Originally Posted by tsk13 Off-topic, there is a hiss from the rear JBL Co-axials in my car post the Amp+Sub setup ... |
Could you describe your whole setup? Are the rears connected to the amp, or the HU? How loud is the hiss? Are you only able to just hear it when no music is playing, or are you hearing the hiss all the time?
Originally Posted by S.I.N.G.H ... i do apologise for that.
now comming to the point, FINALLY WHAT SHOULD I DO AND WHERE IN DELHI SHOULD I GO WITH A BUDGET OF AROUND 12K TO UPGRADE MY ICE. |
No apologies necessary, shereya, it is always possible to misunderstand!
Think of an upgrade only after you have understood what you are missing or what has not been properly used / set in your current system. Despite the fact that Sony raises everyones hackles here, just try to meet up with LBM or Panky or some of the Delhi TBHPians who have ICEd their cars - they will be able to retune your system. Once a limit has been reached, you can compare with their systems and figure out what you need to change. Quite likely your rears have been tuned far louder than the front, and with sub playing full blast the rear is completely overpowering the front image.
You could also try tuning it yourself (I am assuming rear speakers are connected to the amp):
1. Set amp gains to 0 (both pairs of channels)
2. Set Fader to full front
3. Set ALL tone controls to 0 - no Bass boost or Treble boost, no EQ selection
4. Play some familiar music from CD
5. Set HU volume to 1/3 full scale, or whatever level is the normal listening volume for you. Now set Fader to center (F0 or 0)
6. Slowly increase the gain of the channels feeding the rear speakers (sub still 0) till the music is at a comfortable volume for a rear seat passenger, but not enough that you hear the rear channel in the driver's seat
7. Now increase the gain of the channels feeding the sub, till you just hear the sub in the driver's seat
8. Increase and decrease the volume from HU to see if both front and rear increase and decrease with the same proportion
9. At low volume, it may seem that the sub is not playing at all. If you now increase the gain to the sub, at a loud volume the bass may seem very loud. Try and achieve a balance between the two
If in case the fronts are connected to the amp and the rear to HU, start by setting the Fader to full rear and setting the rear volume at the HU to a comfortable volume. Now set Fader to center and then increase the amp gain to front speakers till you hear front speakers more than rear. Cross check by setting Fader to full front to see if rears become almost silent.
Don't worry, you only need a screw-driver suitable for the gain knob, and a bit of self-confidence. All the best! If you need someone to help you get the tuning right, ask a family member to be the listener.
