Old 24th March 2014, 16:40   #46
DerAlte's Avatar
Thanked: 2,920 Times
Re: Increasing Bass...
Originally Posted by saurabh0110 View Post
... Please tell me if it is appropriate! ...
Go ahead. Hope the installer installs it properly (air circulation around amp; placement of the box).
I have a number of queries. Kindly help
... I guess my dealer is planning to put Y cables on 2 of the channels on the converter.
I am not sure if connecting Y cables is a good idea. ...
Nothing wrong with it. Connect it to the front channels.
... 2) Is it a good idea to connect a Rockford Fosgate power distribution block? ... Is it of any help or should i connect the mono block via battery too? ...
Yes. The mono will draw more current than the 4-channel one. Better have the mono on it's own dedicated line.
... 3) I Received 1 meter of ground cable with the Focal amp kit and not sure if my dealer used it or not? how do i check and is it of any help? ...
Only solution: check yourself. I would expect the installers to have used that wire (unless they didn't know what it was for). Look at what is connected to the grounding terminal of the amp (read manual for location of the GND terminal).
DerAlte is offline
Old 24th March 2014, 17:12   #47
saurabh0110's Avatar
Thanked: 12 Times
Thanks bro i was very hesitant about putting those Y cables. Now i am also planning to buy a JBL wired bass knob for the mono block so that i don't need to fade away the speaker output when i need lesser bass. Though i can't get a good deal anywhere. The knob is costing me 60$
saurabh0110 is offline
