Old 8th July 2017, 19:50   #1621
harsh79's Avatar
Thanked: 797 Times
Re: The Dashcam / Car Video Recorder (DVR) Thread
Originally Posted by BlueEyes View Post
No. Tried every trick in the book, 2 different cellphones and 2 different cables no luck. I posted this even on rcgroups.com forum. App developer(Thomas) himself is responding to my queries but not much help.
Anyways, I found an alternate app to do this for me in the meantime. This app detected my dashcam instantly and gives the live feed
Could be something to do with the Type-C OTG and the app. You could also try FinalCam (I remember checking it out).
Thanks, I have this mount already which came bundled with my Mobius package. Will try this out tomorrow
Depending on the rake of your windshield, flipping the mounting mechanism to the front (as shown in the picture I'd posted above) will allow you to mount the camera a lot closer to the windshield. Try it both ways..
harsh79 is offline   (1) Thanks
Old 9th July 2017, 13:05   #1622
Thanked: 184 Times
Just got VIOFO A119 installed in my car using the hardwire kit in a nearby accessory shop. However, as the supplied fuse tap did not fit with existing fuses, the accessories guy tapped into wiring and got power from a wire powered up during ignition only.
The installation is neat and all wires are tapped and concealed properly. My only concern is does it void warranty if we directly tap into wiring instead of via fuse box?
Suryendu87 is offline
Old 9th July 2017, 13:35   #1623
Thanked: 21,423 Times
If the service guys spot it then the warranty would be void. You could have ordered the compatible fuse tap and then installed it IMHO. Plus if your raise any warranty related claim then they'll check all areas and may find the tapping done.
Tapping directly isn't a good way. Any images of how the tapping was done?
Old 9th July 2017, 13:44   #1624
Thanked: 38 Times
Originally Posted by harsh79 View Post
I've seen a lot of reports on DCT about Sandisk red/grey cards not playing well with various dash cams, mostly Novatek based cameras. I had problems with the Sandisk while using the Mini 0805 (Ambarella based).
Been using the following cards without any issues so far -
Transcend 400X 64GB X 2 - one for 13 months and the other 8 months
Sandisk 128GB (all black with red print) - 6 months
Samsung EVO+ 64GB - 3 months
Incidentally all the above cards are used with Novatek based cameras.
I had a similar problem with Kingston 64 GB card, which after first use started to show error and Viofo A119 stalled recording completely.
Changed memory card to a 16GB Strontium (only choice in croma), and it seems to be working well so far!
sumeet007 is offline
Old 9th July 2017, 16:01   #1625
Thanked: 184 Times
Hopefully I will not have any issues to regret this decision.
Have few pictures of the installation. Sorry about the quality, taken in my mobile. I had the direct tapping removed immediately and insulated the shredded region of original wire. Currently dash cam is connected to 12V power socket.
The Dashcam / Car Video Recorder (DVR) Thread-wp_20170709_001.jpg
The Dashcam / Car Video Recorder (DVR) Thread-wp_20170709_003.jpg
The Dashcam / Car Video Recorder (DVR) Thread-wp_20170709_004.jpg
The Dashcam / Car Video Recorder (DVR) Thread-wp_20170709_006.jpg
Old 9th July 2017, 17:20   #1626
That red wire as seen is the repaired one or the wire that is connecting the dashcam?
You can refer my thread (MINI 0806) (DIY Install & Review - The Mini 0806 Dash Camera) or Harsh Sir's (Street Guardian SG9665GC V2) (Street Guardian SG9665GC v2 Dashcam: Review & Install) for all the details.
Old 9th July 2017, 18:54   #1627
Thanked: 184 Times
Thanks for the links. Yes the red one was to power the dash camera. Anyways I had it removed, secured the shredded region with black tape, applied additional tapes on the cover and finally rested the hardwire kit for future use(When I get the compatible fuses). For now I have used 12V socket and routed wire through left A pillar, behind the glove box.
Old 10th July 2017, 09:18   #1628
Mr.Boss's Avatar
Thanked: 7,484 Times
Originally Posted by Mr.Boss View Post
Should there be an action from my end?
After more than 2 weeks the status remains unchanged, leaving me little worried.
Mr.Boss is offline
Old 10th July 2017, 10:07   #1629
Thanked: 181 Times
No need to worry! I received my product last week after the item was held with customs for 10 days. And I was charged Rs, 960 as duty after estimating the product as Rs. 2250. So, you may have to get ready for similar payment.
batman is offline   (2) Thanks
Old 10th July 2017, 14:27   #1630
blackbandit's Avatar
Thanked: 645 Times
I received the product last week well within 20 days without paying any duty. Which seller did you buy the product from ? And was there any custom declaration form stating a lower value in your package ?
blackbandit is offline
Old 10th July 2017, 14:39   #1631
anachronix's Avatar
Thanked: 1,336 Times
Have order Anker Roav camera from Amazon.com
https://www.amazon.com/Dashboard-Rec.../dp/B06XNSDRW8
Anybody else who has tried these ones? I bought them at an offer price of $68.
anachronix is offline
Old 10th July 2017, 15:19   #1632
Thanked: 181 Times
The cost I paid for the product was $29.27 after applying $2 coupon. So, it almost matches the estimated value of the item. I think it caught the customs eyes due to it's larger size of the packaging; The box is about double the size, than what is required. When I informed the seller about this, he was saying, some customers may create issues, when the packaging was different.
https://www.aliexpress.com/item/Car-...809626345.html
The Dashcam / Car Video Recorder (DVR) Thread-img_2656.jpg
The Dashcam / Car Video Recorder (DVR) Thread-img_2657.jpg
batman is offline
Old 11th July 2017, 12:24   #1633
Thanked: 43 Times
Which is the best camera with motion sensing and good night visibility.i want one which can stay on when car is parked or atleast detect motion and record if someone tries to vandalize the car.
caraholic is offline
Old 11th July 2017, 14:07   #1634
Mr.Boss's Avatar
Got it delivered today
No duty charged as the seller declared it as a gift and with a lower price
Mr.Boss is offline   (2) Thanks
Old 11th July 2017, 21:49   #1635
harsh79's Avatar
Thanked: 797 Times
If parking mode is a priority, check out the F770 (dual channel) from Thinkware. Low bitrate is the only con with this model. The F800's release also seems around the corner.
Non-buffered motion-detect is useless as there will be no footage recorded until an event is triggered due to motion or shock (g-sensor). Basically the event is waking the camera up to start recording after its already happened.
IIRC with the F770 you'll have 8 seconds of video also leading up to the event as those many seconds are continuously being saved on a cyclic basis to its internal memory.
harsh79 is offline
