Old 5th February 2008, 00:06   #1
Thanked: 9 Times
Pioneer with JBL Speakers.. Crackling sound
Hi all gurus,
I had installed Pioneer 4050UB with JBL GTO 937 6x9 at rear and JBL GTO 607c component speakers at the front for my Swift. The whole installation with the rear parcel tray(3/4 inch thickness) costed me 16K at trivandrum. The installation was not that pretty good since i had to go back to the shop (Car Shoppy, Trivandrum) several times to get the system properly installed.
IT's been 2 weeks and now i notice a new interesting artifact in my audio. When i am moving on rough roads or when i am breaking the right side tweeter in the front(the GTO 607c) makes a crackling sound. Like a telephone line gone wrong during the monsoon!!!. I need some expert advise from you gurus on the topic.. Sam , do u have time for this? i would really apreciate if you could tell me if it could be anything with the crossover network/ tweeter?
I am asking you this, because the installer is almost clueless on many of the issues , i want to be a bit more aware before i go and talk to this guy.
Any help is apreciated..
Thanks in advance
glidealong is offline
Old 5th February 2008, 03:39   #2
Thanked: 11 Times
maybe its the wiring, it might be getting short somewhere. or say some naked wires must be touching the car body.
many a times speaker wires come under a screw and get damaged. or it could be just loose connections with crossover or HU.
JBL makes some great speakers, the gto936e i have in my accent were originally installed in my scorpio, in the boot door. this car runs in rajasthan under very rough conditions. and image the JBL's were abused by kicks and "jootis" of villagers sitting at the back or were hammered by cargo. the 607's are still installed and work great!
Are you using an amp?
saintsinner is offline
Old 5th February 2008, 11:08   #3
Thanked: 306 Times
Like SS has pointed out it can be loose connection or speaker wiring touching the metal body. Get it rectified ASAP or you HU amp might get damage.
Also is only one tweeter is making this sound or all the speakers.
low_bass_makker is offline
Old 5th February 2008, 12:14   #4
Dhar's's Avatar
Thanked: 628 Times
Originally Posted by glidealong View Post
Hi all gurus,
Is it the shop opp. Sony showroom? Somebody by the name Vinod?
Like SS and LBM pointed out, it must be loose or naked wires somewhere. This guy usually joints wires by just twisting it and taping it.
I had installed my system from him. My mistake. I had to re-do all wiring and connections myself.
Dhar's is offline
Old 5th February 2008, 12:20   #5
Sam Kapasi's Avatar
Thanked: 2,479 Times
Hi baba,
In most probability the wires from the HU to the crossover and theron are not tightened properly. Ask him to remove the corssover unit, undo the speaker cables and reconnect them properly and all tight.
Also check if the front speaker terminals (on the same side side as the tweeter) is perhaps touching the car chassis.
Sam Kapasi is offline
Old 14th February 2008, 10:54   #6
Thanked: 9 Times
Thank You for all the great responses.
Not yet.
Yes only one tweeter was making noise.
Yes.. that's the guy and he has shifted to a new shop in Pongumood. To be nice, the guys are quite unprofessional. And i hope the installation doesnt blow out midway.
And regarding the issue I went into the shop and as you guys pointed out it was some loose wiring. The guy took off the crossover unit and fixed the wiring.
And one more thing happened in between. The left side front speaker(GTO 607) went out. No audio was playing and when i took it to Carshoppy he was saying the JBL speaker connectors are not made to fit tightly and it could come off when doing some rough rides.
Anyway he got it all fixed now. But I lost almost a week for this stuff..
Phew.
Thanks again to you all and especially Sam, the JBL specialist.
Old 14th February 2008, 14:39   #7
Thanked: 306 Times
Good to hear that your problem is sorted out.
Old 24th November 2009, 13:05   #8
addyhemmige's Avatar
Thanked: 490 Times
Hi guys, I am facing a similar problem in my swift. I have installed JBL GTO component speakers in the front and Boston S9(3) 6X9 co-axials at the rear. My HU is a pioneer 5090.
Right from the day one, I used to hear a crackling sound from my rear left speaker, the Boston. I took this up with the dealer and after a few weeks, he replaced it under warranty. The new speaker was working fine for a couple of months and suddenly I started to hear crackling noises from it. When I took it back to the dealer, the noises took a break and stopped. Again, after a couple of days, it started back. I told the dealer about this and he said he cannot do anything until he himself hears the crackling noises.
After a couple of days, the crackling noises stopped and they showed up again after 6 months. Again, it was temporary and it disappeared. Now, after 1.5 years from purchase, those sounds have started again. The speaker does not have warranty and I have to get it repaired myself.
Can anybody tell me the reason for the crackling noises?
addyhemmige is offline
Old 24th November 2009, 14:09   #9
DerAlte's Avatar
Thanked: 2,920 Times
Loose connection at the speaker. Either the crimped incoming speaker wire (I hope they are crimped; hope the installer has not just twisted it around the terminal!), or at the HU end.
DerAlte is offline
Old 25th November 2009, 23:46   #10
Ravi Nandrajog's Avatar
There is some problem in these Boston s9(3) 6x9 speakers as i have come across similar problem a couple of months back. These Boston speakers are not impressive at all.
Fortunately i got them replaced with gto 947
Ravi Nandrajog is offline
Old 27th November 2009, 11:41   #11
Thanked: 490 Times
Even I wanted to replace them with the JBLs. But the day I went to the dealer, the speakers started functioning normally as if there was nothing wrong.
@Der Alte, what do you mean by 'crimped'? I haven't seen the HU end, but he has not twisted the wire around the terminal of the speaker.
I had asked my installer to check the wiring, he said that there was nothing wrong with it.
Old 27th November 2009, 14:07   #12
DerAlte's Avatar
"Crimped" = Push-fit terminal crimped at the end of the speaker wire, which is then pushed over the speaker terminal.
2 more possibilites:
1. Electrical intermittence somewhere else in the inducing electrical noise, though this should appear in all speakers
2. Intermittence in the internal connection (to mid/tweeter via XO) in the left rear speaker. Much more difficult to diagnose - you have to open the speaker and, with a tweezer, give each internal wire a good shake till you pinpoint the culprit joint
DerAlte is offline
Old 27th November 2009, 15:44   #13
Thanked: 490 Times
Yep, my speaker is connected with crimps.
The sound comes only from the rear left speaker and nowadays, it has got a mind of its own. It starts crackling one day and then will be clear for the next few days. Again, it'll start and clear. This has been happening frequently now.
Old 2nd December 2009, 16:24   #14
Swordfish's Avatar
This is such an interesting topic.
I have the same configs and same noice for which i have to skip many songs because the noice is too much for some kinds of music.
I think i should get a check done.
Anyone can suggest a good guy in Hyderabad? Who understands, can check and fix the wiring?
thanks much guys.
Swordfish is offline
