Old 24th October 2005, 14:28   #2071
navin's Avatar
Thanked: 9,398 Times
Originally Posted by k_ajay
somebody gotta tell this guy (seems to be a 5-6" bass relfex 2 way) that the woofer surround might not be designed to stand up to the heat and humidity of a Madras summer. besides Vivek's CCTB still is my top favourite.
BTW have you guys seen this...they are based in Madras.
http://www.yamatoaudio.com/product.htm
navin is offline
Old 24th October 2005, 15:25   #2072
k_ajay's Avatar
Thanked: 1,138 Times
Yep navin... I know of this brand and have also met and talked with a sound enginner from this company. Their office is in this place called R.A.Puram... The guy's name is Anand and he's quite famous with car audio dealers. I think I could get him into this forum.. Has been sometime since I last talked with him...
k_ajay is offline
Old 24th October 2005, 16:10   #2073
Ok people. Finally, I got the parcel tray for my Alto. Out goes my invention. RIP CCTB. Yay! Yay! Hooray! Yipee! And what bass I get from it. I just love this thing.
More importantly, the guy who was fitting the screws was careless and punctured the rubber surround of the 936 with the screw driver. It is a very small hole but what can I do so that it does not start tearing. Maybe I can patch it up with some rubber-based adhesive. I feel miserable.
Vivekphadnis is offline
Old 24th October 2005, 16:31   #2074
Sam Kapasi's Avatar
Thanked: 2,437 Times
careless installer!
Why did one of the leading DIY people in this forum ask someone else to fit his speakers??
A little rubber based glue will help. I think Navin will be able to guide you better on this.
Sam Kapasi is offline
Old 24th October 2005, 16:34   #2075
I told him I would do it myself. He said he would just put in the screws a little so that they do not wobble when I drive. What do I do about it now? It is a small hole.
Old 24th October 2005, 16:41   #2076
navin's Avatar
in my days dunlop used to make a rubber cement that is quite good. it comes in a tube.
1. wash and dry hands well. very well. I would even use acetone to make my hands clean fo this level of work.
2. put a drop of the cement on your finger. then very carefully let a small bead of the solution on th rubber surround.
let it dry. 100% curing happens in 24 hours preferably over night.
hope this helps.
navin is offline
Old 24th October 2005, 16:45   #2077
I am not sure where to get the Dunlop thing. We get a rubber solution to fix tyre punctures and the glue is called Comet. Will that be good? Or how about Fevibond?
What I am worried about is the surround stretching as the cone moves about and tearing more and more.
Old 24th October 2005, 16:56   #2078
navin's Avatar
Fevibond might be better only because it is from a reuputed company. Otherwise see if you can find these....
http://www.loctiteproducts.com/glue.asp?PLID=198
http://www.loctiteproducts.com/glue.asp?PLID=192
navin is offline
Old 24th October 2005, 16:57   #2079
Sam Kapasi's Avatar
You know I really hate it when that happens. Unfortunately i think it's happened to most of us at some point. Thats then I started using a screwdriver and placing my finger as a barrier around the area, in case the screwdriver slips. My finger can heal itself eventually lol
Old 24th October 2005, 16:59   #2080
We do get some Loctite stuff here too. I have used it earlier but am not sure if it is like the one in the link you gave. I will check out the Loctite thing today.
My only hope is that the surround should not start tearing. Boo Hoo.
Old 24th October 2005, 17:03   #2081
Sam Kapasi's Avatar
Vivek i dont think it will tear further on it's own. It's tough butyl rubber. Relax.
Old 24th October 2005, 17:06   #2082
Thanks Sam. That is reassuring. Meanwhile, I will use some Loctite/Fevibond to try and seal it up.
Old 25th October 2005, 11:00   #2083
navin's Avatar
what ever you use dont use any cryoscilicate based stuff.
navin is offline
Old 25th October 2005, 11:05   #2084
mclaren1885's Avatar
Thanked: 46 Times
Infractions: 0/1 (10)
finally the D-day arrives...well done vivek ...so in goes the parcel tray and out goes the CCTB...whew that must be one sigh of relief for vivek aint it my man!!! but lol none of us on this forum will ever forget ur CCTB..haha the tail will continue like navin said and will be passed on from generation to generation...so be prepared to hear about it until our last breaths and maybe a bit longer..
btw what deal did u chalk out with sanjay..and did u enquire about ur amps..
PS: give me a buzz if and when ur free (busiest man on this earth) would love to check out ur car and tell u some secrets about alto too..for all those guys wondering what it is,its gotto do something with engine so better not discuss it here...unless u all want SAM to carry hathoda and run behind me.."engine vengine" haha lol..palio me kya hey...
mclaren1885 is offline
Old 25th October 2005, 11:06   #2085
Sam Kapasi's Avatar
That means, no loctite, no Elfy and no fevikwik
