Thanks again, Reinhard.
That pretty much clears most of the doubts I had.
Originally Posted by Reinhard And not just DIY, I think a lot of car accessory store guys also keep away some times because of not being sure. |
Yes you are cent percent right.
That is why, I am also thinking of a DIY project and was researching on the same.
Originally Posted by Reinhard The BT audio is better than any of the systems I have used so far. Call clarity is superb & mic is extremely sensitive. |
Good to know!!
Bluetooth and voice calling, is one of the main reasons, that I am planning for an ICE upgrade.
Have been using the external Bluetooth device (Tantra fluke), from past 2 years. Though its quality is good, I wanted to overcome the dangling wire and lack of features. Hence the upgrade plans.
Originally Posted by Reinhard There is no external mic to be mounted anywhere. The mic is on the top left corner of the head unit on the face, right above the power soft-key. Well placed. I have tried calls & the mic is fantastic. |
My bad, I missed observing the pic of Kit/contents of the system you shared, which obviously didn't have external mic wire.
Few of the systems I had seen, had an external mic as well, so I was confused.
Originally Posted by Reinhard Since there is no wiring required for the mic - its really your preference. I mounted it on the LHS because the antenna port of the head-unit is on the side near the glove box when installed. |
Ok got it now. Will keep this in mind during my project.
Originally Posted by Reinhard The head unit is hooked up to the stock harness of your car. So it gets power ONLY when your existing system used to get power. No difference here. |
That makes sense to me now. My current OEM system doesn't work if ignition/ACC mode is OFF. So no more worries for me, related to battery drain.
Originally Posted by Reinhard Just tell the exact model & year of your current car. They'll ship the correct matching OEM connector & harness pigtail. |
Yes, that's what exactly I have done.
Still better, I actually removed the system and have taken pics of all OEM pins/ports and connectors.
I have shared the same along with the dashboard pic with the seller. Still waiting for his response.
Originally Posted by Reinhard Any time mate! I hope it helps. You can drop more questions if needed during your project too. Do share your DIY too! There are plenty i10 owners who'd love this change. (There is one in my immediate family too!) |
Thank you, will get in touch with you, if struck somewhere during the DIY process.
The connectors, panels, ports etc of Hyundai are obviously different to that of Maruti. So, as you said, a DIY thread might help other Hyundai car owners.
![Thumbs Up](https://www.team-bhp.com/forum/images/smilies/thumbs up.png)
