates of Lynx are as good as a Cheetah, but offered in a smaller bus. The mileage is better than full size Cheetah and with reduced price of more than 2 lakhs, the deal is better. You have options of 3 wheel base – 4900 (9M) /4200(8M) /3900 (7.5M) in Lynx.
The other option you have is LP1512/52 (9.5M)
Originally Posted by dr. sen - Long distance (about 700- 800 km / day. |
I understand the running kms are 700 to 800 kms two ways. In that case you can look at Viking 222” (10.8M). Unless otherwise you have high level of occupancy you need not look at 12M. Plz note between 12M and Viking there will be hardly ~60 to 70k difference in price, and all the major aggregates are common, and hence point of decision is only occupancy.
Next option is TM LPO1512/55 10.6M
In case you are running 700 to 800 kms one way, you will have to definitely go for 12M CRS variant (225 hp). This will be tad costlier but still you have considerable saving in turn around time, which will turn to your USP. This comes with air suspension / retarder as standard fitment.
No equivalent product in TM and nearest will only be LPO 1618. Between LPO 1618 and 12M CRS, you can go for 12M as it’s a better packaged all-rounder in terms of faster turn around time and mileage and comfort.
Originally Posted by dr. sen Would it be possible to sum up, after a first hand experience of Working / Running both AL & TML buses, which is currently the best |
Dr. Sen, now something important. Decision making:
There are some fine levels of difference that makes the decision favoring AL or TM.
AL has increased its market share post BS III consistently and now it stands nearly 56%. Clearly In line FIP is doing the magic here. Also as stated by V1kram, AL has lesser niggles / issues compared to TM.
In case of Tata, you can sure shot say it will be the cheapest (after discounts) among two. Say a difference of 30k will turn to savings of nearly 3.6 lks. Also they may offer cheaper spares, which need not be the case of with AL.
The one reason I am not quoting mileage of Tata is, I have seen Cummins engines performing a huge binomial curve after years of performance. Means the fuel performance drops after some 3.5 to 4 lks kms of operation considerably whereas the curve is more of a flat or with reduced gradient in case of AL - H Series engines (Good or bad).
Plz note in any engine there will be a drop after the said period, and I am speaking only about the difference in mileage.
Choose a brand/product that best fits the bill - service support / resale value / parts availability / mechanics availability / no of years of operation etc. Take a decision based on that.
As you are going for a fleet of 12 buses, I suggest you may / should have your mechanics to maintain your buses. This is the cheapest and better option. We will speak more on this once you get through the process of buying the chassis.
Originally Posted by dr. sen Can one safely expect a 5 km / lit for the first case and around 4 in the second case. |
Unfortunately there is no safe limit, as geographies vary from area to area. The definition of long distance vary between 4 lane roads in TN to ghat roads in WB / Sikkim. Similarly for city roads, its an equivalent 2 lane road in KL to smaller narrower roads in KA (Mangalore area).
City roads becomes equivalent to long distances and long distance becomes equal to ghat roads in different areas.
So check with your peers and have a target of 5% better than them- which should be achievable.
And finally my heartiest and sincere wishes for you to successfully start your transport business. More miles ahead!
