Old 21st December 2019, 20:23   #121
v1p3r's Avatar
Thanked: 6,946 Times
Re: Upgrading your OEM Car Audio using DSPs (budget version)
Out of curiosity, does putting a DSP on something like the Mercedes Burmester or BMW H/K system make a difference?
v1p3r is offline   (1) Thanks
Old 21st December 2019, 22:04   #122
Thanked: 21,422 Times
Yes.
You have OEM integration systems where you can modify and tune as per the requirements (Eg: JL Audio FiX82 & FiX86).
a4anurag is offline
Old 22nd December 2019, 22:54   #123
vkhandelwal's Avatar
Thanked: 32 Times
Today i got the sony dsp installed in my car. Was trying to go for 2 channel input install with front components and bridged subwoofer.
However there was a confusion on which wiring connection to select
The manual has speaker cord connection table for 4.1 connection only and it does not specify which combination of speaker connection to use when selecting type 2 connection ( 2 way speaker with bridged woofer )
In the demo and advertisement video it displays a different combination and suggests to use passive crossover with 2 way connection and filter option disabled while in manual it seems that direct connection is to be used with lpf+hpf filter selected
I was thinking that may be the green and purple wires were to be used for mid woofer of my component but at the end went for 4.1 connection with passive crossover supplied with infinity components and used front speaker connection only.
May be I will add coax in back doors but interested in knowing what would be the speaker connection for two way front speakers with bridged woofer selected
Any help would be greatly appreciated
vkhandelwal is offline
Old 25th December 2019, 12:14   #124
tush's Avatar
Thanked: 12 Times
I have been planning WagonR 1.2 AGS ZXI, the only thing that puts me off is the stock ICE. The executive says there is no option to upgrade or replace the ICE.
Guys any idea if it could be done, and will it be worth it. Just to add my swift has DLS R6A component, Ground Zero sub, HK amp and Clarion DXZ/DZX series headunit with time alignment feature. Installed by Ajay Kamath 8 years back.
Not sure why Maruti doesn't realise that good quality ICE is now one of the factors in a car buying decision
tush is offline
Old 26th December 2019, 12:16   #125
navin's Avatar
Thanked: 9,397 Times
Originally Posted by vkhandelwal View Post
I have bought sony DSP gs6 which I got at a good price. Will infinity 6530 prove to be a good replacement to front stock speakers? Which sealed woofer should I go with?
The 6530 should work well.
I think they expect you to use it in active mode (2 channels for midbass and 2 channels for tweeter). See Page 14. Option 2.
https://www.sony.co.in/electronics/s.../D6271001M.pdf
navin is offline   (1) Thanks
Old 26th December 2019, 12:26   #126
Thanked: 32 Times
Thank you Mr Navin
I was indeed referring to second option but the only confusion was which output wire to use to connect mid bass
Old 26th December 2019, 15:53   #127
badboyscad's Avatar
Thanked: 479 Times
Tata Nexon XM audio upgrade using DSP
I had recently upgraded the audio system of my Nexon XM using a Pioneer DEQ-S1000A DSP, while retaining the stock harmon kardon(non touchscreen) head unit.
Details in below post:
https://www.team-bhp.com/forum/offic...ml#post4711345 (Tata Nexon : Official Review)
badboyscad is offline
Old 26th December 2019, 16:01   #128
pankajparikh's Avatar
Thanked: 185 Times
Can someone please confirm which is the best speaker upgrade for Honda City 2019 model. The current audio clarity and bass go for a toss the moment sound is increased to 60+%. I was looking for an ICE upgrade but its too cumbersome as steering mounted controls, etc also need an update and warranty might be affected. Existing ICE is too laggy but I can work with it except the pathetic sound clarity.
pankajparikh is offline
Old 26th December 2019, 16:21   #129
navin's Avatar
Thank you Mr Navin
Page 15 has those details. I have attached a picture of that below.
It says Tweeter - Front. Mid - Rear. So the Front connections go to the tweeters. Hope this helps.
Upgrading your OEM Car Audio using DSPs (budget version)-sony-dsp-speaker-connections.jpg
Old 26th December 2019, 16:41   #130
Thanked: 32 Times
I had read that but interpreted that terminal can take tweeter/front speaker /mid/rear speaker
/ as Or but with now your confirmation it looks like it is to use tweeter or front speakers in front speakers connector and mid bass or rear speaker in rear speaker marked connector
Thanks !
will try this combination to check if it sounds better else will continue with 4.1 setup
regards,
Vikas
Old 26th December 2019, 16:48   #131
navin's Avatar
Pin 1 and 2 are Front Speaker Left which means Left Tweeter. You should be able to deduce the rest.
Old 26th December 2019, 17:27   #132
Thanked: 32 Times
Thank you for the support and kudos to you for sharing budget dsp options. it made me upgrade my car sound and now it sounds better
vkhandelwal is offline   (2) Thanks
Old 4th January 2020, 20:22   #133
Thanked: 32 Times
today I connected the components in active mode. front channel is being used to drive tweeters and rear channel mid bass.
now I am confused about LPF and HPF setting for Mid woofer.
I have set HPF for tweeters to 4Khz
what settings I should use for mid woofer
it has both LPF range between 500hz to 4 Khz
and HPF between 50hz to 500Hz
the Woofer in bridge mode has been set to around 80Hz ( approx. because there is no way to explicitly set that ( range is 50 hz to 500 hz )
4.1 mode was a-lot simpler as it was used without filter and passive filters were being used for components
Please share inputs. will appreciate any help
Old 6th January 2020, 13:12   #134
navin's Avatar
what settings I should use for mid-woofer
it has both LPF range between 500hz to 4 kHz
the Woofer in bridge mode has been set to around 80Hz ( approx. because there is no way to explicitly set that ( range is 50 Hz to 500 Hz )
Typically the HPF for the tweeter would be around 4k and the LPF for the woofer would also be around 4kHz. See the image below for an HPF and LPF of 1kHz.
You do not need to set any HPF for the woofer unless you have a subwoofer.
If you have a subwoofer set an HPF for the woofer between 60 and 100Hz.
Old 7th January 2020, 15:48   #135
Thanked: 32 Times
Attachment 1953946
I do have subwoofer connected to 5-6 channel in bridged mode
Actually there is no way to disable HPF for mid woofer channels. for the Mid woofer I need to set both HPF ( Range 50 Hz - 500Hz) LPF (Range 500Hz - 4 Khz)
I have set 4Khz as LPF for channels using tweeters and 80 Hz for subwoofer channel
for mid woofer I have set HPF as 80 hz and LPF as 4KHZ. I am assuming that this will give me full frequency
80Hz and below to subwoofer
80hz - 4Khz to Mid woofer
4Khz > to tweeters
Vikas
