Originally Posted by zenx Whats the primary diff in ovals/round ones for the rear - could avoid cutting/spacers unless theres a big diff. I'm saying this only cause all the speakers in my home theatre are round, and of course theres 3 but it sounds very "natural". |
Ovals are used because in a car environment, space is tight. We only generally get a narrow area on which to install speakers in a car (esp. in the rear). To get more bass from a speaker, we need more cone surface area. [And for best stereo effect, we need to install the speakers as far apart (towards the ends of the sides of the car) as possible]. But a bigger round speaker may not fit on [the corners of] a stock rear-parcel shelf (or other location).
So, the shape is stretched to an oval so that we get more cone surface area, as well as a smaller (narrower) install footprint. This narrow install footprint can be anywhere in the car, not just the rear parcel shelf. A 6x9 has the approximate cone surface area of an 8" woofer. We won't be able to fit an 8" woofer in each corner of the rear parcel shelf, right? Some manufacturers like Ford use a smaller oval size, a 5x7".
Some purists say that a proper round speaker will give a better overall response than an oval speaker. I'd read quite a few such arguments on various forums long back. [Maybe we can all fight over it here too. I'm not tech enough, so I'll stand back & listen  ]. I guess this is why in the home environment there are no ovals, just rounds. No space issues -- just sound quality maximisation issues.
The reason I mentioned ovals for your rear is that you don't plan for a sub. So the only way to get some decent bass would be to use ovals. If you do plan for a sub sometime, a 6.5" round speaker would a better (and overall money-wise) choice.
Don't cut your rear parcel shelf for ovals if the current provision allows for only rounds. Just use spacers. You'll be able to get ovals in there. There will be a difference in bass response between 6.5" coaxials and 6x9 coaxials. The 6x9s will give better bass.
Your home speaker setup has 3 round speakers in the same box? That means you probably have a 3-way system. Nice! They would sound quite good! [Shameless self-promotion  -- check out my TBHP Garage. You'll see 3-ways there too].
