Old 26th March 2008, 13:58   #61
praveen_v's Avatar
Thanked: 219 Times
Originally Posted by Bass&Trouble View Post
5.25" speakers can be installed in the stock locations of the Fiesta.
But i want only 6.5" comps up front. What are the options to have it installed?? which is the best (and neat) option? spacer rings or adapters or anything else??
praveen_v is offline
Old 26th March 2008, 14:00   #62
Bass&Trouble's Avatar
Thanked: 137 Times
I think a little of the door metal will have to be cut for that. But why only 6.5"? Good 5.25s can do quite well too.
Bass&Trouble is offline
Old 26th March 2008, 14:09   #63
praveen_v's Avatar
Thanked: 219 Times
I had the electra 6.5's in my mind. really liked them. Cutting the door panels is ok with me. But cutting metal . No way!
Old 26th March 2008, 14:13   #64
Thanked: 137 Times
The Electra 5.25s are equally good.
Old 26th March 2008, 14:21   #65
swale84's Avatar
Thanked: 9 Times
Ajay, won't something like what we did in my Ikon be possible? Just cut the door trim to let the MDF ring sit within the dor and have the rest protruding into the passenger compartment?
Overall finish was pretty neat and the tweeter can be flush mounted.
swale84 is offline
Old 26th March 2008, 14:26   #66
Thanked: 137 Times
Stock speaker location in the Fiesta is not on the lower side of the door. Its high up, and would look very ugly there besides being quite difficult to implement. Not worth the effort when you can use an equally potent 5.25" speaker set and retain stock look.
Old 26th March 2008, 14:34   #67
swale84's Avatar
Thanked: 9 Times
Alright, wasn't aware of the stock location on the Fiesta. Yup, that solutionwould only work if the speaker was to be mounted at one of the extreme corners of the door.
I'm pretty sure the 5.25"electra's will be potent enough, judging be the way those 6.5"'s sound :-)
swale84 is offline
Old 26th March 2008, 14:44   #68
praveen_v's Avatar
Thanked: 219 Times
Yeah I agree. the stock mount locations are higher in the doors. So which will be better? the 5.25" or the 5x7" jbl compos as someone mentioned earlier in the thread.
Edit: the jbl 5x7's are not comps. So that leaves me with the 5.25" comps. B&T any idea how much the electra 5.1 costs with bill & warranty?? Do i still have to use spacers to fit the 5.25's??
Old 26th March 2008, 14:53   #69
dhaval's Avatar
why not just a speaker upgrade? Maybe add an amp & sub?
Thanks suhail for the suggestion, but I think that the speaker upgrade will only show more better results if the HUs upgraded aswell, may be. May be Ajay can put a light on this.
dhaval is offline
Old 26th March 2008, 15:46   #70
moralfibre's Avatar
Thanked: 14,440 Times
Sorry Dhaval, Ajay deals in Car Audio equipment. I don't think he has yet launched lighting products yet. Once he does he can put some light on this. Till then you will have to do with your own torch.
moralfibre is offline
Old 26th March 2008, 15:51   #71
dhaval's Avatar
my post was in the light of this: quoted below
Ok you help me with the above
dhaval is offline
Old 26th March 2008, 15:53   #72
Thanked: 137 Times
6k. Its not an idea, I'm dead sure that is the correct price. Well mostly because it was my idea to keep it at that price. So yes, an idea it is I guess.
A 5x7 to 5.25" adapter will be required, yes.
Yes, changing the head unit would be good.
Old 26th March 2008, 18:02   #73
vikram18's Avatar
Thanked: 27 Times
Changing Dhaval's Head Unit is not just a good idea, it's an immediate requirement! . Light just shines through; nothing stays inside
If cutting can be avoided, it should. If Ajay says the 5.25s are as good, I'd certainly take his word for it.
vikram18 is offline
Old 26th March 2008, 23:00   #74
praveen_v's Avatar
Thanked: 219 Times
6K for 5.1?? I thought the 6.1 came for that price.
Yeah, I have taken his word
Old 27th March 2008, 00:40   #75
vikram18's Avatar
Thanked: 27 Times
Daam bade aur darshan chote
vikram18 is offline
