Old 22nd April 2024, 02:48   #1
GautamJ's Avatar
Thanked: 648 Times
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)
Sync 3 Update
(Upgrading Sync3 software version from 3.0 to 3.4)
A much delayed update from my side . Delayed? Well, I had done a FORScan coding which requires Sync3 software version to be 3.4.
Ford never released 3.4 version for a BS-IV EcoSport, so updating the software through official way as mentioned in this thread/post. Also, this is not going to be as crazy as this thread.
Disclaimer: I am in no way related to CyanLabs in any which ways. This process can be risky, and in worse situation can brick Sync 3 system. Also, this cannot be done on a FlyAudio. Only applicable for a Sync3 system.
Sharing following steps to update Sync3 Software Version through an unofficial way:
You need to now the current Software Version of your car's Sync3 System. This can be found by toggling to Settings => General => About Sync. The following screen should show up, take a picture of the same as we will require the software version (red box). In my case it was 3.0 Build 20204.
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-step-2.jpeg
Through this link, download Syn3 Updater on a Windows Laptop.
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-step-1.png
After downloading Syn3 Updater, open the application.
The software version as noted down in Step 1 needs to be filed in 'full version' box (In my case it has to be typed as '3.0.20204').
Region to be selected from dropdown 'Middle East, Africa, India...'.
Navigation should be toggled-off, as in India EcoSport does not get Build-in Navigation.
The configuration can be as default (have changed it in the below attached screenshot).
Application Option can be ignored.
Advanced Options, toggle on the 'Edit Advanced Options?'. If your car is manufactured in 2020 or after 2020, enable the 'MY20 Protection'. If the car is a BS-IV or build before 2020, disable the 'MY20 Protection'.
For Install Mode, choose 'reformat' from the drop down menu.
Insert a pen drive which has no data, as the same will be formatted. For non-navigation software, 8GB USB pen drive is sufficient, for choosing the exact requirement on pen drive refer the next picture.
Now we can apply the settings.
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-step-3.png
The next screen on Syn3 Updater will require to choose the USB Pendrive. For New Verion, choose the same region as before, select the latest version (in my case it was 3.4.23188). Leave the map version, if your car does not have a build-in navigation. The last step is to click on 'Start'. A stable WiFi is required, also the download duration will depend upon the WiFi speed.
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-step-4.png
Upon successful download, it will format and rename the pendrive. Once done, eject the pendrive and hop in to your car.
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-step-5.png
Major work being done, unlock the car, slip into the driver's seat, close the drivers door and wait for the Sync3 display to turn off (do not start the car or put the car in accessory mode). Insert the pen drive in either of the USB port, switch on the car (keep the engine running during the software update process). This step will take time, sharing a few pictures (ignore my ugly editing). Do not remove the pen drive, unless the same is shown on the Sync3 display.
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-wip-1-edited.jpeg
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-wip-2-edited.jpeg
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-wip-3-edited.jpeg
Once the process gets completed, it'll request you to remove the pen drive. Now the pen drive can be ejected (simply pull out the pen drive). The Sync3 will reboot, and after this hard work, you'll be rewarded with the similar below screen . After the reboot, it is recommended to format the Sync3 system for minor software glitches. Also, I noticed the bluetooth name has been renamed to 'Ford EcoSport' (earlier it used to be 'Bluetooth') hence, will require re-pairing of devices.
Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)-wip-4-edited.jpeg
Main reason to get 3.4 update on Sync3 was to have turn-by-turn direction on IC, sadly it does not work through Apple Carplay even on iOS 17.4.1 (should work through Android Auto).
GautamJ is offline   (23) Thanks
Old 23rd April 2024, 08:30   #2
Thanked: 321,278 Times
Re: Ford: Updating Sync3 software the unofficial way (from v3.0 to v3.4)
Thanks for sharing, GautamJ! Moving your post out to a new thread so as to update others. A new thread means 100X the views & 100X the visibility in search engines, including Google. Will add to homepage this week .
@ BHPians, if you should spot any good post in an existing thread that deserves its own new thread, please report the post and we'll move it out for greater visibility.
Thank you!
GTO is offline   (3) Thanks
Old 28th April 2024, 22:30   #3
Thanks GautamJ quite simple and useful updated mine to 3.4 personally though I liked the older version.
Airavata is offline
