Old 14th April 2008, 20:47   #7906
mohang_j's Avatar
Thanked: 18 Times
Connecting cs 60.2 to drive sub in bridge mode.
Gurus,
I have brought jbl cs60.2 amp, how do i connect it in brdge mode to drive cs1204 sub.I have Pioneer 3050ub HU.It has 2 RCA out and Rear out can be configured as sub out.Confused a bit since i am getting no deference in output when i connect in bridge mode / single channel.
mohang_j is offline
Old 14th April 2008, 21:12   #7907
greenhorn's Avatar
Thanked: 4,678 Times
just learnt that there are no more Dieci components available. But gunbir's clearance sale prices are yummy
I still have a fixation about my 4" dash location. So was wondering, what if i buy a 6.5" coax and a 4" coax, and wire them up with a homebrew 1st or 2nd order crossover? Alternately, i can get just the 6.5" coax, snip the wires off its tweeter, and use a DT 16 with its own crossover. both will cost about the same as the comps. But I'm leaning towards the first option, since I can then put in an L-pad and tune it the way i want it.
Do you guys think i'm going overboard with the DIY?
more importantly, will it sound worse than the comps?
greenhorn is online now
Old 14th April 2008, 23:53   #7908
somebodystopme's Avatar
Thanked: 43 Times
No actually 10 K is my budget for just 2 speakers. HU is seperate. Have already decided on Pioneer Hu since I have 7950UB on my other car and is running Great for more than a year now.
There is provision for speakers coaxials on rear doors. So I think since am not getting and amp so two speakers are enough. I am thinking about JBL for the timebeing.
somebodystopme is offline
Old 16th April 2008, 22:53   #7909
amit_mechengg's Avatar
Thanked: 2,253 Times
gurus, is there any specific method how to write a mp3 disc for good quality songs. i have observed that same songs play good on one of my older cd than it sounds on the cd which i have written right now.
also i find a difference in the quality of songs that are played from USB and that on CD
amit_mechengg is offline
Old 16th April 2008, 23:17   #7910
vebmetal's Avatar
Thanked: 21 Times
If it's the same bitrate, theoretically there should be no difference. If there is any difference at all I would anticipate usb to be better. If you have problem with skipping etc. try burning at a lower speed. Generally speaking CDs and DVDs burn better at lower speeds.
vebmetal is offline
Old 17th April 2008, 09:44   #7911
hrsraghav's Avatar
Thanked: 24 Times
Yaa i too have noticed this thing. The songs played from USB are not that good compared to the same songs of same bit rate from a CD (copied from same location).
I dont know whats the reason behind it.
hrsraghav is offline
Old 17th April 2008, 09:58   #7912
SRShrikanth's Avatar
ICE Gurus....help required.
The ICE in my car is complete Blaupunkt now.
Recently, the HU was changed from Sony to Hamburg 57.
After the change, a peculiar issue cropped up.
Whilst accelerating from stop onwards - with A/C ON & the muzik files being read from the USB - there is a corresponding whillstling sound from the muzik system....
It parallels my acceleration rate.
However, if i swicth off the AC and reach 40-50kmph in 3rd gear and then swicth the ac on - no whistle then.!!!
What could be the concern area for this issue plssss.
& how can i recitify it - if anyone hear has come across something similar.
Thanx in advance
SRShrikanth is offline
Old 17th April 2008, 11:31   #7913
Thanx in advance
you are suffering from alternator whine. please search Alternator Whine on the forum and you will get all the answers of your problem.
Old 17th April 2008, 11:40   #7914
greenhorn's Avatar
Could you specify in what manner there is less quality
1) digital artifacts ( ie does it sound like lower bitrate)
2) skipping
3) resampling issues ( try the same song after resampling to 48 khz with a good external resampler in the PC )
4) decoding issues - if the HU supports, try playing a decompressed wav of the same song from the USB
Old 17th April 2008, 14:44   #7915
Hi , JBL are good speakers and should get the 300 W at around 3 to 3.5k. Also if your budget is 10k consider putting component jbl in your front as well for around 3k and maybe a 2 channel amp connected to your rear speakers. You should be able to hear good music then. Cheers !
maverick74 is offline
Old 17th April 2008, 22:18   #7916
hrsraghav's Avatar
Thanked: 24 Times
2) skipping
I would say the overall quality goes down, I can't say about bitrate, but it sounds like the track is not picking all the frequencies of music.
Old 17th April 2008, 22:48   #7917
i have the same song written on a disc and the same song copied to USB. yes i too observe the same thing. some frequencies, i think mostly the higher ones are lost as i feel lack in trebble and frequencies heard from tweeters.
Old 17th April 2008, 22:59   #7918
Thanked: 71 Times
Pioneers normally have different memories for equalizers for different sources. Have you checked equalizer settings for CD and USB?.
There is also SLA (source level adjustment) check that also.
alto99 is offline
Old 17th April 2008, 23:05   #7919
Sam Kapasi's Avatar
Thanked: 2,438 Times
As veb pointed out, theoretically this is impossible. Allow me to explain.
MP3 is not audio, it is data that can be decoded into audio. The only difference between the data on your USB and on your CD is the medium. The USB stick has solid state memory chips, while the CD has on on a vinyl layer that needs to be read by a laser diode.
If at all, the CD will have jitter and will be slower to read than the USB.
Theoretically the same MP3 data should sound the same, whether on CD or on the USB pendrive. If it sounds different, I would be surprised.
Sam Kapasi is offline
Old 17th April 2008, 23:24   #7920
@ SAM Sir,
Believe me sir, i too think usb should sound clear. but cd produces sounds in all frequencies while usb omits the higher frequencies , the tweeters sound empty
