Old 12th January 2009, 21:14   #106
sam_786's Avatar
Thanked: 23 Times
Thanks for all the replies guys, Time for some pics
Updates
1. Power Cable upgraded to 0 Gauge Kicker
2. AMPS flush mounted in the boot with a cosmetic cover on top. Cross-overs moved from the front doors to the rear, to make tunning much more eaiser
3. Sub changed to a IDMAX in sealed box
sam_786 is offline
Old 12th January 2009, 21:16   #107
sam_786's Avatar
Thanked: 23 Times
Pics Continued, Sorry for the bad quality, all phone cam pics, Will take better pics.
Lighting is left. Planning Blue neon under the face plate
sam_786 is offline
Old 12th January 2009, 21:31   #108
Thanked: 4,905 Times
whats that 80mm(?) fan for ?
greenhorn is offline
Old 12th January 2009, 21:37   #109
abhinav.gupta88's Avatar
Thanked: 341 Times
Exactly My Question.
What's the fan for.
Also is the IDmax 12" or is it 15"?
abhinav.gupta88 is offline
Old 12th January 2009, 21:43   #110
sam_786's Avatar
Thanked: 23 Times
Its for air circulation.
Right now the fan is not connected as will be putting another fan on the left side.
Note from the Team-BHP Support Staff : Please use the "edit" button if posting within 15 minutes of the first post, instead of creating another back-to-back post
sam_786 is offline
Old 12th January 2009, 21:45   #111
karankapoor's Avatar
good good sam!!!
if i am not mistaken the kicker wiring used is a 0 gauge dual amp wiring kit.
@abhinav its is 12 inch id max 15 inch is in progress id will launch it this summers.
karankapoor is offline
Old 12th January 2009, 21:50   #112
Thanked: 341 Times
So Why not 2 idmax Sam.
You have posted they cannot be installed?
2 IDV3 and 2 IDMAX , wont they require the same space?
Old 12th January 2009, 21:54   #113
id max requires larger enclouser
Old 12th January 2009, 21:55   #114
m4ugr8's Avatar
Thanked: 129 Times
IDMAX and iDv3's are completely different subs, the IDMAX requires a comparatively large box, fitting two IDMAX is virtually impossbile in a ported box with the correct specs according to the subwoofer.
SAM did not want to fit them just for the sake of it, The result would be decrease in the performance of the subwoofer. Come have a demo of this, The IDMAX in a sealed environment performs like crazy. BTW dont poke him much, He is hunting a CR-V now to fit 3 IDMAX into it
m4ugr8 is offline
Old 12th January 2009, 22:02   #115
no , i mean, it seems to be pulling air from the hole...
but whats in the hole ?
Old 12th January 2009, 22:07   #116
sam_786's Avatar
Thanked: 23 Times
I have mentioned in my earlier post that one fan is still left. That fan will be fixed on the another hole which is left.
sam_786 is offline
Old 12th January 2009, 22:11   #117
what are you trying to say
the fan is for air circulations in side the trey as the amps will nit get any air from outside because of the cover it will more work like a exhaust
Old 12th January 2009, 22:13   #118
m4ugr8's Avatar
Thanked: 129 Times
Yup, The Other hole would be fixed with another fan and then both the fans will work to circulate air inside the AMP rack. Like an exhaust fan
m4ugr8 is offline
Old 12th January 2009, 22:23   #119
Thanked: 341 Times
Lol. Will come up for an audition of sam's car now.
A full fledged one.
Are all the upgrades done?
Old 12th January 2009, 22:27   #120
abhibh's Avatar
Thanked: 39 Times
Sam if one fine day you wake up and your car is missing you can contact me
Jokes apart. Congrats once again Sam. BTW whats the volume of the enclosure ?
i don't think so!!!!!!
abhibh is offline
