Originally Posted by navin |
Gurudev i should have asked this to you only, but forgot to check more relaible sources. Quote:
Originally Posted by navin 2. 6" have twice the cone area (Sd) of a 4" and usually 50% more cone travel (Xmax) than a 4". That menas that they can move 3 times more air than a 4" and hence produce more bass. Since in a car the subwoofer is rarely located in the front of teh car it makes sense to at least have a 6" woofer in the front. A 6" will be limited to about 60Hz and a 4" to about 100Hz. Although this difference (60 to 100Hz) is less than an octave it also falls in the area where road noise is most prevalent and hence a 6" in the front makes more sense.
3. A 6" woofer will have more limited dispersion when compared to a 4" the difference is usually in the range from 1200 to 3000Hz. After 3kHz even a 4" woofer's off axis response falls. Mix this with the fact that most 6" wofoers are located somewhere between your ankles and your knees and you wonder how to can hear any midrange at all. A 4" on your dash however will refelct off the windscreen so in theory it's response should also be inaccurate. Fortunately our ears, brain and to some degree the odd mix of materials (soft carpet and seats and hard dash and glass) in a car compesate for all of this.
4. Most music is not mixed to heard over headphones. Mixing engineers usually use what the industry calls "Monitor" speakers for this purpose. These speakers are usually (if we disregard the good ones like BBC, Sheffiled Sound, etc..) a 2 way placed over the mixing console.
Since the engineer is located very close to the monitor he mixes the sound accordingly. When the CD produced by this mix is played on your home stereo the bass gets support for boundary reflections reducing the relative level of the midrange, besides there midrange suffers from smear due to similar reflections and hence becomes a bit un-intelligible so the brain focusses on what is intelligible.
When the same CD is played on your ipod the midrange is not recessed or smeared and hence you hear the vocals more clearly. The ear is very senstive to the midrange so differences in this area are most obvious.. |
So thats why emphasis is more in front speakers. Whatever is their position, dashboard or doors, they are more directional than the rear speakers. And Mostly Rear ones are used as fillers.
If this is the case than it shouldn't make sense to invest more on rear speakers relative to front ones. A simple 4" coaxials will do the job. Please correct me wherever I am wrong. Quote:
Originally Posted by navin Sorry for the rant. |
Boss one can make out from all your posts, that its not just a hobby, you simply love music in real sense. And by seeing the way you write anybody can make out that you knows what you are saying. Whatever you wish to call it, we wish to have more of it.
