Old 30th March 2008, 16:18   #7786
DerAlte's Avatar
Thanked: 2,920 Times
Around 6K with b&w, I think.
DerAlte is offline
Old 30th March 2008, 17:54   #7787
nishantgandhi's Avatar
Thanked: 156 Times
Is that 6K for JBL gt5-a604 or Blau GTA 4 ch amp?
How much w/o B&W?
How are JBL gt5-a604 and Blau GTA 4 ch amp compared to Pioneer 6300 and Kenwood 8401?
nishantgandhi is offline
Old 30th March 2008, 17:55   #7788
adityamunshi's Avatar
And also how are they compared to each other ?
How much w/o B&W?
adityamunshi is offline
Old 30th March 2008, 18:15   #7789
DerAlte's Avatar
Not different like chalk and cheese, but they have their own sound signatures.
The 8401 is comparable. According to @rocksterraghu, the 6300 is not up to scratch (http://www.team-bhp.com/forum/produc...tml#post776967).
JBL GT5-A604: Dippy got it for 8K with b&w in Mumbai (http://www.team-bhp.com/forum/sound-...tml#post699043), and it is 5K in grey in Bangalore
Blaupunkt GTA4 Mark II Special: 6K with b&w in Bangalore
DerAlte is offline
Old 30th March 2008, 23:22   #7790
tush's Avatar
Thanked: 12 Times
Originally Posted by adityamunshi View Post
Guys, Any idea about the current prices of JBL gt5-a604 and Blau GTA 4 ch amp ?
Blau GTA 4 special - 6350/-
tush is offline
Old 31st March 2008, 02:26   #7791
I have poineer DEH-P9650MP head unit, sound stream EGA5700 amplifier with 5 channel out of 700 watts. 4 bosten speakers with 2 normal tweeters and a JL subwoofer of 12'' 4 ohms 100-300 rms power range,22-220hz frequency. I would like to provide a additional amplifier only for the s/w to get a better bass out. can u advice me which is the best and ideal with a reasonable budget. I am in bahrain.
cheers.
supersonic is offline
Old 31st March 2008, 11:06   #7792
Thanked: 7 Times
hey guys... would u please suggest a good headunit, not too expensive around 6-7k....
one dealer told me that pioneer4050 with b&W will b 6.8k
wht do you say... is it good... any other suggestions
ihkhan is offline
Old 31st March 2008, 11:13   #7793
DerAlte's Avatar
Originally Posted by supersonic View Post
... I would like to provide a additional amplifier only for the s/w to get a better bass out. can u advice me which is the best and ideal with a reasonable budget. I am in bahrain.
cheers.
Is your sub single voice coil or dual voice coil? What type of box is the sub mounted in?
With a sub of 300W and an amp capable of 200W@4/300W@2, you are quite well matched. However, another amp will not necessarily help you since you will be limited by the sub then. You could add a 500W rms mono block, but your sub will pump only 300W - or burnt itself out trying to do more.
A safer option would be to add another 4 ohms sub, wiring it in parallel with the current sub to get 2 ohms effectively, so that the current amp can dump 300W it is capable of. Another sub will double the surface area, and you are likely to perceive more loudness in the lows.
DerAlte is offline
Old 31st March 2008, 11:25   #7794
amit_mechengg's Avatar
Thanked: 2,263 Times
i am having jbl gto 937 6" X 9" ovals and a GT5-12" sub powered by jbl 75.4 amp.i am finding the setup a bit bright with the settings done on my amps.
how can i set it perfectly so that i make them sound a bit soft.
the GTO 937 are in small boxes at the rear and not on tray(infinite baffle)
the Sub is in ported enclosure. i fire it with REV sub settings on HU.(pio 5050)
EQ1 settings : L0 M(0-2) H(0-2)
EQ2 settings : LOW 80khz Q1
MID 500khz Q2
HI 10khz W2
SUB settings : 80 kHZ 0hz
HPF settings : 50-80 HZ
Sound retriever : 2
Loudness : MID
amit_mechengg is offline
Old 31st March 2008, 11:56   #7795
navin's Avatar
Thanked: 9,957 Times
MID 500khz Q2
HI 10khz W2
Sound retriever : 2
Loudness : MID
firstly I think you have mixed up kHz and Hz and maybe EQ and XO too.
Next start with all EQ settings being flat. then decide if you need to reduce the brightness.
XO for the sub (LPF) and for the front and rear (HPF) speakers can start at 80Hz.
Ideally one first tunes XO of the front speakers seeing how low the front speakers can go. The lower the better. 63Hz/12db is not uncommon.
Then one integrates the sub to the front speakers and lastly one brings in the rear fill.
navin is offline
Old 31st March 2008, 12:04   #7796
Technocrat's Avatar
Thanked: 2,705 Times
Navin, the front speakers are normal 4 inchers Sony\Kenwood\Pio I think. Also in his case rear fills are powered by amp, he has rear sound stage as of now.
Technocrat is offline
Old 31st March 2008, 12:07   #7797
i dont have a good speakers in the front.they are sony coaxials 4" that fit in alto. what i feel is all sound coming from the rear. the brightness is so felt that i start getting irritated after a while. also with the same flat setting the radio doesnt sound good at all. for radio i have to increase the M to 2 and H to 4 ( EQ1 settings) and also SLA to 4. i feel the vocals are lost when i listen to radio or USB. with CD its fine.
Old 31st March 2008, 13:18   #7798
navin's Avatar
Well the 4" sony are not great speakers so this phenomenon (all the sound comng from the rear) is understandable.
given that radio is a compressed format it will not sound the same as CD. one option is to store 2 different settings one for radio and the othe for CD in your HU's memory (if it has this feature).
navin is offline
Old 31st March 2008, 13:29   #7799
ya i know those sonys are not good.they hardly sound with respect to the rear ones. as technocrat said rightly i am right now having a rear sound stage, that too with JBL it sounds bright. i am waiting for a GZ MK2 sub. i hope it makes a difference. also i am finding sources to cut my door trims perfectly to accomodate 6" illusion components
Old 1st April 2008, 10:24   #7800
Technocrat's Avatar
Amit a sub will have no impact on brightness of your ICE. Putting up comps at front might have depending on how bright you find them.
