Old 30th May 2007, 09:18   #1
v1p3r's Avatar
Thanked: 7,462 Times
What is a condenser?
What is a condenser, wrt ICE? Binz's car has this annoying alternator whine, and we went down to this store to see if they could give us a quick-fix, but the guy said "Saab, condenser lagaana padega." I have no clue what that is. I hope you guys do.
v1p3r is offline
Old 30th May 2007, 09:24   #2
Vid6639's Avatar
Thanked: 44,135 Times
with respect to ICE condenser is nothing but a capacitor.
Vid6639 is offline
Old 30th May 2007, 09:45   #3
hydrashok's Avatar
Thanked: 18 Times
Like vid said, he must have meant a capacitor.
But IMHO spending money on a Cap is a waste. Most power/noise problems can be traced to the wiring:
1) Bad quality power wiring (BOSS, usually)
2) Power wires run with RCA interconnects, causing noise to creep-in. This usually happens with RCAs with bad shielding. But even with the best quality RCAs and best quality power wires, and best quality speaker wires, I'd personally run the RCAs & speaker wires and the Power wires along different sides of the car. (RCAs and speaker wires can be run together).
3) Some mechanical problem with the alternator.
4) Some problem with the battery (from personal experience, EXIDE seems to cause this problem at times).
Most likely the problem will be fixed with the re-routing of power wires away from RCA & spkr wires. Else, instead for adding a Cap, I'd upgrade to better power & RCA wires. Cost will work to about the same.
Caps are usually needed to tide over sudden & huge power requirements made by amps powering subs, for eg. when an especially wicked bass note needs to be played. I don't think they will help with removing alternator whine.
Last resort, (only) if all else fails, you'll need to get a line-noise filter. Again a bit expensive, if you want the job done well.
Absolute last line of defense: A line-noise "masker" (and all other noise "masker") in the guise of a GF in the front seat. Yak, yak, yak. No more line noise
hydrashok is offline
Old 30th May 2007, 10:00   #4
Vid6639's Avatar
As hydra said, get the battery checked is it old or new. If the battery is old then that could be the reason of alternator whine.
The battery may not be charging properly.
The most common problem in loose ground connection. The grounding may not be proper causing the alternator whine.
Vid6639 is offline
Old 30th May 2007, 10:11   #5
Thanked: 306 Times
Condenser is a also said as capacitor.....it is correct and here we are not talking of 1 farad which is used to keep the supply voltage of the car supply up....but the one we are discussing is used in conjunction of ground here to filterout the noise...
low_bass_makker is offline
Old 30th May 2007, 10:33   #6
Thanked: 26 Times
Pioneer HU ??
Just try grounding the RCA's / slots to the back of the HU with a copper wire.
Usually fixes the problem and its the last thing the shop guys will tell you to do (well until they hit ground in your pockets.)
s0uljah is offline
Old 30th May 2007, 10:40   #7
binz's Avatar
Thanked: 431 Times
Originally Posted by s0uljah View Post
Pioneer HU ??
Yep,Pio HU it is.Exactly what has to be grounded??
binz is offline
Old 30th May 2007, 10:47   #8
Thanked: 26 Times
I have a pic of whats to be done, imageshack aint working though
edit : get on MSN
s0uljah is offline
Old 30th May 2007, 11:03   #9
Thanked: 306 Times
here what souljah posted few days ago...
http://www.team-bhp.com/forum/413720-post5726.html
here is the pic who are in a hurry to see it...
Old 30th May 2007, 13:13   #10
gunbir's Avatar
Thanked: 33 Times
Originally Posted by low_bass_makker View Post
Yes, most Pioneer HUs (even the expensive ones costing 50k and above) have this problem. Do ground your RCA grounds to your chassis and the noise will be reduced / eliminated.
gunbir is offline
Old 30th May 2007, 14:50   #11
clipto333's Avatar
Thanked: 7 Times
hi,
i had the same problem wit my pio HU. i also did the same thing . the noise was totally eliminated. i inserted a 1 rupee coin in between the stereo chassis and the rca input.lol. after some time i got my hu repaired.
cheers
clipto333 is offline
Old 30th May 2007, 15:33   #12
Thanked: 306 Times
I have heard it is with most of the pioneer HU....but I have used nearly 5-6 HU personally and I have faced this problem in a single one.....
Old 30th May 2007, 16:36   #13
clipto333's Avatar
Thanked: 7 Times
HI,
this usually happens when the rca leads connected to the hu come in contact with the ground of the vehicle when the HU is on. when this happens, a tiny fuse on the main board gives way. well this thing happened with me. dont know about others.
cheers
clip
Old 30th May 2007, 16:40   #14
Thanked: 306 Times
Not the fuse I would assume the track on the PCB (printed circuit board) of the HU
Old 30th May 2007, 16:42   #15
gunbir's Avatar
Thanked: 33 Times
HI,
cheers
clip
I thought so too till recently, and of course all precautions were taken, but when we installed a high end Pioneer unit straight out of the box, it had the same problem.
gunbir is offline
