Old 8th December 2006, 20:15   #4786
rsjaurr's Avatar
Thanked: 28 Times
right now I have put the fader to F4 which gives decent front stage but if its a song which I want to listen loud I need to set the fader to rear as the front cant handle it, so was wondering if powering the fronts with amp would be of any help? Also its mostly me who wants loud music the rear passengers(whenever there are any) hate it when I pump it up
So u should power ur front spk from amp.Not only u will have more loudness up front but also it will bring more clarity as well.
rsjaurr is offline
Old 9th December 2006, 09:52   #4787
navin's Avatar
Thanked: 9,586 Times
Originally Posted by Technocrat View Post
...so was wondering if powering the fronts with amp would be of any help? ....
the front speakers are jarring not because of too much power but becuase of too much LF. so you can either add a bass blocker (simple 6db/oct HPF) or an amp with a HPF. You'll find your front speakers can play louder that way but the bass will have to come from the rear as you will filtering them out of the front speakers.
navin is online now
Old 9th December 2006, 11:10   #4788
Sam Kapasi's Avatar
Thanked: 2,452 Times
the front speakers are jarring not because of too much power but becuase of too much LF. .
B-I-NGO, B-I-NGO, B-I-NGO and bingo was his name. That's why I suggest, if you are using an amplifier on most 4" coaxial speakers, keep the hpf on to cut at 100Hz.
Sam Kapasi is offline
Old 9th December 2006, 11:56   #4789
navin's Avatar
Originally Posted by Sam Kapasi View Post
B-I-NGO, B-I-NGO, B-I-NGO and bingo was his name..
Sam, it goes and "Bingo was his name-o" trust me I koow nursery rhymes. Can you imagine listening to nursery rhymes via EL34s and ScanSpeaks.
navin is online now
Old 9th December 2006, 20:18   #4790
Technocrat's Avatar
Thanked: 2,703 Times
Thanks Navin :-)
Stupid Q are these bass blockers commonly available at installers? Also any tentative prices if known would help me.
Hmm I think this alone should help, I mean front two 4" sony coax would sound funny I mean how would these powered with amp & all the base coming from sub at boot sound? I mean after powering fronts the rear would not be noticeably heard?
Technocrat is offline
Old 11th December 2006, 10:27   #4791
navin's Avatar
you can build a bass blocker using 2 470uf electrolytic caps connected in series (back to back). if you want to build a nicer bass blocker connect a 1uf ployester cap in parallel to the above back to back combination.
navin is online now
Old 11th December 2006, 11:39   #4792
Sam Kapasi's Avatar
See here Last post
Old 11th December 2006, 11:42   #4793
navin's Avatar
Sam, did you draw this out? wow!
navin is online now
Old 11th December 2006, 11:45   #4794
Technocrat's Avatar
Wow Sam thanks a ton its lot more easier now. Navin's post was bouncer to me(since me not that technical :( ) Now its clear. Mostly i will take a printout of this & go to the installer
Old 11th December 2006, 12:10   #4795
Vipul.Sharma's Avatar
Originally Posted by Bass&Trouble View Post
Wow, Vipul Sharma must be an awfully attractive man to turn on a speaker.
Hey man, Its ok i m new to audio and i m not electronic engineer. I m mechanical engineer. After all budget is also a constraint.........Don't under estimate others man........
Vipul.Sharma is offline
Old 11th December 2006, 14:29   #4796
hydrashok's Avatar
Thanked: 18 Times
Hey vipul, chill! B&T was pulling my leg. :-)
hydrashok is offline
Old 11th December 2006, 14:44   #4797
Its ok yaar.....i m cooooool.........thnks for ur extended help.....
Old 11th December 2006, 21:31   #4798
Sam Kapasi's Avatar
yeah, I saw your post and imagined I was a newbie and, well, just drew it out for the benefit of some. Thanks for the wow though
Old 11th December 2006, 22:43   #4799
hydrashok's Avatar
Thanked: 18 Times
Thanks for the effort, Sam. A picture is really worth a thousand words. It made things completely clear for me too.
Old 12th December 2006, 00:02   #4800
abhibh's Avatar
Thanked: 39 Times
JBLfyed team bhp memebers help needed
One of my frnd owns a M800 and wants to go for a JBL sub or Bass tube. Now the confusion which one will be the best bet from below:
JBL 10 Inch Car Subwoofer - GT4-10
JBL 10 Inch Ported Subwoofer Tube for the Car - CS1004T
JBL 12 Inch Car Subwoofer - GT4-12
JBL 12 Inch Ported Subwoofer Tube For the Car - CS1204T
I think the bass tube is just an enclosure with the 10 and 12 inch sub in it. Please tell me if i am wrong ?
Also is Pio sub good or JBL sub ? Budget 5K - 6K for sub for tube 7K. And are these JBL subs DVC ?
Thanks.
abhibh is offline
