Old 26th September 2005, 13:26   #106
navin's Avatar
Thanked: 9,457 Times
I heard the same about them as well as those garages behind Juhu garden. But when i talked to Suraj Bhalla of Team Motor Works I found him ok. It depends how you come to them. If you come to them and say "give me the latest" and dont discuss cost they'll do just that.
A knowledgeable customer is the best customer.
navin is offline
Old 26th September 2005, 15:19   #107
Thanked: 7 Times
I liked that. And thanks to you all, I have accumulated all my knowledge by going through your threads in TBHP. I can now talk to them in their own language.
Scorp72 is offline
Old 26th September 2005, 16:26   #108
navin's Avatar
best of luck scorp. glad we could help.
navin is offline
Old 26th September 2005, 16:44   #109
Thanked: 7 Times
Navin,
Have'nt heard from Sam today. Not sure if he could have suggested a better deal than what I already have. But I need to get this done sooner ratehr than later. Can you let me know the answer for the below 2 queries:
"Can I power the 936 only with the HU instead of a seperate Amp (like Sony 502z) ?
Do you recommend any Sub with a built-in amp instead of the CS1200T ?"
Also, in another thread, you mentioned using the 426e in the rear too instead of the 936. Since the comps cannnot be powered by the HU, can I just install some local co-axials (to be powered by the HU)
I am going to another dealer tomorrow evening. Will be checking out his quotes and finalizing between the 2.
Scorp72 is offline
Old 26th September 2005, 16:56   #110
navin's Avatar
PM him if you want him. I think he is busy.
I am a bit confused i thought you were getting 2 amps a 504 and a 502.
anyway if you are getting only the 502 you'll need that to power the sub. and i dont know of an active sub that will come cheaper than a seperate 502 and a sub.
If you are getting only a 504 and if you use 2 channels for the front components and 2 channels for the sub this will work WELL only if your HU has 3 pairs of pre out (front, rear and SUB) OR unless your HU allows the RCA and speaker outputs to be used together. Check with the installer.
In this case the front RCA and rear RCA go the 504. the 504 then has HPF on for the front speakers and LPF on for the sub. The Rear speaker out of the HU then feeds the rear speakers which could be 4-5" coax drivers.
I would sugest that you can get decent coax drivers for the rear so as not to mess up the sound by introducing any poor sound in the car. The drivers can be whatever fits in the speaker pods in the rear.
navin is offline
Old 26th September 2005, 17:28   #111
Thanked: 7 Times
The only reason for thinking of having an active sub is that I am not sure, how good a match the 502z is to the 1200T ?
Scorp72 is offline
Old 26th September 2005, 17:35   #112
Sam Kapasi's Avatar
Thanked: 2,438 Times
Hello!!
Prices are decent. Go Ahead. The 502 bridged is a pretty decent match with the 1200T.
Sam Kapasi is offline
Old 26th September 2005, 17:41   #113
Thanked: 7 Times
At last, a reply from the busy man. Okey, I will not mess up the setup by asking more questions. 'I' will get confused with the possibilities.
Any good installers around Bandra/SantaCruz area ? Any idea how this guy "FM Drive" is ? He is situated around the Benetton showroom on Linking Road (Khar side). Recommended by a friend's friend !!!
Scorp72 is offline
Old 26th September 2005, 17:56   #114
Sam Kapasi's Avatar
Sorry man, have really been busy busy busy. The right person to ask is firoz. Chief of Mumbai JBL car Audio. 9819850106
Old 26th September 2005, 18:24   #115
Thanked: 7 Times
Will talk to him right away. Need this done on my car ASAP.
Scorp72 is offline
Old 26th September 2005, 18:39   #116
Thanked: 7 Times
Sam, spoke to Firoz. Am meeting him tomorrow. Thanks !
Scorp72 is offline
Old 27th September 2005, 11:02   #117
navin's Avatar
Now that is a nice car Sam. esp the 5 life jackets.
navin is offline
Old 27th September 2005, 11:50   #118
jkdas's Avatar
Thanked: 1,492 Times
u zoomed teh picture?
and @Scorp ru going for 426 at frnt? i thought corsa could take 606 or so at the frnt.
i haev 426 at frnt and 606 at the rear
jkdas is offline
Old 27th September 2005, 12:33   #119
Thanked: 7 Times
Yes, I am. Not sure if Corsa can take the 606. Will check this with the dealer today.
Scorp72 is offline
Old 27th September 2005, 13:09   #120
navin's Avatar
jk, no need for zoom. as you get to my age you devleop radar for such sights. :-)
I think the corsa fronts are 5".
navin is offline
