Old 5th April 2017, 04:30   #1
DrBoom's Avatar
Thanked: 28 Times
Infinite Baffle Subwoofer
Hello there, I was wondering if infinite baffle subwoofer installation is common in India?
The main emphasis on such installation is that you still retain your boot space whilst using your trunk area as usual, so in conclusion, you get bass you want in your car and that it remains practical to gain access to spare wheel and to use the trunk area as well.
I am currently using 2 x 15 inch Rockford Fosgate subwoofers in this configuration and although my car is a hatch back, (its a Subaru Impreza 2010 RS model) I still can access my boot area.
Currently I have a Phoenix Gold RX1100.1 amplifier powering them.
My trunk area has been sound deadened and MDF panels were made for the entire boot area to accommodate the bemoth subwoofers and to seal the front / back standing waves from cancelling out. My front components are Boston Acoustics Pro 6.4 components and rears are Rockford Co-ax speakers being powered by a Precision Power PPI PC450 amplifier. My head unit is a Pioneer DEH-9850BT which has time allignment and all the bells and whistles as I am aiming for a sound quality system, not booming bass!!
Please let me know your thoughts.
DrBoom is offline   (6) Thanks
Old 5th April 2017, 10:52   #2
navin's Avatar
Thanked: 9,950 Times
Re: Infinite Baffle Subwoofer
My first car subwoofer in India was an IB. You have listed the challenges of IB pretty well (you have to seal the trunk area to prevent cancellation). This is even more difficult in a hatchback because the rear deck is acoustically very porous.
Eventually I tore the IB out and built a TL in the trunk of my Hindustan Motors Contessa ISZ. The car was not my primary car so I did not need the trunk for baggage.
If you are looking for tight bass IB might be the toughest option to use. Sealed is the easiest.
navin is offline   (4) Thanks
Old 5th April 2017, 11:18   #3
Thanked: 4,910 Times
I think practically an IB sub will approximate to an open baffle, unless your enclosure seals are perfect. You will need to apply equalization depending on your baffle size and shape to get a flat response, and possibly a lot of power
Have Fun! http://www.linkwitzlab.com/models.htm
greenhorn is offline   (2) Thanks
Old 7th April 2017, 13:38   #4
Thanked: 27 Times
My .02 Cents on this,
Why not go for the following:
* Install a slim Sub in hatch door. You should be able to get decent volume by building enclosure out of Fiberglass.
* Consider Isobaric configuration to reduce enclosure volume (better if you can use slim sub).
* Build an enclosure inside your spare tire to optimize space utilization. I had partially built something like this in the past. Will post photos if interested.
Cheers,
Venki
venki7744 is offline   (1) Thanks
Old 3rd July 2018, 11:55   #5
DrBoom's Avatar
Thanked: 28 Times
I tell you once you go IB subwoofer setup, you will never return to a boxed subwoofer. If you asked why? Its because of the slow roll off and where you actually feel the subwoofer, not only hear it.
DrBoom is offline
