Closed Thread
Old 26th May 2009, 07:47   #106
srikant's Avatar
Thanked: 12 Times
1000$ to 5000$ Thats the way to go on Team BHP. As you get suggestions and get involved budget is long forgotten. Mods please change the title soon.
Congrats on the buy buddy, waiting for the complete installation pics. It would be grateful if you could post WIP pics.
Srikant
srikant is offline
Old 26th May 2009, 10:49   #107
shreyasma's Avatar
Good show buddy! congrats on your progress
shreyasma is offline
Old 26th May 2009, 13:37   #108
Thanked: 571 Times
Good to see the title corrected and moved to right forum!
Just the right place to be - "Show Off"!
That is some serious amount of money and time that you are investing, IBM_J! Good on you to know what you want and walk the whole mile for it!
And I am not even guessing what the end result would be. It would anyway be totally of the scale!
HappyWheels is offline
Old 26th May 2009, 14:10   #109
ibm_jennifer's Avatar
i am sorry, What's WIP?
Theoretically a Car PC should beat any high end head unit as we are using the same room correction algorithm used in Alpine 650 and time alignment algorithm used in Alpine 710. But it wont be easy like playing with knobs.
I just learned the following things in recent days:
The Mic supplied with ARC and RTA is not perfect. I have to invest in a professional studio quality condenser Mic.
None of the VST based EQ is perfect. They are actually affecting the phase and none of them come closer to my RTAS EQ from McDsp. So there is no EQ in car now.
The process should be:
Audio input -> Cross Over -> Room Correction -> Time Alignment -> IRC Loudness Maximizer -> Phase Correction -> RTA
So No EQ, No Reverb, No Dynamics, No Mastering.
ibm_jennifer is offline
Old 26th May 2009, 14:17   #110
Thanked: 306 Times
Work In Progress
low_bass_makker is offline
Old 26th May 2009, 14:29   #111
I have posted many pics already in this thread, isnt it? if you badly want to see the Akon photo, please visit my profile or my personal blog: Building a Car PC in TATA Safari | TATA Safari Club.com
Old 27th May 2009, 21:33   #112
Just received the Monster 401 XLN Pro and Low Profile VGA Cable & Right Angle USB Cable.
And here is the show off:
And here are some of the installed Speakers pictures(I am sorry, again No WIP):
Front Electras. (Why reverse mounted?)
Front Tweeters: (Flush Mounted)
Front Door:
JBL 607 in Rear:
Rear Door:
Old 27th May 2009, 22:09   #113
nitrous's Avatar
Thanked: 333 Times
Jeniffer, Did you spend 80,000 rupees on audio software and 70,000 rupees on RTA software?
Where did you purchase them?
nitrous is offline
Old 27th May 2009, 22:51   #114
Yes Bhai, its not only for my car, I need it for my videoeditingindia.com too. The full version RTA Software alone cost you 2 lacks: NI Sound and Vibration Measurement Suite - Products and Services - National Instruments
No friend, its the total cost I have spend for the software. Including Centrafuse, Satguide India Map, CoreAVC, Mainconcept, Elecard, Webcam Soft, Allocator, Voxengo, Comfort, BS Player, Audiomulch & other VST Plugins).
I didnt counted Win XP, Nero, Cinematize, DIVX & some RTAS Plugins here as I already have multiuser license for them.
Old 28th May 2009, 17:27   #115
esteem_lover's Avatar
Thanked: 513 Times
With such expensive software, don't you think that the audio hardware is seriously lagging behind ? Time for stegs, i suppose, Jenny ?
esteem_lover is offline
Old 28th May 2009, 17:41   #116
abhinav.gupta88's Avatar
Thanked: 341 Times
even if not stegs it deserves some thing really good. 5000$. Thats not even the total amount of my complete ICE. :-D
abhinav.gupta88 is offline
Old 28th May 2009, 18:37   #117
I hope No, The main reason for the Acoustic Software is - None of the speakers available in the Market can reproduce the sound perfectly.
ARC & RTA will compare the frequency response of this Speakers with the reference signal and correct the room acoustic based on the ability of the sound reproduction in the current environment. But If I have a very High End configuration in my Car, there is no need of this software, isn't it? My Aim is to emulate the high end configuration using this setup with the help of Acoustic Correction, Noise Reduction, Time Alignment, Speaker based Frequency Routing, Speaker based EQ, Phase correction and Run time mastering. But I am sure I can achieve some SQ, but not the SPL of the high end configuration.
Will it compete with a High End System: Currently yes in SQ, If I am allowed to play a Lossless audio Song. (I believe So, but I am sure its way better than my $1000 Yamaha HS 2.1 studio monitors on a $800 Mackie VLZ3 Mixer)
But I am still searching for a 2*4Ohm DVC Sub. But couldn't source a good one under my budget as my pockets are almost empty now(!).
Old 28th May 2009, 18:42   #118
Thanked: 341 Times
why not one bigger 2ohm dvc. Check the ground zero radioactive or hydrogen series. Some serious subs on offer.
Old 28th May 2009, 18:53   #119
I have a JBL GTO75.4 in boot and need to use it.
Old 29th May 2009, 11:08   #120
badboyscad's Avatar
Thanked: 483 Times
@ibm_jennifer: Im also using 5.1 setup in my scorputer but the volume control in centrafuse is not working properly, i.e, when i reduce the volume in centrafuse, only the front channels reduce, rear speakers volume remain unchanged. Is there some configuration in centrafuse for colume control for 5.1?
badboyscad is offline
Closed Thread
