Old 4th February 2011, 13:57   #1
Repairing my amplifier
I have a Pioneer GMX-944 Amp installed in my SX4. I have been using this amp for quite some years. Yesterday one of the channel on my amp started playing a bit weird. By weird I mean the sound keeps flickering and goes blank and at times it gives a balrring sound. Not sure what this is ?
Can anyone tell me what might be the possible issue ? (Assuming you guys might have come across this issue)
abhijithvarma is offline
Old 4th February 2011, 15:08   #2
DerAlte's Avatar
Thanked: 2,920 Times
re: Repairing my amplifier
Take the amp to a Pioneer service center, or a competent electronics technician. This is due to either a solder joint gone/going loose, or a component (probably a capacitor or a potentiometer) saying final prayers.
DerAlte is offline
Old 4th February 2011, 15:28   #3
Thanks DerAlte for your quick response.
Found a technician in Mumbai. Said He is gonna take a look at it. His intial diagnosis was also the Soldering going loose. I have dropped the amp with him. He is gonna get back to me by tomorrow. Have my fingers crossed.
Old 4th February 2011, 16:56   #4
Thanked: 321,245 Times
Hi Abhijith,
It's a known issue with Pioneer 944s; I had one myself, which suffered from the same problem after 6 years of use. The capacitor had gone bad. I don't know whether it was repaired or replaced, but Bharat Auto charged me 600 bucks for the same. However, note that after a while the problem resurfaced in another channel. So maybe, it's a good idea to have all of them checked up while it's at your mechanics.
GTO is offline
Old 4th February 2011, 17:25   #5
jatinpatel's Avatar
Thanked: 196 Times
Hey abhijith,
I also use the same GMX-944 amp in my tiny its 8.5years old.
I had two issues with the amp
1. Solder going dry which got sorted but resurfaced again.
2.Mosffets went bust on the front channel so decided to replace all this sorted out my 1st issue too.
The total repair cost was 1200rs Got it repaired from my installer FM drive in santacruz.
PM me if you need the contact details for the same.
Its better to replace the mosffets and have peace of mind for a long time, and after the new mosffets the output has become good and even more clean.
jatinpatel is offline
Old 5th February 2011, 17:59   #6
It was the Solder going dry. Got i re-soldered. Its working fine now. I have also been facing some issues around my equalizer. I will post a new thread for that.
Thank you Ol Man,GTO and Jatin.
Old 26th June 2019, 15:55   #7
Thanked: 22 Times
BMW 3 GT - Amplifier Repair anyone?
Hi All,
In another thread I talked about regarding a leakage through the sunroof drains on my BMW 3 GT. Water landed on the amplifier area and the amplifier has fried. Buying a new one will cost me about 70k upwards.
I wanted to look at options that I want to take your opinions on. Its a Lear amp.
1. Repair the amp - Im really looking for this option. Do you have anyone/trusted/tested repair guy in Pune/Mumbai who can repair amps. I don't think its too much of rocket science and Im sure there must be someone out there who does it.
2. Buy a new one from Germany/US. I have a few friends who can get one from there if it makes sense. Will it be compatible, etc etc.
3. Buy a upgrade/alternative that is compatible. Suggest all alternatives that could be at least cheaper and provide the same output.
4. Is there any second hand market for this amp.
5. All alternate solutions are welcome.
spirits999 is offline
Old 29th June 2019, 15:34   #8
Thanked: 22 Times
Re: Repairing my amplifier
Dear mods,
I don’t know why my thread was attached to this thread. There are a lot more other concerns I’ve raised that has nothing to do with this thread. The views have gone down and haven’t received even one view after the thread came under this. Obviously it’s not helping any.
Could you please move it out under the main topic car entertainment.
Old 1st July 2019, 14:55   #9
navin's Avatar
Thanked: 9,948 Times
I assume this is an OEM amplifier from BMW. The one person who might be able to help you get this amp repaired in Mumbai is member Bass and Trouble. He has repaired my Steg amplifiers when they got flooded.
Since this is an OEM amplifier I cannot give you any suggestions about a replacement as there might be some DSP built into the amplifier specific for the BMW GT3.
For this same reason only another GT3 customer would be able to use this amplifier hence the second hand market for this is amplifier is pretty limited.
Dear mods,
Your post was moved into a thread for amplifier repair. This way any other members looking for amplifier repairs would have only one thread to search.
navin is offline
Old 1st July 2019, 15:15   #10
Thanked: 22 Times
Thanks for your reply Navin.
May be ill get in touch with Bass and Trouble.
Secondly, yes I understand, it moved because of Amplifier repair. While my queries is not limited to only repair and hence the audience is going to be lesser. If i post a separate question of just an Upgrade, a lot more audience is going to look at it and give their suggestions. Right now it is completely limiting the audience to only people who are looking for a amplifier repair.
Old 1st July 2019, 15:27   #11
navin's Avatar
OEM equipment rarely has an equivalent. This is because the OEM amplifiers and head units have built in DSP processing that the specific for that ONE model of car it was designed for.
If you were looking for a upgrade you would have to consider a system that includes a DSP and an amplifier.
navin is offline   (1) Thanks
