Old 3rd May 2009, 10:30   #1
chiragh_bir's Avatar
Thanked: 74 Times
Mdf Wood or Partical Wood Sub Box
Guys
Which is the best wood for constructing a Sub Box
I know it has been discussed many times here but am still little confused.
What should be approx thickness of the board ?
chiragh_bir is offline
Old 3rd May 2009, 11:40   #2
karankapoor's Avatar
mdf boards are compressed particle board, and is always recommended to use mdf. .75 inch is the way to go.
karankapoor is offline
Old 3rd May 2009, 12:05   #3
Invinsible's Avatar
Thanked: 62 Times
Particle board is fine to be used in speakers below 100RMS but not recommended for subs. For Subs below 150-200RMS .5 inch MDF should be fine. Anywhere above that .75 inch upto 400-500 RMS. Beyond that I think it's best to go 1 inch thick.
Invinsible is offline
Old 3rd May 2009, 12:19   #4
frankmehta's Avatar
Thanked: 3,667 Times
so basically chiragh needs to go for one inch think mdf board. chiragh, its best you get it made outside, rather than DIY. sub boxes need good air tight corners. get it done by a professional. according to the specs of your subwoofer. i guess, about 1.2-1.3 cu ft.
frankmehta is offline
Old 3rd May 2009, 13:28   #5
Thanked: 74 Times
ok !!
what will go wrong with particle board?
Old 3rd May 2009, 13:34   #6
particle boards are not meant for sub enclosure, it is not as strong as mdf and will not be able to hold the sub woofer weight and the vibration.
Old 3rd May 2009, 13:34   #7
abhibh's Avatar
Thanked: 39 Times
Why not to use particle board:
- it will flex too much specially with the sub you are using
- it can contract and expand due to weather changes
- its is not as strong as MDF
There are other misc. factors too but that concern the one who is making the box and not the end-user.
abhibh is offline
Old 3rd May 2009, 13:53   #8
Thanked: 306 Times
very true....but if cost is not a issue I would go for Alternate material like....Aluminum.
low_bass_makker is offline
Old 3rd May 2009, 14:06   #9
Thanked: 74 Times
got it .
So going for MDF box only !
Old 3rd May 2009, 14:08   #10
abhibh's Avatar
Thanked: 39 Times
Aluminum port or box ?
abhibh is offline
Old 3rd May 2009, 14:12   #11
frankmehta's Avatar
cost for a port would not be much. im quite sure lelo boofers mera(lbm) is talking about a box made of aluminum. or maybe lined with aluminum.
Crutchfield.com - Car Showroom - Road Tests - James Turner's 1989 Honda CRX
check out the enclosure at the bottom.
im not sure if chiragh will take this suggestion, but its something interesting to look at.
Old 3rd May 2009, 15:21   #12
sudev's Avatar
Thanked: 3,250 Times
A bit OT but...
LBM as a manufacturer of MDF I have interacted with lot of people here and abroad and essential concclusion is MDF also has much better acoustic charactertics. I am sure about Aluminum though.
Can you opine?
sudev is offline
Old 3rd May 2009, 16:37   #13
guys what you say on Plexiglas never heard one so asking, anyone.
Old 3rd May 2009, 17:19   #14
frankmehta's Avatar
my dad is into plexiglass, and he says the acoustic properties of plexi are brilliant. but for an enclosure, the thickness of plexi required would be more than the average thickness of mdf required for the same box. this would make things bulky (not important) and FRIGHTENINGLY expensive (very important)
I have seen those plexu boxes abroad, and wanted to build something on those lines last time I did the big upgrade (a month back). but Dad and Ajay both said its not feasible economically, and that MDF would do as good a job, if well made.
Old 3rd May 2009, 22:44   #15
is this comes as sheet like mdf and what about the price can you share it.
