Old 22nd January 2018, 23:42   #61
SPARKled's Avatar
Thanked: 664 Times
Re: Installed! Pioneer AVH-Z5090BT in my Honda City
Where does one connect the phone to enable android auto. Is it the same as the usb cable where one connects USB pen drives?
SPARKled is offline
Old 23rd January 2018, 09:22   #62
sridhu's Avatar
Thanked: 2,756 Times
YEs. You also need Android Auto installed on your phone
sridhu is offline
Old 26th January 2018, 14:08   #63
SPARKled's Avatar
Thanked: 664 Times
Have been trying to get AA work with my Honor 6x but I get the screen with "to use android auto please park your car and check your android phone" message and the phone goes to charging mode. Its running on Android 7. Any help will be appreciated.
SPARKled is offline
Old 12th April 2018, 10:36   #64
vsrivatsa's Avatar
Thanked: 4,056 Times
Originally Posted by bsdbsd View Post
The purpose of this write up is to review the localized aspects, where as the YouTube video below is about the generic aspects of this unit. Got the Pioneer AVH-Z5090BT installed a couple of weeks back in my 4 yr old Honda City. There are no online reviews for the India unit in Youtube as this a new launch.
Came across this thread and seems like an interesting option. I have a 2014 Honda City as well and had the following questions for you:
1. Mine is the V Variant and hence came with a OEM Reverse Camera which offers 3 views. Did the Reverse Camera integrate with seamlessly with the Pioneer Unit and will it provide all the views as well?
2. You mentioned that the Steering Mounted Controls were "botched up" in the initial thread. Did you get it fixed and is it working correctly?
3. Do you think there are better options today since your post dates to Sept 2017.
Thanks in advance!
vsrivatsa is offline
Old 12th April 2018, 12:36   #65
Thanked: 158 Times
Can someone pls tell me what is the difference between AVH-Z5090BT and AVH-Z2090BT? 2090BT is around 4k cheaper i assume. Which one do you recommend (primary requirement being - access google maps, reverse camera and bluetooth)? Hope i have not hijacked the thread.
kiranknair is offline
Old 13th April 2018, 15:25   #66
Prodigy07's Avatar
Thanked: 639 Times
To give you a quick comparison between the two, please pick Z5090 as the screen is 7 inch and is both Android Auto and Apple Car play compatible.
Please check this - https://pioneer-india.in/products/compare/?p=274&p=275
Prodigy07 is offline   (2) Thanks
Old 13th April 2018, 16:30   #67
sridhu's Avatar
A quick update - the Bluetooth became very jerky & jittery when I moved to an Nokia 8.
The issue went away once I upgraded firmware twice. Now I am on V 8.32 and the Bluetooth works fine.
I have heard of issues with the iPhone Bluetooth as well but I am not sure if it is resolved by this.
The update process itself is quick & trouble free
sridhu is offline
Old 16th April 2018, 17:27   #68
Thanked: 158 Times
Thanks for the suggestion. I bought 5090 and it works really awesome. Have used google maps, bluetooth, reverse camera and no issues so far.
Old 16th April 2018, 19:48   #69
Thanked: 446 Times
How has it been to use the resistive touch screen? Have you faced any issues or frustrations?
suku_patel_22 is offline
Old 16th April 2018, 21:19   #70
Thanked: 30 Times
Have installed Z5090 BT on my 2005 Amaze , the HU brought in much needed relief. Other than occasional Bluetooth Jitter the HU has been outstanding. AA had issues with my old cable , with the cable switched its a breeze.
The only issue is the second hanging cable other than the OEM(pig tail connector) one. has any one able to resolve this?
iceman07 is offline
Old 18th April 2018, 11:15   #71
Thanked: 504 Times
Originally Posted by vsrivatsa View Post
...I have a 2014 Honda City as well and had the following questions for you:
Sorry about the delay in responding. I was traveling.
I had no OEM reverse fitted, so I can not comment on it.
I never got it to work. I had no time to go to my car guy again. It never worked and I know why it did not work - its due to the bad component used by my car guy. The problem I have is, it works while the car is static and the moment car moves, all the controls will go for a toss. Weird. I have stopped using in-built controls.
I have not checked recently but you must be having better options during 2018. At the least, dont touch any unit without a capacitive touch screen. Wait until such a unit is launched. No resistive touch units please.
bsdbsd is online now   (1) Thanks
Old 19th April 2018, 15:52   #72
Prodigy07's Avatar
Thanked: 639 Times
Hi bsdbsd, can you try to set the Steering Mounted controls by using the Option 'W/O adapter and Japanese car' and see if that works?
I've set all the controls in that fashion and it works like a charm in my Baleno.
The only grouse that I've is the Bluetooth audio. Even after the latest firmware update to 8.32, the connectivity at times goes for a toss. I'm not sure if the incoming messages on Whatsapp are the culprit for connectivity loss!
Prodigy07 is offline   (1) Thanks
Old 25th April 2018, 23:16   #73
Thanked: 504 Times
Thanks for the nice suggestion. I will try it next week. I think the malfunction is due to the "learning steering wheel" logic/software. Once I enable the steering mounted controls, it works when the car is at a standstill. Once it starts moving, I think the "learning" component tries to "learn" something and wreaks havoc. The volume continues to increase or decrease. My car installer does reset the system and everything works in front of him. Once I start for home, this thing comes into the picture. . I will once gain try your advise and let you know how it goes.
Old 6th June 2018, 09:14   #74
Thanked: 504 Times
[*]You said "CarPlay navigation is not available in India, as Apple does not support both Google and Apple maps" but I can run Google Maps (never tried Apple Maps) on my iPhone. I assume Car Play technology reflects everything that is on the iPhone on the Head unit so wont the Google maps playing on my iPhone reflect on the Head Unit too?
Finally! In Mondays WWDC 2018, Apple announced that starting this fall (post September), iOS 12 supports third party navigation apps! Yay! Miracles do happen. This is indeed great news for all Apple CarPlay owners, especially in India. Well done Apple and Google.
Old 17th June 2018, 18:48   #75
sridhu's Avatar
Amazon prime used work fine but of late, it just keeps looping without starting.
Anybody else having this issue?
I am on 8.32 firmware and prime music used to work on this version
sridhu is offline
